Question about John Deere Garden
How do you remove the gear at the end of shaft to place for it? John Deere LA175
    Sergeant:
  • John Deere Expert
  • 187 Answers
It's a lock nut, but you should have no trouble removing it. Just hold the steering wheel, or turn it all the way to one side. Put a socket on the nut below the gear and ratchet it off. That's all there is too it.
Posted on Mar 29, 2015
  • 4 more comments
  • Lawanna Hunter Mar 29, 2015
    We did remove the nut but the gear will not come off??
  • Kprime
    Kprime Mar 29, 2015
    lol, get a bigger hammer, nah, just use some force and it should pry off. I have taken many of them off. They are splined and just need some persuation.
    I did not get the picture.....
  • Kprime
    Kprime Mar 29, 2015
    Thank you so much!!!!
  • Kprime
    Kprime Mar 29, 2015
    you are welcome
SOURCE: gas tamk removal john deere 115
I had the same thing happen. I got the tank out, but it wasn't easy. Take out the bolts out that hold the rear end on. Take off the two springs that support the seat. Take out the battery and the battery tray. Take out the 6 bolts that hold the black cowling and the front of the green platform to the frame. This will allow you to lift the seat platform far enough off the rear end to allow the tank to be pulled out through the side. You also have to remove the metal bracket which holds the front of the tank and has caused the tank to leak in the first place. New tank is $56.00 not installed. I used a soldering gun and melted the plastic back together. I think it will hold quit a while. I know this is a little sketchy, but It worked for me.
Posted on Jun 02, 2009
  • 548 Answers
SOURCE: can't get front wheel off my john deere lawn tractor
remove the cap on wheel then there is a ring or cotter pin to remove then pull wheel off
Posted on Aug 22, 2009
mowerman1857
  • 389 Answers
SOURCE: John Deere LA175 lawn tractor front wheel bushings
Remove the tire and wheel from the spindle. Take a long punch or similar item and reach in the center of the wheel hub where the spindle goes. Locate the space in between the inner and outer bushing and tap the edge of the old bushing until it comes out. Now go in from the other side and do the same with the other bushing. This one will be a little easier to do since you don't have to hunt for the center space. Put the new bushings back in the same way just be sure you drive them in STRAIGHT
Posted on Sep 18, 2009
  • 229 Answers
SOURCE: MOWER DECK BELT ROUTE FOR LA175 JOHN DEERE LAWN
you can try johndeere.com you should be able to find it there.
Posted on Oct 20, 2009
spiegela
  • 3 Answers
SOURCE: john deere 445 tractor v twin 22 hp engine, john
Where did you get it fixed for $300. Dealer wants 6 hours labor and $400 in parts. Total cost will be $1,000.
Posted on Jun 05, 2010
John deere la175 deck blades spin quit and fast. hook up to pto and engage engine boggs and tries to die
Maybe the travel speed is too high for it or the fusible link in starting circuit is blown.Check and adjust timing belt tension if necessary.Visit john deere expert or dealer.
Jul 21, 2016 | John Deere Garden
How do you get the gear at the end of the steering shaft off to replace it on a John Deere la175 lawn tractor?
It's a lock nut. But you should have no trouble removing it. Just hold the steering wheel, or turn it all the way to one side. But a socket on the nut below the gear and ratchet it off. That's all there is too it.
Mar 29, 2015 | John Deere Garden
Will a John Deere LA175 lawn tractor start without the mower attachment installed?
I wouldn't think so. I know you DO need the seat switch depressed in order to start the engine.
Oct 18, 2014 | John Deere Garden
John Deere la175 mower the front center pully its
Sounds like you need a shear pin replaced where the pulley is spinning on the shaft.
Oct 07, 2014 | Garden
John Deere la175 mower the pullies are not turning
Do the shafts spin and not the pulleys? if so you need to replace the shear pins. If nothing works are there belts that drive fron the PTO could be a broken belt.
How to adjust the valves on a la175
that is a lawn mower number, not the engine. But if it's a John Deere LA175 and it has a Briggs single cylinder you need to adjust them to .004 ~ .006. As for how to do it. You need a manual because I am not typing all of that up
Sep 10, 2014 | John Deere Garden
Rebuild steering on john deere L120
Hi there, I am not familliar with the L120 specifically, and suggest that you go to: "John Deere Lawn Mower Manuals" online and select your model from there. In my experience with this type of unit there are two ways that the pressed gear on the end of the shaft is fitted.. Real engineers make a ferrule, usually about twice the diameter of the steering shaft, and have either a tapered end with a threadded end for a nut which often has a split pin thru the thread like a trailer wheel bearing, and a key in the shaft and taper. Machines made with a lesser labour input often have a fixed pinion which means replacing both the shaft and the pinion. If it is the tapered end with a nut, they are often very tight and cannot be removed while mounted in the machine. They may require a sharp heat and severe blow with a good hammer. I do not recommend that you do this if you are not competent as the blow to the nut can do much damage if not hit square with a cushion of copper between the hammer and nut. The fact that you do not know how to do this job probably means that it is cost effective to employ a shop which does this type of work.
Aug 19, 2014 | John Deere L100 Series
Replacing Drive Belt on John Deere La175
if the manual says it will slide off then it will but if it doesn't then it is probably rusted on or corroded on. It may be necessary to use a puller or press to achieve the desired result. I suggest you talk to a dealer mechanic to clarify that there is not a shear pin you have to remove first.
Jun 11, 2013 | John Deere Garden
John deere la175 54 belt diagram
Here is my diagram for a LA175 (series 100) 54 inch deck.
May 31, 2012 | Garden
La175 54 inch deck
Here is a belt diagram that I drew for a Deere LA175 (100 Series) 54 inch deck.
Apr 21, 2012 | John Deere 22HP VTwin 48" Riding Mower
Garden Logo
115 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
