Question about Pool & Spa
My robo kleenz don't pick debris from the pool
  • 1,631 Answers
This cleaner has been discontinued by the manufacture. Parts may or may not still be available, if you are in need of them. By the way you worded your sentence, I am presuming that the unit is moving around in the pool, but not picking up any debris. This means that there is no suction being created at the bottom input port.
this is most likely to dirty internal filters, and I believe these use filter bags. Disassemble the filter area, and remove the bags. Clean them very well. And try again.
Posted on Mar 31, 2015
thepool
  • 78 Answers
SOURCE: I have a robo-kleen pool cleaner which stops
If debris is entering the bag, it may be as simple as that. The bag is clogged. We typically recommend hand cleaning a pool before using an auto cleaner specifically for that problem. You might have to remove and clean the bag 50-75 times. Much easier to hand vac first. If no debris is getting into the bag before it stops, it could be a problem with the motor. we have seen them "short cycle" and require replacement. Rob
Posted on Apr 23, 2010
jharwell668
  • 640 Answers
SOURCE: Wondering if a robo-kleen robotic pool cleaner can
These automatic pool cleaners can be used in inground pools, but only if they are flat bottom. They cannot be used on split level pools with deep ends.
Posted on Jul 21, 2010
jharwell668
  • 640 Answers
SOURCE: Robo Kleen pool cleaner troublshootong
One thing that you might want to try on these pool cleaners is removing the limit screw on the axle for greater angle of tandem wheels. Make sure your filter bag is not clogged or partially clogged because this cause restrict movement. Check for debris jammed in your drive system (wheels, axles, etc.)
Posted on Oct 07, 2010
jharwell668
  • 640 Answers
SOURCE: I have a Robo Kleen
You should be able to purchase pumps for these automatic pool cleaners from a pool supply company, but I would take it to a professional first. It could be something that is easily fixed without purchasing an expensive part.
john224
  • 1378 Answers
SOURCE: Our Robo-Kleen moves around the pool but does not
For a list of service centers or further troubleshooting assistance please contact Maytronics directly at www.maytronicsus.com or 888-DOLPHIN.
John
Posted on May 20, 2011
My robo kleen moves around the pool but has no suction so it won't pick up any debris
i had that problem, past year
open the motor check for rust stains on the round magnetic surface
i used a steel or copper brillo pad dry to sand down the surface
careful with those plastic motor screw washers to secure motor
Jul 27, 2012 | Smartpool Dolphin Robo - Kleen Above...
Not picking up debris
open motor
sand down rust stains with coil brillo pad
test before mounting back into car
Jun 25, 2012 | Smartpool Dolphin Robo - Kleen Above...
The vacuum is not picking up the debris in the pool
if it drives ok, then it should be the water pump motor
if you see the water bubbling at the top of your pool then the vacuum part is working
Robo comes on but wheels dont turn and robo just sits there.....I cna see no physical problems as all else appears to be working fine. Thanks for any assistance you can provide. Robo Kleen in new as...
Make sure that your impeller is not clogged. Occasionally hair or linen may get caught in the impeller. Take the top grill off by removing the 2 screws from the top, with the transformer unplugged. Remove the debris and replace the grill. You will also want to check for obstructions in the axle of the drive shaft. Sometimes even small debris can cause the wheels not to turn. You might also want to remove the limit screw for greater wheel movement. These are all pretty common problems with these pool cleaners. Unfortunately, it could also be a problem with the gear box. If this is the case, you will need to have it services professionally.
Jun 11, 2011 | Smartpool Dolphin Robo - Kleen Above...
Robo kleen moves back and forth in one area
First, I would make sure that you don't have any debris in your wheel axle or impeller. Both could restrict movement. You can also try removing the limit screw on the wheels to see if that helps. Most likely, your problem is going to be with the interval timing software in the pool cleaners computer system. If this is the case, you are going to have to have it services and repaired professionally.
Jun 04, 2011 | Smartpool Dolphin Robo - Kleen Above...
My robo kleen pool cleaner motor and pump run but the unit will not roll
You might need to perform some maintenance on the automatic pool cleaner wheels and drive system. Remove debris or tree leaves caught in the axle bearing. Do not turn the drive wheels by force. This may cause damage to the drive gear train.
Nov 04, 2010 | Smartpool Dolphin Robo - Kleen Above...
My Robo-Kleen, when I first turn on goes forward a couple of feet, then goes in reverse for a couple of feet then stops altogether. Fan is still working while the wheels are turning however when the wheels...
It sounds like your gear box has gone out. If that is the case, the pool cleaners not going to work until you replace the gear box. Unfortunately, this is something that only a professional can do. Just to make sure that this is the problem, you should first check the wheels for any debris or damage. Then make sure that you don't have any clogs or jammed/cracked hoses.
Aug 10, 2010 | Smartpool Dolphin Robo - Kleen Above...
Pool & Spa Logo
64 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
