Question about Samsung Dishwashers
Error message as 9e - low water. Because the water was not going into dishwasher - was leaking at bottom of dishwasher to the floor below. We did what manual suggested - but didn't clear the problem. When we turned it on again, it leaked again - lots out of bottom of dishwasher. No repair man will come to fix it? Say Samsung are the worst.? Can we fix it ourselves? Perhaps its just a seal or something?
  • 116 Answers
SOURCE: Leaking water on floor during drain cycle
First the source of the leak needs to be identified. pull the machine out from under the counter and remove the left side panel exposing the blue float assembly. Turn the machine on and observe the fill cycle. if water comes out anywhere on the fill mechanism then the inlet valve needs to be replaced. once the machine has filled and begun to cycle cancel the program and drain the unit. observe closly where the leak is happening. a leak during drain usually indicated a leaking drain hose.
Posted on Mar 11, 2007
skrbin
  • 121 Answers
SOURCE: leaking lower door seal on kitchenaid dishwasher model KUDM25SHWH
check door hinge.
Posted on Feb 15, 2009
SOURCE: How can I fix my Fisher and Paykel DD 6031 Dishwasher? its leaking
I have Fisher & Paykle DW DD603-SS (5Y old)
The upper drawr started to leak H2O out and in to the bothom drawr???
What is the problem and also please what is the solution?
Thanks, JB
Posted on Mar 13, 2009
SOURCE: dishwasher leaking around the bottom of the door
I had the same problem in 2004, lots of Bosch trained repair techs, calls to Bosch, and the appliance dealer we purchased it from with no answers. Our kitchen cabinet bases were ruined by the flooding that occured. After months of trying to get help I insisted on speaking to a supervisor that told me it was my fault for putting a flexible cutting board on the right side a blocking the vent. I told her that no where in the manual did it mention this issue and none of their trained techs were aware of this flaw in their design. When I asked about getting my cabinets repaired she said that was not an option. When I mentioned possible legal action her response was "good luck with that". Here it is 2009 and they recently called about a possible fire hazard recall for the control panel. The Bosch trained tech that came out to complete the repair knew nothing about the vent/flooding issue.
Posted on Aug 06, 2009
SOURCE: My Samsung DMR57 Dishwasher gives me error code
Our unit started displaying code 9E after filling, draining and filling again. At the beginning it was enough just to restart it. Finally this trick didn't work anymore. Before calling service for out of warranty I decided to take the unit out of the cabinet and start it. Of course this didn't fixed the problem. Then i noticed where the water comes in and I took off the panel on the left side bottom. 366571e.jpg
Under the panel there is a white box that has a floater inside. The floater is pushing a lever that actuates a micro switch. I noticed that the lever wasn't moving as the machine started to fill in with water. The lever was stuck. An easy touch on the lever fixed the problem and the machine started working. 677e4ea.jpg
I will put back the washer for now but if it happens again in the next future i'll have to find a more permanent fix.
Posted on Sep 21, 2010
Dishwasher starts and then stops with 9E flashing in window.
The 9E issue indicates a low water level in the dishwasher. Check your hoses. Make sure that no dishes flipped and filled with water. Make sure that the dishwasher is level. Next check if there is any debris blocking the water level (overflow) sensor. It's in a small square plastic box on the left side of the dishwasher. Pull the dishwasher forward and check for loose or damaged wires to the water level sensor.
If the wiring is good and the error persists, replace the sensor. Replace the wiring if it is damaged. If you add a comment with the model number, I may be able to point you to the replacement part. If your dishwasher is under warranty, contact Samsung for the repair.
I hope this helps.
Jul 04, 2016 | Samsung Dishwashers
Door on diswahser not shut completely during cycle. water leaked out onto floor. now flashing LE and cannot power off or on.
Good picture! The LE message indicates a leak, but besides leaking on your floor, apparently some water has gotten into the base and triggered the water-leak sensor. Basically, that water must all be sopped out dried out, then the message will go away by itself. You will probably have to pull the dishwasher out to be able to get to the water in the base.
Feb 05, 2015 | Samsung Dishwashers
I have a 3 year old Samsung DMT800RFS dishwasher. It had a 9E error, so we changed the part on the side and replaced the interior gasket. Now we get a oE error and I can not enter Service Mode to re
I don't know if this is the same. However, on my washing machine I had to clear out the water trap at the bottom of the machine. I know I have to clean it out every 6 months to be on the safe side. This also helps the machine to not smell like old stagnate water and helps your clothing smell fresher with not having that water build up and sit. I found all strange things in all kinds of water overflow tubs.
Dec 20, 2014 | Samsung Dishwashers
9E error code on dmt800rhs dishwasher
I also had the 9E error code on my Samsung dishwasher DMT800RHS mmodel. I had to call Samsung and the nearest authorized Samsung service representative came to my house last Tuesday, January 29, 2013. The cost of the call is $100 which really annoyed me off considering the dishwasher is only 1 1/2 years old. Two South Korean guys showed up and to fix the problem just press down on the Heavy, Delicate and Power button at the same time for a few seconds and a menu will appear on the top left hand corner of the panel. Scroll down the menu by pressing the Normal button until you reach "FT" and the dishwasher will automatically fill up and then autimatically drain. If it does not drain then scroll down to "S" and the dishwasher will drain. Thsi should get rid of the 9E error message and your dishwasher will work fine but if not you have to repeat the procedure maybe 2 or 3 times until the 9E error message disappears. If you constantly get the 9E error message then you may need to replace the part which is about $60. The part is extremely sensitive to either hard water or food particles which is why the 9E error message appears. Therefore, scrape your dishes thoroughly so the food particles are minimized and the sensor does not go off which causes the 9E error message.
Nov 21, 2012 | Samsung DMT800RHS Semi-Integrated...
Logik dishwasher E4 error message
I am having difficulty with my logik slimline dishwasher. E4 message about 30 minutes into cycle. Where the salt goes is always full of water. Please can someone help me
Nov 17, 2012 | Dishwashers
We have a samsung dmr77xxx dishwasher and it keeps getting a 9E error and stopping> what is causing this error? thank you
Most 9E error codes are caused by a sticky float located on the LHS of the dishwasher. You can sometimes do a temporary 'fix' by 'thumping' the left panel inside the dishwasher (towards the bottom).
Aug 23, 2011 | Samsung DMR77LHS Tall Tub Dishwasher
Samsung DMR77LHS Tall Tub Dishwasher displays HE code (flashing) and does not finish the cycle. I am very handy and would like to repair this myself. so as much detail as possible is appreciated.
EE1/HE/HE1
  • The EE and HE codes refer to temperature errors. The EE1 designation refers to a thermistor issue, and the HE codes refer to heater problems. These are all functional errors that require a certified service technician, but disconnecting the circuit breaker in the meantime can prevent the problem from growing worse.
  • 4E/4E1
  • The 4E codes indicate a problem with the water supply. If you see the 4E code, make sure the water supply line is correctly attached and open and not frozen or clogged. If you get a 4E1 code, check the temperature of the incoming water supply and ensure that it is below 176 degrees. If either of these issues persist despite your best efforts, contact a repair center.
  • 5E
  • The 5E code means there is a problem with the drain. Make sure the drain hose and openings are not clogged or obstructed. If they are not, and the code remains, disconnect the circuit breaker to reduce the risk of electric shock and contact a service center.
  • oE/9E
  • The oE and 9E codes refer to issues with the water level. The oE code means that the dishwasher is filling too much, and the 9E code means it is not filling enough. Disconnect the circuit breaker for safety and contact a repair center.
  • LE
  • The LE code indicates a leak. To keep from voiding your warranty, do not attempt to diagnose and repair the leak yourself. Close the water supply valve and disconnect the circuit breaker to avoid electric shock and contact a repair technician.
  • 6E2/PE
  • The 6E2 and PE codes both indicate functional errors that must be repaired by a professional. The 6E2 code indicates a pressed key error, and the PE code refers to a problem with the half-load function. Disconnect the circuit breaker in either case and contact a repair service.
  • Jan 14, 2011 | Samsung DMR77LHS Tall Tub Dishwasher
    My dishwasher model number dmr77lhb is showing error code le and there are no apparent external water leaks how can I rest
    I fixed mine by pulling out the unit then flipping over to access the white tray that covers the bottom of the unit. Remove this then dry it out...there's a sensor in there that triggers the LE code. It could be a leak but in most cases it's just built up condensation. EE1/HE/HE1
  • 4E/4E1
  • 5E
  • oE/9E
  • LE
  • 6E2/PE
  • Jan 10, 2011 | Samsung DMR77LHS Tall Tub Dishwasher
    AEG OKO-FAVORIT 50800
    C3 error means that there is water at the bottom of the dishwasher. Unplug the dishwasher, slide it forwards and push it back. So it stands on the 2 back knobs. Do this atleast at a anle of 45 degrees. You will see water flowing at the floor.
    If this happens often you have a leak somewhere. Time to cal the technician then.
    Mar 03, 2008 | AEG Dishwashers
    Dishwasher fix
    111
    Floor pan Leakage
    Leak inside machine activating ground float switch
    302
    At pumping out during rinse cycle level does not fall below level 1
    Drain pump faulty, blocked, aqua stop not closing completely, no signal from circuit board (connection number 6 on XA1 connection plug)
    Feb 28, 2008 | Meiko FV 40.2 Dishwasher
    Dishwashers Logo
    78 people viewed this question
    Top Samsung Dishwashers Experts
    Rod
    Rod
    Are you a Samsung Dishwasher Expert? Answer questions, earn points and help others
