Question about DeLonghi Magnifica Coffee Makers & Espresso Machines
Coffee rounds falling inside machine after completing cycle
Ground coffee is falling inside of the machine after completing cycle for auto cappacino . It seems like the compressed coffee is sticking to the press when diffuser returns
    Habit-Forming:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 154 Answers
Give machine good sevice
Posted on Mar 31, 2016
  • 74 Answers
SOURCE: Instructions
http://www.coffeecrew.com/content/view/186/27/
http://www.coffeecrew.com/content/view/187/27/
found these two links right here on Fixya.
Sry to say it seems that most people that have actually got a manual is from Salton.
Email them and they will send you a .pdf of the manual.
info@salton.com
Posted on Jul 18, 2008
SOURCE: "Fill System/Press Steam"
Remove the tray at the front of the machine. Look inside and you will see a rubber flap which separates the right and left side of the machine. Gently lift this to the right and look inside to the left (a small mirror like from a womans compact and a flashlight will help you see in there.) You will find a small circular screen (about the size of a half dollar.)  You need to wipe ALL the coffee grinds off of this screen. That should fix the problem. If you use dark beans, you are probably grinding them to fine and some of the oily residue is sticking to this screen. Try grinding the dark beans more coarsely. Only change the grinder WHEN IT IS GRINDING by adjusting the litlle knob in the box where you place the beans. If the problem started just after changing the filter you may have air in the water line and it needs to be flushed. Try running the tea portion hot water until it clears. These suggestions were given to me by Capresso and actually worked for my machine. Good luck. Gary
Posted on Dec 14, 2008
  • 211 Answers
SOURCE: coffee ground are coming out of the k-cup area
Make sure the needle in the bottom of the K cup holder is not missing, broken or bent. Also, look at your used K cup when it comes out. Is there a hole in the top and the bottom? It sounds like the pressure is building up within the K cup due to a backup at the bottom of it. This could also occur if the bottom needle hole is obstructed. Be careful...the needles are sharp!
Posted on May 28, 2009
  • 20 Answers
SOURCE: coffee leaks out the bottom of the machine
The black tube that is protruding from the coffee machine is broken or leaking.If you pull out the brewunit,, you may find the broken piece stuck inside of brewunit.
Posted on Dec 16, 2009
espressonist
  • 1711 Answers
SOURCE: Water (coffee) does not make it out through the
Propably the vibrating water pump is the problem.
It might be full of scale and it can not create any pressure or it is completetly damage and need to be replaced.
First we sugest to perform a descaling of the machine and try again.
Second you should try to reduce by little the quantity of the grounded coffee used. Aprox you should use 7 to7.5 gr of coffee. If you try to use about 6 to 6.5 and you have the coffee runing out from the machine like in 25 sec you have about 30 cc of water. Then try to clean the group shower which it can be ansrew by one cetrer screw and if you can you can open the machine and remove to clean also the coffee group solenoid valve. Bothe the valve and shower can be full of dry coffee that can blocked the way of water coming to the grounded coffee.
If you manage to clean everything above and the machine work ok so from now on in order to avoid the problem again try to flush water from the group many times without any coffee. With this is like you wash the group shower and valve from any remai coffee.
Good luck
Posted on Mar 25, 2010
Testimonial: "Brilliant, I cleaned the shower head as you instructed and it's working perfect, thanks for the tips. Louise"
Coffee too weak what are normal knob settings
Function Knob For setting time of day, and auto on and auto off times. a. Auto On The Auto On feature is used to program the start time of the brew cycle. The auto on time can be set for any time, day or night. The “PM” indicator is displayed on the LCD for nighttime program times. b. Auto Off The Auto Off feature is used to shut off the coffeemaker at a preset time, anywhere from 0 to 4 hours. c. Program Set The Program Set function is used to set the time for the Auto On function. d. Brew The brew function is used to start the brew cycle directly. e. Clock Set Used to program the time of day. f. Audible Tone (not shown) The Brew Central™ Coffeemaker is equipped with an audible tone which will sound 5 times when the coffee has completed brewing (coffee will continue to stream from the filter for a few seconds after tone).
If yours is a Vienna Digital Coffee Maker please click the link below. it is manual of Coffee Maker, it would be helpful to in the future.. http://www.cerinicoffee.com/Saeco_User_manuals_free.asp
Jan 20, 2010 | Saeco Vienna Digital Coffee Maker,...
Does not complete the brewing cycle. Only cycles 1/3 of the water. 1-4 cup is NOT turned on.
First remove charcoal filter. Your coffee maker is clogged with hard water grime. Run 5 cups of vinegar through it twice, then follow with a couple of rounds of water to get the vinegar taste out. It will be as good as new.
Oct 04, 2009 | Cuisinart DGB-600BC 10-Cup Coffee Maker
Hello. I have a saeco vienna superautomatic
This happens due to condensation caused by steam developed at the end of the grinding cycle. Make sure that the grinding chamber is completely cleaned and dried before using the grinder.
  1. Turn the whole bean chamber to the right until it can be lifted off the base. This will allow you to clean the grinding wheel. NOTE: Never use water or liquid for cleaning the lower grinding section of this appliance.
  2. Clean interior recesses with a soft brush (not provided).
  3. Wash the whole bean chamber and lid and the ground coffee chamber and lid in mild detergent and water. These items are only dishwasher safe on the top rack of your dishwasher. Wipe exterior with a damp cloth. Do not immerse mill in water or any other liquid or place in dishwasher. Use only non-abrasive cleaners to remove stains.
  4. After completely drying, replace whole bean chamber. Important: when replacing whole bean chamber, screw on completely before setting grinding rate. Turn chamber clockwise (as viewed from top), until it will not turn. Fill with whole coffee beans for grinding and replace lid.
  5. Replace ground coffee chamber and lid, making sure it snaps securely into place.
Aug 02, 2009 | Saeco Vienna De Luxe Espresso Machine
No milk,or steam coming from cappucinno nozzle
If you pull the cappacino component off. The black plastic thing at the end of the metal tube (where the cappacino component's attached to) can be unscrewed by rotating it with your hand. You can clean it with a brush and a thick needle to clean the hole the make sure that it's not blocked. After that just screw it back on and reattach the cappacino component.
Dec 16, 2008 | Jura Capresso Impressa Z5 Espresso/Coffee...
No coffee will dispenses
How fine have you got you grind setting, if it is a new machine it needs to be on course Grind, fine grinds clog the filter.  You need to reach into where the tray goes with a cloth and wipe clean the filter bin which is right behind a flap
Nov 02, 2008 | Jura Capresso Impressa Z5 Espresso/Coffee...
Instructions
info@salton.com
Jul 18, 2008 | Salton EX20 Coffee Maker, Espresso Machine
Bypass doser malfunctions
Happens when the preground coffee is not ground fine enough, you may have to put the pre ground coffee in a manual coffee grinder to make it finer. The machine is not really designed to brew regular coffee grounds.
Jan 20, 2008 | Saeco Magic De Luxe Espresso Machine
Coffee Makers & Espresso Machines Logo
79 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
