Question about Frisby Audio Players & Recorders
What buttons do i press on the sub to connect to bluetooth
How to pair it with galaxy tab 4
This is for the 1900, but should be the same. Go to Bluetooth settings on your Galaxy.
Samsung HM 1900 User Manual
Aha, I found this for the 1500
4 Enter the Bluetooth PIN (0000, 4 zeros) to pair and connect the headset to your phone. Your headset supports the Simple Pairing feature which allows the headset to be paired with a phone without requesting a PIN. This feature is available for phones that are compliant with Bluetooth version 2. The headset also can be paired via the Active pairing feature, see page 14. Connecting with two Bluetooth phones
With the Multi-point feature activated, your headset can be connected with two Bluetooth phones at the same time. 1 After connecting with the first Bluetooth phone, press and hold the Talk button until the blue indicator light stays lit. 2 Press and hold the Volume up button to activate the Multi-point feature. 3 Activate the Bluetooth feature on the second Bluetooth phone and search for the headset (see your phone???s user manual). 12
4 Select the headset (HM1500) from the list of devices found by the second Bluetooth phone. 5 Enter the Bluetooth PIN (0000, 4 zeros) to connect the headset to the phone. ??¢??¢ You can set the headset automatically to reconnect to the recently connected phones each time you turn it on. -- To reconnect to the two most recently connected phones, activate the Multi-point feature. Press and hold the Volume up button in Pairing mode until the blue indicator light flashes twice. -- To reconnect to only the most recently connected phone, deactivate the Multi-point feature. Press and hold the Volume down button in Pairing mode until the red indicator light flashes twice. ??¢??¢ When the headset connects to two Bluetooth phones, some phones may not connect to the headset as the second Bluetooth phone. English
Disconnecting the headset
To disconnect the headset from your phone, ??¢??¢ Turn off the headset. 13
Reconnecting the headset
When the headset is paired with a phone, it will attempt to automatically reconnect each time you turn it on. If the headset does not automatically attempt to reconnect, ??¢??¢ Press the Talk button. Pairing via the Active pairing feature
With the Active pairing feature, your headset can automatically search for a Bluetooth phone and try to make a connection with it. 14
3 Press and hold the Talk button until the violet indicator light turns on. The headset will switch to Active Pairing mode, search a Bluetooth phone within range, and attempt to pair with it. [. . . ] ??¢??¢ To switch between the current call and the held call, press and hold the Talk button. 19
http://lastmanuals.com/manual/SAMSUNG/AURICULAR-MONO-BLUETOOTH-HM1500
Oct 30, 2015 | Samsung HM1500 Bluetooth Headset
How do i get the pairing code for my lexmark s305
1 Insert a Bluetooth USB adapter into the USB port.
Bluetooth Dongle Connected appears on the display.
Note: A Bluetooth adapter is not included with the printer.
2 From the printer control panel, press Setup.
3 Press the up or down arrow button to scroll to Bluetooth Setup, and then press OK.
4 Press the up or down arrow button to scroll to Security Level, and then press OK.
5 Press the up or down arrow button to select the security level, and then press OK.
• Select Low to allow Bluetooth devices to connect and send print jobs to your printer without requiring users to enter a pass key.
• Select High to require users to enter a four-digit numeric pass key on the Bluetooth device before connecting and sending print jobs to the printer.
6 The Bluetooth Pass Key menu opens on the operator panel display if you set the security level to High. Use the keypad to enter your four-digit pass key, and then press OK.
Jun 12, 2012 | Lexmark Impact S305 Wireless All-in-One...
Want to pair Pro 705 via Bluetooth with Nokia E72. Cell asks for passcode. Have tried 0000 and 1234. Doesn't work
May 07, 2011 | Lexmark Prevail Pro705 Small Business...
Bluetooth
There are six sub models included in the model number you have given and according to the acer website none of the specifications indicate that there is wirelss bluetooth built into the laptop. So it appears that it does not.
Oct 04, 2009 | Acer Aspire 5535-5050 Notebook
How to connect via bluetooth my blackberry and my macbook?
Hi
to receive data files on a Blackberry you need to 1st make sure your device is set to visible in bluetooth settings. If the BB is receiving? In menu select media, once in media menu press BB button. A sub menu will pop up and you should see an option to receive by bluetooth? Select this and now the device should say 'waiting for connection'. Now send file from other device and it should receive. Hope that helps?
May 03, 2009 | RIM Cell Phones
Bluetooth problem , cant do the bluetooth activity
Hi
Blackberry's are very secure.
If you want to receive by B/Tooth you need to firstly make sure B/tooth is switched on. Go into media section of menu. Once in media menu,press BB button and up pops sub menu, you will see an option to receive via B/tooth, select and now it will receive incoming B/tooth files.
All Blackberrys work this way as they are the most secure mobile device! Thats why the FBI use them! Hope that helps?
Apr 27, 2009 | Cell Phones
BT160 connect problems
while your in the phones bluetooth manager/program and searching for the device. press the bluetooths buttons to enable the 2 to syncronise. if you press the up/down volume buttons while searching with the phone, it should find it, and syncronise. by pressing different buttons, your giving the phone a chance to detect a bluetooth signal change, and receive the device.
Mike @ compurepair.
Apr 01, 2008 | Jabra COMMUNICATIONS BT160 Bluetooth...
Problems With Pairing H500 and Motorola V190
1.Press and hold the Multifunction button in the middle of a boom headset while the headset is closed. The light will glow blue.
2.Open the boom microphone and the blue light should remain on. If not, repeat step 1.
3.On the cell phone, press Menu > Settings > Connection > Bluetooth > Handsfree > New Device
4.Select H500once a connection is detected.
5.The passkey "0000" is now entered to confirm the connection has been made.
6.The cell phone screen will now read "Bluetooth Connection".
Tips:
1.Provided you set the Bluetooth power to "On" after the initial connection has been made, the phone will automatically re-connect to the headset.
2.To set the Bluetooth power on - Press Menu, Select Settings, then Connections, then Bluetooth link, scroll to Setup and select that. Scroll to Power and chose Change. Scroll to On and press Select. The screen should now read "Changed: Power On".
3.Test Your Connection: Close the headset and watch for cell phone to say "Disconnected". Re-open the headset and the phone should be connected automatically and will now display "Bluetooth Connected".
please give good rating if the solution works.
Thanks for using FixYa.
Dec 24, 2007 | Motorola Mobility H500 Wireless Headset
183 people viewed this question
Top Frisby Audio Players & Recorders Experts
Andrew Taylor
Andrew Taylor
 Grubhead
Grubhead
Don A
Don A
Are you a Frisby Audio Player and Recorder Expert? Answer questions, earn points and help others
