I have a old siegler wall furnace model MIII 51 pwa and was wondering if someone could point me to a manual or location of the filter?
2 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: I am looking for a
I was going to see if someone else responded to this...but don't want to let it go too long with out a response...
I do not have and cannot find a wiring diagram...however if it is what I think iit is the wiring is not all the complicated....
Let me know specifically what is happening or not happening that are causing your problems....I can probably help you from there...
heatman101
Posted on Feb 27, 2011
What airflow does RHEEM RGLN 07eamer Furnance have? Is it downflow or upflow?
looks like Downflow
Rheem Classic Series Downflow Gas Furnace cdn.globalimageserver.com/fetchdocument-rh.aspx?name=rgln... · PDF file Rheem Classic® Series Downflow Gas Furnace FORM NO. G11-519 REV. 1 RGLN- Series ... RGLN- SERIES 05EAUER 05NAUER 07EAMER 07NAMER Standard Filter ...
Feb 18, 2016 | Filter Heating & Cooling
Williams wall heater 2509622. How do I keep the pilot on? It tends to turn off after it reaches the desired temperature.
WILLIAMS 2509622 OWNER'S MANUAL Pdf Download.
www.manualslib.com > Brands > Williams Manuals > Furnace > 2509622
2509622; 2539622; 2559622; 3509622; 3539622; 3559622; ... WHAT TO DO IF YOU SMELL GAS: ... Williams furnace co. direct-vent wall furnace owner's manual (24 pages) ... Caring for Your Furnace ............24-25 Locating Wall Furnace and Thermostat ........6-7 Learn how to keep your new Williams Furnace operating.
How to light Heater or Furnace Pilot Light Gas Pilot of ...
? 5:01
https://www.youtube.com/watch?v=FZVQmKTYTTg
Oct 25, 2013 - Uploaded by 3p0cHx
How to light a gas pilot for a heater or furnace of the Williamstype. This is a general guide and is not ...
[PDF]Monterey Installation Instruction Manual - Home Depot
Dec 08, 2015 | Williams Heating & Cooling
Where is the filter located in the armstrong air ultra v advantage 93?
The Filter will be located between the air return and the blower box. Sometimes there is a filter "rack" added by the installer on the outside of the furnace - it will be located between the blower box (lower part of the furnace where the blower is located) and the air return duct - Locate the filter rack and remove the access cover, slide out the old filter and slide in the new one - Note that filters are "directional" meaning they are designed for air flow in one direction only (look for the air-flow orientation marked on edges of the filter) replace the access cover. If you do not see the filter rack on the outside of the furnace, it may have an internal filter rack (inside the blower box)
To change an internal filter - Remove the lower front cover of the furnace, the filter will be held flat against the return inlet by some sort of retainer - remove and replace the filter with the same size and type - be mindful of the air-flow orientation of the filter (air-flow indication arrows should point toward the blower). Replace the retainer and cover(s).
Sep 13, 2014 | Heating & Cooling
I am looking for a wiring diagram for a model 8565-C Lear Siegler counterflow wall furnace. Thank You
heatman101
Feb 26, 2011 | Heating & Cooling
How do I locate and change the furnace filter?
Your filter will commonly be on the side of your furnace where the return air comes in, usually it will slide into a filter rack or you might have a small cover on it. When replacing a filter make sure the arrow on the filter is pointing in the direction of airflow, so the arrow should be pointing toward the furnace.
Jan 21, 2011 | Goodman Heating & Cooling
I'm trying to locate an owners manual for an old Montgomery Ward Wall Furnace, model # SFB 50175A C.
There is not much out there at all.
Try http://www.borel-furnaces.com/ they may be able to help.
Hope this helps.
Nov 27, 2010 | Montgomery Ward Microwave Ovens
Where is the filter on the Criterion II
On a upflow model, the factory location for the air filter is just below the blower. Remove the front furnace doors to get to it.
If it is a downflow furnace, remove both furnace doors, and look inside the blower area, they will be sitting above the blower. Usually 2 air filters, in a "V" formation and are sometimes hard to get to.
If you do not find the filters here, someone has removed them or they may have been relocated to the return air grill, a large grill, usually located in the hallway or higher up on the wall.
If the Rheem factory air filter is still being used, it will be a black plastic frame and the filter area will look like a window screen.
Good luck and have a great day.
Paul
Apr 05, 2010 | Heating & Cooling
Where are the furnace filters in my older furnace?
Open the door to the airhandling unit inside the closet by lifting upward on them. There should be two filters located on top of the A coil.
Dec 05, 2009 | Heating & Cooling
I just had the furnace installed six months ago and have used the air condtioner over the summer but never the furnace. When I went to change the controls for the furnace use, the blinking ''change...
Hi, sometimes depending if the unit is an up flow or down flow that depends where they put the filter.If you don't have a return grill in the ceiling, then it would be in the bottom of your furnace. I am sure its hard to remove as it is new, but i am sure it is there.Sometimes there is a grill on the lower wall beside the furnace they could have put it in. They may not have installed one? Good Luck, Sincerely, Shastalaker7
Nov 27, 2009 | Heating & Cooling
Changing filter
The filter should be located in the return air flow duct either inside the furnace or in the ductwork
you should have it inspected by a service contractor
as far as when it should be replaced depends on the condition of the heat exchanger and overall condition of the rest of the parts it could start to nickel and dime you
Dec 31, 2007 | Carrier XHB123D X/Y Series Heat/Cool Air...
Heating & Cooling Logo
82 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
