Question about Rockford Fosgate Car Audio & Video
My rockford fosgate power 400@4 makes noise when switched to high pass but goes away when switched to full?
    Habit-Forming:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 69 Answers
What kind of noise
Posted on Aug 26, 2016
SOURCE: Rockford Fosgate Amp Repair Guild
I would love to get a copy of that repair guide you made. Could you please
Posted on Sep 02, 2007
SOURCE: Rockford Fosgate 800a2 To 2 SVC 2ohm subs
Ok.. Bridge the two sub into 4ohm than bridge to amp.
So. this how it goes.
sub1 + -
to      | |
sub2 - +
=      4ohm
           From Sub
                Two
amp (L) - + (R)- +
This will use the full potiental of RF 800a2 amp. I believe it like 1153 watts max out.
Posted on May 29, 2008
  • 4 Answers
SOURCE: How much would installing a headunit, amp, and subs usually cost?
hows it going so you need it to be installed or you can install this yourself? well the best bet fund to get stuff done cheap is t get the stuf you will need to do an install like a install wiring kit and tools and post a installer help on craigslist.org iin your local area would be the cheapest way or just go to your local audio stereo shop thanks again and i hoope this help have any more questions please feel free to contact me if you need a step by step install i can help you in that and save you big bucks thanks again. always forward jcbproducts
Posted on Dec 03, 2008
etirbynnor
  • 655 Answers
SOURCE: Rockford fosgate 800 a2 amp power?
Hello desperate2le,
Watts delivered is a function of the voltage times the current. If the amp was 100 percent efficient, it would need 33 amps at 12V for 400 watts. At 14.4V, it would only need 28 amps. Of course, amplifiers are NOT 100 percent efficient, only about 50-60 percent in many cases, but somewhat higher for monoblocks, maybe 80-90 percent. So you're looking at a fuse in the 60-80A range. In the absense of a specific fuse size from the manufacturer, I'd start the primary fuse at a 60A and if the amp blows it on power up/immediately/frequently, move up to an 80A.
All of the Rockford-Fosgate 2-channel bridgeables I've ever seen show using the left positive (+) and the right negative (-) for bridging. But if it's not shown right on the amp, I'd call or email RF for the correct connection. The new amps do show it.
Hope this helps.
Posted on Apr 28, 2009
  • 149 Answers
SOURCE: 1000 crossfire bmf and a rockford fosgate that need to be fixed
send the rockford to landis technical-they bought up all the parts to rockfords amps and will get them back to factory specs and recertify it for ya along with a new power certificate-look on rockfords website and snoop around and it will break it on down for ya and give you the address n stuff. i had to send my 1501bd mono amp in to get an overhaul and it came back throwin 1810watts rms so that was better than when i started -good luck.
Posted on May 01, 2009
Is the bass boost the gain or frequency knob?
Bass boost simply adds DB or gain to the bass signal. Some like it, some dont.
The frequency knob is the Low Pass Filter (LPF) that cuts off the amp output above
the set frequency. A bass system usually cuts off below 400 HZ and more often 200HZ.
A good, rattle your car bass note is in the 25-80HZ range or lower but most amps and audio
input devices cant attain a good low note with clarity.
"Low-pass filter allows only frequencies below the crossover point to be amplified. A high-pass filter allows only frequencies above the crossover point to be amplified - useful for keeping low bass away from small speakers, so they can play more efficiently."
Checkout Crutchfields Glossary of Car Amps.
http://www.crutchfield.com/S-LPyoWWgD5qN/learn/learningcenter/car/amplifiers_glossary.html
Mar 14, 2011 | Rockford Fosgate Car Audio & Video
I have one 12inch 1000 watt mtx sub what size amp should i buy
Hello taona80,
If the 1,000 watts is RMS, I'd recommend an amp in the 750-1,000 watt RMS range, perhaps like the Alpine MRP-M1000 or Rockford-Fosgate T1000bd. If the 1,000 watts is peak power, the subs continuous (RMS) power handling is much lower, probably 300-400 watts. In that case, I'd recommend the Alpine MRP-M500 or Rockford-Fosgate T500-1bd.
Nov 09, 2009 | Nitro BMW-482 Car Audio Amplifier
Connect rockford fosgate amplifier & speaker together
Assuming your P3 has a single voice coil (it will have only one place to plug your wires into) you will be running this in a bridged mode. You will take the left (+) coming off the amp and plug it into the (+) on the P3. Then take the right (+) from the amp and plug it into the (-) on the P3. This will make your amp push 500 watts to your sub. Now on the amp make sure your adjustments are as follows: Signal input switch is set to unbalanced for RCA input. Left Phase switch is set to 0. Right phase switch is set to 180. your X-card should be set to low pass. And adjust the gain for both R and L equally so it has equal power from both channels.
Aug 09, 2009 | Rockford Fosgate Punch 401S Car Audio...
Rockford fosgate 3002 thermal light on no sound
Is this powering speakers or subwoofer? If it's the subwoofer you need to make sure the gain is turned up and the sub is set to low pass frequency. Also make sure bass and subwoofer are enabled on the head deck. Make sure the RCA's are hooked up properly at the back of the head deck. If it's the speakers then you may have balance set to front only so your rear speakers aren't making noise.
Aug 04, 2009 | Rockford Fosgate Car Audio & Video
Hello desperate2le,
Hope this helps.
Apr 27, 2009 | Rockford Fosgate Punch 800a2 Car Audio...
Not a problem just a question
  • 100 watts RMS x 2 at 4 ohms
  • 200 watts RMS x 2 at 2 ohms
  • 400 watts RMS x 1 at 4 ohms in bridged mode
  • stereo or bridged mono output
  • 4-ohm stable in bridged mode
  • Tri-Way capable
  • requires 8-gauge power and ground leads — wiring and hardware not included with amplifier
  • 50-250 Hz high-pass/low-pass (12 dB/octave) crossovers
  • wired remote included for fingertip control of Punch Bass (0-18 dB boost at 45 Hz)
  • MOSFET power supply and output devices
  • MEHSA mounting technology increases the heat transfer from the MOSFET output devices to the heat sink, for higher power output, lower operating temperatures, and greater reliability
  • TOPAZ — noise-killing differential inputs that eliminate 80% of ground loop noise
  • Trans•ana circuitry keeps preamp voltages low and signal paths simple for outstanding audio quality
  • NOMAD — advanced protection circuitry for "intelligent" shutdown protection
  • speaker- and preamp-level inputs
  • 11-1/8"W x 2-3/8"H x 9-7/8"D
  • Wire your sub in bridged mode (4 ohm mono)
    + to + on amplifier
    - to - on amplifier
    (using bridging terminals)
    Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
    Apr 25, 2009 | Rockford Fosgate Punch 401S Car Audio...
    Rockford Punch HE2 wiring question.
    if your sub will handle it, bridging it will give you more power. The best thing to do is to find out how much power the amp puts out ( RMS ) and if it is in your power handling range bridge it. It sounds better and gives you a harder punch because of more power.
    Feb 05, 2009 | Rockford Fosgate HE2 RFP4212 Car Subwoofer
    Rockford Fosgate 501bd question
    that amp should work fine with those speakers,just make sure that they(speakers)are wired for 2 ohms.at 500-600watts coming from amp, you should be getting 250-300 watts per speaker,just dont crank your gain too high on the amp.
    Aug 29, 2007 | Rockford Fosgate Power 501BD Car Audio...
    Car Audio & Video Logo
    79 people viewed this question
    Top Rockford Fosgate Car Audio & Video Experts
    Tygh Duval
    Tygh Duval
    Professor_V
    Professor_V
    Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
