Question about Garden
How do you get the string to come out of the spool whilst the snipper is in use ?
It is an elctrolux electric snipper
    Novelist:
    Filmmaker:
    Uploaded 5 video answers.
  • 161 Answers
There are two or more types,
1: provided the spool is full and wound on correctly, to increase the length of nylon you tap the head of the snipper on the ground while it's spinning. This should release extra cutting string.
2: others are simply feed by the centrifugal force governed by a spring in the head. When you wrap the nylon string around the spool, then feed the nylon out the holes provided, the weight of the nylon string pulls the required amount of nylon out so you can continue to work.
Others are manual, simply pull the nylon out by hand to the desired length.
Note that you are only cutting with the very tip of the nylon string, not the full length.
Posted on Mar 29, 2015
How to replace the spool head
Once you remove the spool cap and the spool, you cannot remove the head from the motor. It is not a replacement part.
Ryobi P2002 Cordless String Trimmer Parts
Aug 31, 2014 | Ryobi Lithium Ion 18 Volt 18v Cordless...
Cutting string is stuck inside head
The head will have to be pulled off by taking the nut off of the bottom and then take the spool off and resting the spool. If the string is new it may be the wrong size string.
Jun 04, 2011 | Ryobi 15" Electric Factory Reconditioned...
Gettin spool off to change string
1.Twist the cap off counterclockwise.
2. Remove the cap and spool.
Note: If the spring falls off, install it before installing the spool.
3. Thoroughly clean the cutting head and cap and inspect them for anydamaged or worn parts.
May 29, 2011 | Toro& Electric String Trimmer
I have an electric 13"
you can try a smaller string size, this should help. Tim
Apr 24, 2011 | Toro& Electric String Trimmer
How to fix my Ryobi Wipper Snipper - Model# RLT30CD? Hi, I having been using the bump feed and all of sudden its not bump feeding. What should i do about fixing this up? Cheers Clint Baird
You may have dirt in the spool, keeping the line from feeding. Or, the string is slightly tangled on the spool, not allowing it to feed properly.
Jim
Nov 26, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
My tele tuners have a slot in the tuners. I am
Usually you have either loops or little metal spools in loops at the end of the strings. The little spools are put down into the slots to secure the strings. If your old strings have the spools, you can remove them and put into your new strings.
Sep 29, 2009 | Fender '72 Tele Deluxe Electric Guitar
Cannot get spool out of Poulin Weedeater Lite
There should be a round knob at the bottom of the spool where the string is. Twist off counter clockwise and the spool of string will drop off.
Jim
Jun 27, 2009 | Poulan Garden
Describe string replacement on ryobi trimer
Wind the string on in a clockwise direction.
If it is a duel line then: Cut two separate pieces of string, about 7 ft. each.
Stick the end of the line in the hole on the inside of spool.
Wind clockwise onto spool, putting the line that is closest to the ground on first.
Once you have winded this piece on, lock the last 4 inches of line through the slits on spool.
Repeat process for second piece of line, locking the last 4 inches in slot opposite the other locked in piece.
Put the spool on the trimmer, feeding the end of lines through either hole on trimmer.
Before you push the spool all the way on, pull the strings out of the locked position.
Jim
Jun 24, 2009 | Ryobi 15" Electric Factory Reconditioned...
Cannot Open Spool Compartment
Jim
Jun 18, 2009 | Toro 15" Electric Trimmer&Edger
Cannot undo the string compartment to put new string in. There may still be string in the compartment but I cannot get into it. This is a 12 inch Toro electric wacker.
There sould be a knob that turns counterclockwise to take spool off. If not there sould be two taps that push in and pull down on what they call the spool head. Hopefully this will help you.
May 14, 2009 | Toro& Electric String Trimmer
Garden Logo
85 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
