Question about Garden
Power mate rear tiller cranks but want stay running
    Top Expert:
  • Garden Master
  • 45,531 Answers
It is indicated that the main jet in the carby is blocked or there is water in the fuel
Check that the filter in the tank or line is not blocked first.
Posted on Mar 29, 2015
3 Suggested Answers
  • 468 Answers
SOURCE: Yard Machine rear tine 6hp tiller that wont start.
Ok, what's happening, is your carburetor metering hole is plugged. When you place your thumb over the carb, it draws fuel through the primer circuit to feed the engine instead. What you need to do, is clamp off the fuel line, take the nut off the bottom of the carburetor bowl, and clean that nut. Look closely at it; there is a hole that goes down the center of it, and a hole that goes through it side to side towards the bottom. These make a "T" shape inside the nut. You need to make sure that these are completely clear and clean. The one at the bottom is very small, and plugs easily. You usually need a small piece of wire to clean it, such as a single strand from a wire brush. You can use carburetor cleaner to loosen it up a bit, but the important part is to clean that hole out. You also need to make sure that the float moves freely up and down while you're in there. If it sticks in the up position, it will starve fuel as well. Also look closely at the gas that came out when you did this. Was there any water in it? If so, let a bit drain out before putting it all back together.(unclamp the fuel line). Hope you have it back online soon.
Posted on Mar 23, 2010
Testimonial: "Nut was clogged. Now it starts but acts as it is in choke position, dont think there is a choke. Engine reves, falls, reves falls but stays going."
  • 198 Answers
SOURCE: tiller won't stay cranked
the carb needs a thorough cleaning
Posted on May 04, 2010
What type of oil goes in the crank case in a Scotts model 6070S, rear tine tiller?
normal engine oil in the engine sump
gear oil 80 oep in the gear box
Jul 21, 2016 | Garden
FG tiller 110 stop running took it apart timing belt loose what do I need to fix it
replace timing belt if hours of use unknown are stretched cracked
before removal take photos of line up points for crank and cam cogs
these belts when stopped
do look as if they run off the cam a bit
but under work load stay straight
Jun 22, 2016 | Garden
How do I adjust the carburetor on an Ariens 5020 tiller, model #901016, with a 5 HP Tecumseh engine?
close the needle valve completely, then back it off 1.5 turns. Adjust from there for most efficient fuel usage.
May 04, 2015 | Ariens Rear Tine Tiller 17 901028
My powermate rear tine tiller is getting gas into the oil it will start and run as long as im am putting fuel into the carberator once i stop putting fuel the engine stops what is the problem. the til
This sounds like the float is sticking in the carb causing it to flood . You need to take the carb off and clean it and put a kit in adjusting the float per the instructions
Jun 27, 2014 | Powermate 18 in. 196 cc 4-Cycle Rear-Tine...
Engine runs on half choke
You probably have some buildup in the carburetor, because tillers are gernerally used seasonally it leaves plenty of opportunities for buildup to occur . Also, you should inspect throttle cables and linkage to insure that everything intact.
Sep 07, 2012 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Tiller won't stay cranked
May 04, 2010 | Mantis 2-Cycle Tiller
Engine will crank with starting fluid, but dies.
Have you checked the spark plug and see if its clean and also check the fuel line and carburetor for clogs. And you can also check the air filter.
Hope you find this helpful.
Jul 09, 2009 | Mantis Gas Mini Tiller/Cultivator, 2 -...
Carb is running on full ckoke
screw in the adjustment screw all the way in then back off 1.5 turns.crank and adjust from there.
Apr 27, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Oil blows out of tube
You either have a head gasket going bad or your piston rings are shot which causes air to go down into the crankcase building up pressure which exits through the breather tube.
Jan 31, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Garden Logo
59 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
