Question about Singer Sewing Machines
Fabric not feeding on singer model 750 - Singer Sewing Machines
  • Singer Master
  • 654 Answers
This is an old machine. However, the same problems arise with other machines:
1. Ensure the length of stitch is not zero.
2. Check the adjustment to make sure the bobbin winding is off.
3. If this doesn't work you might try moving the length adjustment back and forth several times. It could be old lubricant is stuck.
4. Take your thread off of your machine and out of the bobbin.
5. As you step on the foot control watch the feed dog. Move your length adjustment back and forth. Place a long oil tube of sewing machine oil down in that area and lubricate as well as you can.
6. Continue to monitor the feed dogs and step on the foot control.
7. If it isn't working by now you may have to take the bottom off and oil and clean the moving parts that go to the feed dogs.
9. After that you can take the top off and move the stitch length adjustment and watch the moving parts. Oil and clean (qtip) the moving parts.
By doing these steps you should have gotten it to work. If not you will have to see a repairman.
Posted on Mar 29, 2015
    Top Expert:
  • Singer Master
  • 49,228 Answers
Check that the feed button or lever is in the correct position
If it is in the centre position then the feeding foot doesn't know to go forward (normal ) or reverse
If electronic controlled the maybe a service is called for.
Even on the raised setting, the feed dogs won't move the thinnest summer weight fabric. Does anyone know how to fix this problem on the Singer Model #7426?
Could be the presser foot is not applying enough pressure to the feed dogs. Check your owner manual for instructions on increasing the presser foot pressure. Could also be that the feed dog height needs to be adjusted or their teeth are worn (do not run the machine without fabric between the presser foot and feed dogs).
Aug 22, 2017 | Singer Sewing Machines
Feeding Gear for Singer model Mon AMi II 390
These machines are not user serviceable, no parts will be available to the general public. Have a trained service technician give you an estimate for repairs.
Cheers,
Embroidery Services
San Diego, CA
Jun 11, 2016 | Singer Sewing Machines
Singer model 518....the material won't feed through.It wants to sew but won't feed cloth through. Thks
Be sure you have the stitch length set high enough that the fabric will actually move instead of sewing mostly in one spot.
One other thing to check is the presser foot applying enough pressure to the fabric so that the feed dogs can grab the fabric? On the top left side of the machine, there is probably either a dial or a push-type button. That would most likely be the pressure adjustment. The tighter that is set, the harder the pressure the presser foot will apply and the more the feed dogs will grab the fabric.
Check that the feed dogs are in the "up" position so they will pull the fabric through the machine. Are the feed dogs actually moving forward, raising above the needle plate, pulling toward the back of the machine, and then dropping below the needleplate before moving forward again? If not, then the problem could be with the feed dogs.
Your machine appears to be a mechanical model. If so, it could be the machine needs a good over-all cleaning and oiling--a couple drops of fresh, good quality sewing machine oil every place that metal rubs on metal (no plastic parts, belts...). Feed dogs are frequently affected when the sewing machine does not receive regular maintenance.
Jun 04, 2016 | Singer Sewing Machines
My singer 6180 feet dogs eats fabric at the top of feed dogs fabric gets stuck and does not feed the fabric why???
It sounds like the height of your feed dogs is the problem. I don't know which model you have, but of it's a plastic casing, you will need to take it in for service.
Mar 05, 2015 | Singer Sewing Machines
My singer sewing maachine model 9008 was working fine but than didnt feed the fabric, what could be the problem/
If it's not feeding the fabric, it make me wonder if you accidently lowered your feed dogs.
Jun 19, 2014 | Singer Sewing Machines
Singer Sewing Machine model #2638 Does not feed fabric
Here is a link to page 22 of the manual. It shows you where to flip the lever to raise the feed dogs. If your feed dogs are not grabbing fabric your feed dogs are lowered.
https://www.manualslib.com/manual/1050311/Singer-2638.html?page=23#manual
Sep 20, 2012 | Sewing Machines
I have an old Singer sewing machine, (I cant find a model number for anywhere on it) that wont feed fabric. I know some have a darning option, but I cant for the life of me find such a thing on this...
Thge most common fault is the needle plate is not on properly if you have a magnetic plate, you may have a drop feed mechanism in the bobbin case area.
Aug 08, 2011 | Singer Sewing Machines
I have a singer 3343c machine, when sewing the fabric foot does not move, the fabric while the machine is sewing.
the presser foot only holds the fabric against the feed dogs in the needle plate area
check the feed dogs to see if there in the up position
if not there should be a nob in the feed dog area to move them up & down
on some models when you remove the extension table the nob is at the back
Dec 10, 2010 | Singer 3343 Mechanical Sewing Machine
Why would my Singer 6235 not feed the fabic:
h! there,
fabric moves forward when machine run due to movement of feed dogs,feed dog has a teeth, when your foot presser goes down attached to fabrics the pressure hold the fabric between pressure foot and feed dogs that why when machine run feed dogs pushed fabric when recieved stitch.try to check adjustment of feed dogs it maybe set at rest or neutral.reset it to upward towards needle.check also bobbins thread if accumulation was build up under feed dogs.regard and have a nice day.
Apr 03, 2009 | Singer 118 Mechanical Sewing Machine
Sewing Machines Logo
73 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
