Question about 1A Auto Parts 2000 Olds Intrigue Lug Nut Cap Black Set of 5 for Models with Ste
I need to know where the fuel cut off switch is located on 2000 olds intrigue
Where is the kill switch on a 1998 oldsmobile intrigue
Kill switch ? kill switch for what ? Like fords inertia fuel cut off switch ? Your vehicle does have one . Do you know how to use a wiring diagram an a DVOM - digital volt ohmmeter to test electrical circuit's ? So , you think your fuel pump isn't working ? What engine ? 3.8 L
Mar 04, 2017 | 1998 Oldsmobile Intrigue
I'm working on a 2000 olds intrigue. Lighters stopped working.. The fuses don't say anything like lighter or aux. So I looked at them all and none are blown.. Is there an in line fuse?? If so were
John, Open passenger door wide, fuse box, passenger side end of dash, under removable trim cover.
The fuse marked Cigar Ltr./Aux.Pwr. 20 amp. is the fuse you want to look at. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.autofuseboxdiagram.com/10639-2000-oldsmobile-intrigue-fuse-box-diagram
2000 olds intrigue cigar lighter fuse Google Search
Where is the fuse for your cigarette lighter located at for your 98...
Where is the fuse for your cigarette lighter located at for your 99...
May 11, 2016 | Cars & Trucks
Replace heater core
Heater Core replacement 2000 Olds Intrigue - Car Forums and ...
www.automotiveforums.com > ... > Oldsmobile > Intrigue
Jan 1, 2014 - Trying to replace the heater core in my Intrigue. I've done heater cores before- perhaps a dozen. Mostly in the late 80's. Hate the job with a ...
Heater core shortcut - YouTube
? 4:40
https://www.youtube.com/watch?v=LsZoFoiJsdw
Apr 26, 2009 - Uploaded by realfixesrealfast
A short cut for removing a heater core on a Ford Taurus. ... 04 Jeep Grand Cherokee: how to remove dashboard and replace Heater Core / AC ...
Heater Core Replacement Olds Silhouette Chevy Venture ...
? 6:18
https://www.youtube.com/watch?v=rW23CtepYWU
Sep 8, 2014 - Uploaded by Buckwsr
I walk you through replacement of the front heater core on a 2000... I just finished replacing the fuel pump and sending unit on my2000 Olds ..
Oct 09, 2015 | 2000 Oldsmobile Intrigue
BCM LOCATION 2000 OLDS INTRIGUE
It is located under the dash left side above the parking brake ! There are four wiring connectors to it !
Mar 17, 2014 | 2000 Oldsmobile Intrigue
Where is the reset fuel pump switch on a Oldsmobile Intrigue 2000?
A 2000 intrigue has no fuel pump reset switch. You probably need to replace the fuel pump.
Sep 04, 2011 | 2000 Oldsmobile Intrigue
2000 olds intrigue car starts fine and will run and drive for a few miles then car shuts off. then you can start it up and drive again for a few miles etc.
Hello and welcome to FixYa!
As a first course of action, I suggest that you have the fuel pump checked. It can be failing that's why the fuel supply cuts off. You may need a fuel pump replacement to resolve the problem.
Hope this helps and thank you for using FixYa! Have a good one!
Jul 29, 2011 | 2000 Oldsmobile Intrigue
2000 Olds Intrigue fuel gauge reads randomly incorrect
The Olds Intrigue along with several other models had issues with the sending units in the fuel tank.
the resistor board and the metal contacts wear and lose contact.
The sending unit will need to be replaced.
The fuel tank will need to be dropped in order to replace it.
May 31, 2010 | 2000 Oldsmobile Intrigue
Long crank time for 2000 olds intrigue 3.5
first thing i would do is replace your fuel filter.
with a fuel filter restriction it take longer to provide enough fuel pressure to fire.
that would be the most common but there are also may other things that could have happened but would need more information to do a process of elimination
good luck
paul
Oct 02, 2008 | 2000 Oldsmobile Intrigue
Crank position sensor location
you will need to remove the starter to gain acess to the ckp sensor. once you remove the starter look on the engine block and you will see the sensor. The only problem with doing this repair yourself is that you will not be able to preform the crankshaft position variation learn procedure with out a factory scan tool. The vehicle may crank an run, but the timing advance curves will be wrong so the vehicle will probably cut off every time you remove your foot from the gas pedal. Hope this info helps!
I’m happy to assist further over the phone at https://www.6ya.com/expert/jonathan_3a3c556b4b17d1d2
Aug 18, 2008 | 2000 Oldsmobile Intrigue
1A Auto Parts 2000 Olds Intrigue Lug Nut Cap Black Set of 5 for Models with Ste Logo
18 people viewed this question
Top 1A Auto Parts Tools & Hardware - Others Experts
Pete Bruk
Lawrence Oravetz
William Alequin
Are you a 1A Auto Parts Tool and Hardware - Other Expert? Answer questions, earn points and help others
