Question about Garden
What is the fuel mixture please? - Garden
    Top Expert:
  • Garden Master
  • 52,047 Answers
No make no model sorry wild guess is 40-1
Posted on Mar 29, 2015
1999 Yamaha YZF-R1 air-fuel mixture setting
Hi, John it should be noted that the "AIR FUEL" mixture screw adjustment "ONLY" manages your idle and has no effect on any other circuit also any intake leaks must be repaired before the A/F adjustment procedure can be performed otherwise you will never obtain a proper idle and you will waste a lot of time chasing the impossible. The A/F mixture screw's purpose is to fine tune the fuel charge entering the combustion chamber. The following applies to both 2 and 4 stroke engines:
1. The mixture screw may be sealed at the factory with a Welch Plug please review the following video for removal.
https://www.youtube.com/watch?v=wAXcksgvDkM
2. The mixture screw manages a range of 3 complete 360-degree counterclockwise turns from the bottom/closed position.
3. The mixture screw should have a spring and o-ring for tension and sealing integrity.
4. Turn the mixture screw clockwise until it gently bottoms out, this makes the fuel charge very lean and the engine should not idle if it does then the pilot/idle jet is too big and needs to be replaced with the next size smaller.
5. Turn the mixture screw 1 and 1/2 turns counterclockwise to establish a baseline for starting the engine.
6. To fine-tune the idle circuit, adjust the mixture screw 1/4 turn in or out to achieve maximum idle RPM, wait 15 seconds between each adjustment for the idle to settle.
7. Never go past 3 full turns out this will make the fuel charge rich, foul plugs, and produce black smoke out of the exhaust, if the engine RPM keeps increasing past 3 turns the pilot/idle jet is too small and needs to be replaced with the next size larger.
8. After achieving maximum idle back out the mixture screw another 1/8 of a turn then adjust the throttle cable idle stop screw to 950-1050 RPM.
9. This procedure works great on 99% of all engines, for the 1% that demand a more robust throttle response on aftermarket monster fuel delivery systems additional tweaking outside the box may be necessary.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Stock 98 99 R1 fuel mix screw settings
R6 Carburetor Fuel Mixture Adjustment
1998 1999 Yamaha YZF R1 Service Manual R1 Moto Data Project
https://www.partsfish.com/page/oem-parts-for-yamaha
2001 Yamaha YZF R1 Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Jun 16, 2018 | 2000 Yamaha YZF-R1
1992 Honda CBR 600 F2 air-fuel mixture adjustment
Hi, Chad it should be noted that the "AIR FUEL" mixture screw adjustment "ONLY" manages your idle and has no effect on any other circuit also any intake leaks must be repaired before the A/F adjustment procedure can be performed otherwise you will never obtain a proper idle and you will waste a lot of time chasing the impossible. The A/F mixture screw's purpose is to fine tune the fuel charge entering the combustion chamber. The following applies to both 2 and 4 stroke engines:
CBR 600 f2 air fuel screw adjustment Biker ie Forums
Air fuel mixture screw question CBR Forum Enthusiast forums for Honda CBR...
1991 1994 CBR600 F2 Service Repair Manual Download Download Manuals... $15
https://www.partsfish.com/page/oem-parts-for-honda
Honda CBR600F Owner Manual Page 3
May 15, 2018 | 1989 Honda CBR 600 F Hurricane
Fuel mixture cbr600fs
Hi, Anonymous it should be noted that the "AIR FUEL" mixture screw adjustment "ONLY" manages your idle and has no effect on any other circuit also any intake leaks must be repaired before the A/F adjustment procedure can be performed otherwise you will never obtain a proper idle and you will waste a lot of time chasing the impossible. The A/F mixture screw's purpose is to fine tune the fuel charge entering the combustion chamber. The following applies to both 2 and 4 stroke engines:
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
99 Honda CBR 900rr carburetor removal and air fuel adjustment
Honda CBR600F4I 2001 Service Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda CBR600F4i Owner Manual
Mar 29, 2014 | 1992 Honda CBR 600 F(2)N
2005 Honda Activa air-fuel mixture adjustment
Adjusting air fuel mixture screw
Honda Activa Fuel Mixture screw Actual Adjustment and RPM Adjustment
http://www.family-motorsports.net/GY6-50cc-150cc.pdf
Honda activa 2009 Owner Manual
Feb 14, 2014 | 2005 Honda Activa
Adjust air fuel mixture
Fuel Mixture Screw
Basic how to on air fuel adjustment on 1300 VTX
Honda VTX1300S Service Manual
Honda VTX1300C VTX 2004 Owner Manual
Jun 01, 2013 | 2003 Honda VTX 1300 Retro
2009 Honda CRF450X how to adjust fuel mixture
Throttle Response Fuel Screw adjustments
How To 4 Stroke MX Fuel Screw Adjustment YZF CRF KXF RMZ FCR Part 1 of 2
Honda CRF450X 2005 Service Manual
Honda 2009 CRF450X Owner Manual Competition Handbook
Mar 08, 2013 | 2009 Honda CRF450R
How to adjust air and fuel mixtures of Honda XRM 125
How to adjust AIR Fuel Mixture on CARb
Honda125 stock carburator tuning
http://www.artsoul-gallery.com/honda_xrm_125_service_manual_download.pdf
Honda xrm 125 operation manual
Mar 05, 2013 | Honda Motorcycles
1979 Honda CX 500 B air/fuel mixture adjustment
Hi, Dan it should be noted that the "AIR FUEL" mixture screw adjustment "ONLY" manages your idle and has no effect on any other circuit also any intake leaks must be repaired before the A/F adjustment procedure can be performed otherwise you will never obtain a proper idle and you will waste a lot of time chasing the impossible. The A/F mixture screw's purpose is to fine tune the fuel charge entering the combustion chamber. The following applies to both 2 and 4 stroke engines:
Mixture adjustment
cx500 carb balancing part 1
Honda CX500 Shop Manual
Honda CX500 CUSTOM Owner Manual
Apr 04, 2012 | 1979 Honda CX 500 B
2001 Honda VT 600 C Shadow air-fuel mixture setting
Hi, Richardyance it should be noted that the "AIR FUEL" mixture screw adjustment "ONLY" manages your idle and has no effect on any other circuit also any intake leaks must be repaired before the A/F adjustment procedure can be performed otherwise you will never obtain a proper idle and you will waste a lot of time chasing the impossible. The A/F mixture screw's purpose is to fine tune the fuel charge entering the combustion chamber. The following applies to both 2 and 4 stroke engines:
idle screw air fuel mix
VT1100 Mixture Screw Location
Honda VT600C Shadow VLX Service Manual
Honda VT600C Owner Manual
Jul 14, 2011 | 2001 Honda VT 600 C Shadow
2007 Honda VTX1300C air/fuel mixture adjustment
Hi, Bill_fiaccon it should be noted that the "AIR FUEL" mixture screw adjustment "ONLY" manages your idle and has no effect on any other circuit also any intake leaks must be repaired before the A/F adjustment procedure can be performed otherwise you will never obtain a proper idle and you will waste a lot of time chasing the impossible. The A/F mixture screw's purpose is to fine tune the fuel charge entering the combustion chamber. The following applies to both 2 and 4 stroke engines:
Fuel Mixture Screw
Honda 2007 VTX1300S Owner Manual
Feb 03, 2011 | 2007 Honda VTX1300C
Garden Logo
103 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
