Question about Water Water Heaters
How do I get rid of the particles in the water?
I see small particles, almost like flakes, in the water output only from the hot water faucet. The dispenser is probably 4-5 years old and yes, we have hard water.
  • 682 Answers
This is the build up of calcium on the heating element that is now breaking off.if you turn off the heater and water you can drain and replace the element which is a small step to cure this .long term you would need to consider new tank or even go to installing soft water unit as the problem shortens the life of all devices like taps shower heads washing machines dishwashers within you system.
Posted on Mar 29, 2015
    Top Expert:
  • Water Master
  • 43,064 Answers
Are they white particles sounds like you need a new inlet (DIP)tube perhaps call a plumber
Hot Water Pressure from taps
Hard water deposits from the water heater in the supply lines to the faucets. Sounds like your water heater needs to be cleaned out -- not just drained of water. You need to get inside and clear out the deposits in the bottom of the tank. You also need to remove the hot water supply lines to your faucets and see of you can get the lines to run free from the deposits -AFTER you clean out the water heater. Remove the drain -put on a 3/4 in. ball valve for the drain and a hose bibb on that - you can hook up a 5/8 - or 3/4 inch hose to get the particles out of the drain of the water tank. You may have to blow back the water line, from the faucets, the hot water lines- to get the deposits out of the water lines. You also may have to blow out the faucets with the water line disconnected to clear the calcium out of the hot side of the faucet.
Feb 18, 2014 | Water Heaters
Heater takes more than 1 minute to get water to kit faucet , then temp fluctuates
1) Guesses: Sounds like a bad single-handled faucet cartridge, or low water flow at faucet, or clogged water filter.
Replace faucet cartridge, clean the aerator, and/or clean sediment out of pipes below sink, and clean water filter at tankless unit each month.
2) For exact measure of problem:
Typical faucet can have 2 gallon per minute flow rate.
2 gpm flow rate means faucet fills 1 gallon container in 30 seconds. Test faucet using 1 gallon container and a cooking timer to get flow rate.
Clean aerator to improve flow rate. Compare kitchen flow rate with other faucets in home.
http://waterheatertimer.org/Low-hot-water-pressure.html
Most homes have 1/2" diameter pipe running to kitchen faucet.
100 feet of 1/2" diameter pipe holds 1.2 gallons of water. This assumes no sediment build-up inside pipes.
http://waterheatertimer.org/Water-heater-recirculation-system.html
Assuming only hot is turned on: If faucet is 100 feet away from water heater, and pipe diameter is unobstructed 1/2" diameter, and faucet has 2 gallon per minute water flow, then hot water should arrive in 36 seconds.
50 feet away, and hot water should arrive in 18 seconds.
If kitchen has single handled faucet, and the handle is raised in the middle, then equal amounts of hot and cold water are drawn at same time. This doubles amount of time for hot water to arrive.
If single handle faucet has a bad cartridge, then faucet can have crossover.
Crossover means that cold water can enter the faucet even if faucet is turned to hot.
Bad single-handled faucet cartridge can delay or stop the arrival of hot water.
http://waterheatertimer.org/Crossover.html
Tankless require maintenance including cleaning combustion parts yearly, de-lime heat exchanger frequently, and clean water filter each month.
http://waterheatertimer.org/pdf/Tankless-maintenance.pdf
http://waterheatertimer.org/pdf/Bosch_Overcoming_fluctuating_temps.pdf
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Add a comment for more help.
Take a moment and rate answer for accuracy:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 15, 2011 | Rheem Direct Vent Natural Gas Tankless...
Black flakes come out when the hot water side of the faucet is used
These black flakes must be in your line or your expansion tank. Remove the filter from your faucet, temporarily, and let just the hot water side run until the water comes out clean. You must flush these black flakes out.
Jan 31, 2011 | Amtrol ST-5-C THERM-X-TROL ASME Expansion...
I am losing water pressure, but only on the hot side. Cold pressure is fine, as you add hot the pressure fades, the hotter the less pressure. This is at all points in the house. The water heater was...
You have a clog in the hot water line.
If problem is at one faucet, then remove aerator and clean, then disassemble lines underneath sink.
If problem is at every faucet, then that moves search close to water heater.
Look at hot water line that exits water heater and trace that line to first Tee.
Look at cold water line that enters water heater and trace that line to Tee.
Clog is located between those 2 Tees.
Buy pressure tester that connects to hose thread.
Connect pressure gauge to hot water heater drain valve.
Then conduct same test you did at faucet.
See if pressure drops at tank.
If pressure drops, then clog is on cold side of tank, and probably hot side too.
If pressure does not drop, then clog is on hot side of tank.
Suspect 1 is any place two different metals join. For example galvanized pipe and copper.
Suspect 2 is supply pipes that exit top of tank. Take apart and look inside pipes for corrosion and sediment lining pipe walls.
Suspect 3 is elbow. Disassemble pipes and look for sediment and flakes of rust.
Suspect 4 is all suspects above, each having sediment and corrosion.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on water heater or any do-it-yourself project.
Jan 19, 2011 | Rheem 50 Gallon FVR NATGAS Water Heater...
We still have hot water, but it runs out quickly. This problem started a few months ago.
One of your elements is most likely burned out
I would suspect the bottom one
Check first for 220 volt power to both elements if you have power then the chances are 90% that your have a bad element
Mar 31, 2010 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
I am getting lots of brown flakes in valves
The brown flakes are most likely rust from either the tank or associated metal piping. They could also be from the anode used in hot water tanks to combat electrolysis. Does the water have a Sulphur" or "rotten egg" smell to it? Are you on a well? There shouldn't be so much, as to plug up the valves. Turn off your heat source to the hot water tank. At the bottom of the tank is a faucet. Hook a garden hose to it, run it out side where the hose lays lower than the faucet if possible and flush the tank untill you have clear water again. You may want to do this a couple of times to be sure you get rid of any sediment in the tank. When you are done flushing, make sure you have the air out of the tank by opening a hot water faucet until it runs clear with no "spurts" of air. Shut the faucet off and turn the gas back on, light the pilot light and see if the problem persists. Also have your water tested. Sears does this for free -just take a sample in and they will tell you what the hardness is.
Jan 15, 2010 | Noritz 7.1 Gpm Natural Ng Gas Tankless Hot...
I have a Reliance 501 gas hot water heater that needs a tank cleaning. Scale is showing up in faucet aerators. Is it still comon practice to delime hot water heater tanks? If so any recomendations?
hook up garden hose to faucet @ the bottom of the tank and drain the hose to the outdoors or down a floor drain and open the valve , leaving the cold supply valve on , let it run until it runs clear , this will get rid of some of the sediment deposit that form at the bottom of tank , is the most effective way i know , good luck
Dec 31, 2009 | RELIANCE ELECTRIC WATER HEATER
High pitch noise when water is turned on.
that's a faucet problem, nothing to do with the tank
either replace the faucet washer (The one that's noisy)
or get a diffeent style faucet
Aug 31, 2009 | Water Heaters
Sediment in hot water
With Rheem you have to back to the installer.Most of the heater have ten year warrany.
Mar 15, 2009 | Rheem 40 Gallon FVR NATGAS Low WATER...
Water is either hot or cold - no in between.
I found a way to get warm water in the shower, but I'm not sure it qualifies as a solution. After trying everything else I thought that maybe when I was feathering the faucet in the shower toward the cold side so I would get warm water that at a certain point it blocked the flow on the hot water side enough so that the sensor in the hot water heater sensed there was no demand in the line and it shut the water heater off. To test this, I went to the kitchen and turned the kitchen sink faucet all the way to the hot side and then turned it on so that I got a small flow of water. I waited for the water to get hot to be sure the hot water heater was working. Once it was hot, I left it running to keep demand in the line and then I went to the shower and turned the faucet on. When the water got hot I started feathering the control towards the cold side and soon I had warm water. So I think I'm right in that the sensor in the hot water heater was shutting the water heater off when the demand in the shower was lowered to a certain point when I was trying to adjust the water temp in the shower.
So now I can get warm water, but it means I have to leave the hot water running at another fixture in the house to create a false demand in the system so the hot water heater doesn't shut down. Is there a way to adjust the senor in the hot water heater so that it will stay on when I'm using the shower only, so I don't have to waste water by running another faucet when I want to take a shower?
Nov 28, 2008 | Water Heaters
Water Heaters Logo
66 people viewed this question
Top Water Heaters Experts
freddyfox
Kenneth Walker
Are you a Water Heater Expert? Answer questions, earn points and help others
