Question about Refrigerators
Nw house to us today. Fridge not going below 46. How to change to he proper temp?
  • Refrigerators Master
  • 5,323 Answers
REMEMBER GOD IS THE REASON FOR GOOD ADVICE"
FREEZER /FRIDGE NOT COOLING: Optimum refrigerator temperature at or below40° F(4° C). The freezer temperature should be0° F(-18° C). Check temperatures periodically. Appliance thermometers are the best way of knowing these
Check ur cold control thermostat, ur thermistors in both fridge and freezer ( they should be checked for both ohms and for amount of current being put out as per ur model ), ur air flow vent from freezer to fridge.( to make sure it opens and closes without any restrictions) On thermistors check for A close circuit and amount of ohms not just an Ohm reading. As per ur model. Most should atleast show 1200 ohms. Also Check door seals for leakage.
Evaporator coils
Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.
If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited.
FAN check to see if it is operating or restricted A fan that is not blowing or restricted will not circulate the cold air properly.
Often, the first thing that folks do when their refrigerator starts to feel warm is turn both controls on the coldest settings.This is exactly the WRONG thing to do.Turning the cold control to the coldest settingwillkeep the compressor running longer and make lots of cold air.
But turning the air door to the coldest settingclosesthe airway to the food section. Lots of cold air is made, but most of it stays in the freezer section, and the food section actually getswarmer.
Condenser
Self-defrosting refrigerators all have a set of coils and a cooling fan, usually under the refrigerator, that need to be cleaned regularly. If these coils get coated with dust, dirt or lint, the refrigerator may not cool properly. The coils may appear to be a thin, black, wide radiator-like device behind the lower kick-panel. To clean them, disconnect the refrigerator from the power source, use a refrigerator condenser brush and your vacuum cleaner to clean the coils of any lint, pet hair, etc. You may not be able to get to all of the condenser from the front, it may be necessary to clean the remainder of the condenser from the rear of the refrigerator.
May also need to check the defrost timer, u can get by and test manually by placing a small screw driver into the tiny slot or hole underneath the timer and turn slowly clockwise till u hear 1 click. this will engage ur defrost cycle in about 15 minutes u should be able to come back and feel the heat in freezer as it melts the ice providing ur terminator is not bad?
Another way to test it is with a multi meter. Remove timer it from fridge and you will see 4 prongs numbered 2,1,4,3 in that order. Place ur meter prong on prong 1 & 3 (if your fridge has a capacitor wired in series with the windings, then u check for micro fares rather than OHMS) If u cannot confirm this test, still try the next.
Take ur meter prong and connect to prong 1 & 4, it should read resistance or ohms ( closed) now remove prongs and place on prong 1 & 2, this should now read infinity or open (no ohms) now take a small screwdriver place it in the tiny hole or slot under the timer. Turn it clockwise slowly till u hear 1 click. Now ur 1& 2 should read closed ( showing ohms or resistance) now place meter prongs on 1 & 4 and you it should now show open ( or no resistance - no ohms) this is how u know ur timer is good, Remember when testing for ohms ADJUST meter to use a high ohms rating in the thousands as the resistance is very high in OHMS. And adjusting to low ohms rating may give a false reading or not show the proper resistance..
THE COMPRESSOR:
If you hear a clicking sound coming from the back of your refrigerator/freezer, then the problem is most likely the compressor, relay and or capacitor is overheating or not getting proper power and will not start.The compressor is the component on your refrigerator that allows your refrigerator to cool. If this component is not working properly your refrigerator will stop cooling. Most of the time the compressor is not the component that has failed.
To check ur compressor with multi meter:
Disconnect and remove the relay and capacitor from compressor, some located next to compressor in a casing.
You wills see 3 prongs coming out of compressor. 1 goes to ur srtart winding, 1 goes to ur run winding and the center goes to ur ground.
Place ur meter connector or prong on the start prong and the other on the ground (center prong) take note of the reading in OHMS for example 5 ohms.
Next place meter prong on run prong and the center ground prong agin. Take note of the reading in OHMS. Example 4 ohms
Next place meter prong on the start prong and the other on the run prong, now take note of the reading example 9 ohms. Now match the total of this ohms test with the total of ur two separate test. 9 ohms, if they match ur ok give or take 5 percent plus or minus. One more test to make to test of there is a short in compressor attach meter prong to ground prong and rub the other end of meter prong to metal ( scrape the metal clean of paint and test on metal surface not painted surface. If it shows continuity or ohms , u have a short in ur compressor. It should show infinity
Lastly you should also check ur THERMISTORS in the freezer and fridge section for continuity OHMS and for amount of OHMS current being put out. In most models around 13000 ( give or take 150 ohms) ohms is required.
Read more:http://removeandreplace.com/2013/10/31/fix-refrigerator-freezer-wont-cool-freeze/#ixzz3WDEo5NDJ
Posted on Apr 28, 2015
  • 279 Answers
SOURCE: Samsung RS2630H - Fridge temperature will not go below 14
The first thing to do is clean out from under and behind the refrigerator thoroughly. In over half the cases like this, I've found it's just a matter of not enough air getting to the compressor, because of dust bunnies or other things blocking the airflow. You'll need to empty it and tilt it back to clean out from under it properly. But I will be surprised if that doesn't fix your problem.
Posted on Aug 31, 2007
SOURCE: Have a 2 year old SAMSUNG RS2545SH Side by Side
Control board has gone bad....
What happens is the defrost is controlled electronically from a circuit board, when this goes bad, the freezer quits defrosting, and freezes the fans that circulate air through the fridge side of things.
To check this, unplug the entire fridge, leave the freezer open, wait for it to defrost a bit, if this causes the fridge to start cooling again when you plug it back in, then its the defrost. You should also see ice crystals on the back of the freezer just under the icemaker.
http://forums.partselect.com/refrigerator-freezer-repair/rerifgerator-side-not-below-54-degrees-6699.html
Posted on Mar 08, 2008
Sea Breeze
  • 4655 Answers
SOURCE: my samsung fridge will not go below 46 degrees
Model is? It is most likely a defrost problem. Look inside the door frame. Inside the fresh food section an there also may be a hole there that has plastic plug to hide opening. May need to drop the cover to fresh food sections contol panel for a defrost time or Adaptive Defrost Control and behind the plastic cover on control panel. This also may be an auto damper that has frozen the damper shut. Look at the rear panel in freezer. Is there frost building up. If yes the send me the model number. Auto damper regulates the fresh food section and has thermostat probe filled with freon. If you still need my help please let me know, Sea Breeze
Posted on Jan 18, 2010
SOURCE: Hello! The power went out
if the fridge turns off and the two upper lights blink. you need to reset by holding the two two buttons down for several seconds until it resets if that doesnt work... open your refrigerator door look where the temp setting controll is. if you look under the temp setting a lot of refrigerators will have a hole you really have to look for it its about the size of a dime and inside there you can see the defrost timer. some of them have an extruding peice of plastic you can turn you have to stick a flathead screw driver to reach it but turn it until the compressor kicks on. if you make a full rotation and nothing happens you need to start the diagnoses. if your familiar with and own an electrical meter i can tell you how to do this also Check the breaker first, and then there could be a relay switch on the refrigerator that was blown by the power surge. Most of the time, they recommend that you unplug the refrig whenever the power goes off, and then DO NOT open the door unless absolutely necessary. I'd go to the breaker box, find the one for the refrigerator, and then turn it off and back on after a few seconds. If that doesn't work, call a repairman and get them to check the relay switch. regards Iversh
Posted on Feb 12, 2010
wwga
  • 106 Answers
SOURCE: Samsung RS267LA won't go below 46 degrees
not capible.
Posted on Mar 21, 2012
My Viking professional refrigerator is stuck on 46 degrees refrigerator/ 6 degrees freezer. None of the buttons work. Is there a reset button?
press display on or (activate control) button first you should then be able to choose fridge or freezer and change set temp
after set will read actual temp 46 is a little high sounds like you have service issue
Jun 27, 2017 | Viking Refrigerators
Model #FGHC2331PF frigidaire. Controls were set for 35F fridge and 0F freezer, but when the fridge stopped the temps went up. They are now at 40F fridge and 5F freezer. Why?
Because nothing is perfect. As soon as the compressor stops running, the refrigerator will start to get warmer as the ambient temperatures will affect it. Then after a few degrees of temp rise, if thermostat is working properly, unit will kick on again to lower temps to preset level. And the cycle continues.
Apr 02, 2016 | Refrigerators
Set temp to 46 deg(highest for fridge), temp ranges from 30 to 46 deg inside
Use the humidity slide control on the veggies drawer to control the amount of air entering the drawer/s...hope it helps... cheers
Jan 21, 2018 | Whirlpool Refrigerators
KBFA20ER Turns Off
Holding fridge door open allow warm air into fridge/freezer that's why temp is going up .Maybe you device have a temp cutout which in your case 46 degrees.
It is like a energy saving
Jun 01, 2017 | KitchenAid KBFA20ER Bottom Freezer French...
Model WBM412 - Freezer works but fridge does not cool at all.
Its due to freezing behind the freezer coil by which freezer fan gets logged to function. Defrost the refrigerator and then run. Keep freezer temp between -14*F and 8*F and fridge temp between 36*F and 46* F. And also check defrost cycling is properly working.
Thanks, helpful?
Feb 26, 2011 | Whirlpool WBC3525 (12.36 cu. ft.) Bottom...
Bottom freezer model, fridge temp is @ 24 degrees, but it is set to 46 degrees.
some times the flap that controles the temp inside the fridge gets stuck or sometimes (hate to say this) parts and not installed properly or not at all I have found this to be true from alot of hhgregg stores they seem to buy defects and then replace the missing part
Dec 09, 2009 | Kenmore Refrigerators
Fridge side wont cool properly.
Check out this link below for a PDF manual on your item. Great information to have. Just copy and paste into your browser.
http://www.samsung.com/us/function/search/espsearchResult.do?keywords=RS2630SH&input_keyword=RS2630SH
Try this:
Temperature Adjustment
• After 24 hours, adjust the controls as needed. Adjust temperature gradually: push the button in small increments,
allowing the temperature to stabilize.
• Press the button(Freezer Temp or Fridge Temp) repeatedly until the desired set temper.
• For lower temperature, press the button(Freezer Temp or Fridge Temp) towards coldest.
• For higher temperature, press the button(Freezer Temp or Fridge Temp) towards cold.
If this does not work for you let me know or you can contact Samsung support at 1-800-SAMSUNG (1-800-726-7864) Mon - Sun : 9am - 9pm (EST).
Or you can try this Live chat at this link below, just look to the middle left of their page for live chat:
http://www.samsung.com/us/info/contactus.html
Let me know how this works for you or if I can help you with anything else.
JimmyC
Oct 06, 2009 | Samsung RS2630SH Side by Side Refrigerator
Temp inside fridge is 46degrees. Besides
46 degrees is still below normal room temperature so it seems that the unit is cooling....you do not mention whether it is 46 degrees in both the freezer and the food compartments.....if the freezer is still cold...say below freezing or near zero but it is hot (46) in the other part of the refrigerator then there are probably 2 possibilities:
1. The small fan inside the freezer may be stuck and not spinning...they seem to go bad or at least stop spinning regularly on many freezer compartments. For most designs the fan must be running to circulate the cold air inside the freezer and also send some of the cold air over to the normal food compartment. When these fans shaft get stuck they will often emit a high pitched noise if they are able to turn at all. Of course if not turning t all then there is no sound. Determine if the fan is working....if not you will probably need to replace it and problem fixed. If the fan is working then look at the design of the plastic leavers etc inside the unit that control baffles between the freezer and food compartments. It may be a simple matter of sliding one of these controls to make it colder where the food is stored. some of them also have an electronic control for this so look for that knob and turn it to colder...not the actual refrigerator thermostat but one that controls what they call "balance" between the freezer and food areas.
Aug 21, 2009 | GE Refrigerators
Refrigerators Logo
53 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
