Question about Presto Kitchen Appliances - Others
My oil heats up but the red light stays on and I get no green light. Is it way overheating? Not reaching correct temp?
3 Suggested Answers
  • 110 Answers
SOURCE: hobart deep fryer, light pilot heats to temp then all goes out?
it probibly a millivolt system, would reccomend replacing thermocouple, that should take care of the problem
Posted on Jan 13, 2010
kebah
  • 683 Answers
SOURCE: czf625 deep fryer wont heat.green
hi limit device possibly tripped off. look for a reset button, usually located at the back of the unit and reset it.
Posted on Mar 31, 2011
Why does my ceramic heater keep turning off
Without other specifics I can only postulate that it's more than likely overheating, and perhaps it's location stifled
Dec 09, 2014 | Heating & Cooling
Shark iron g1462
the lights you witness are correct. once the iron has reached tempreture.
ensure the iron is stored in an upright position between ironing items if left laying down the iron may switch off as an anti-burn or fire safety feature as if left unattended. with the iron placed on its back plate with its point facing upwards the iron should stay on.
I hope this was useful.
May 14, 2014 | Irons
My 1997 Monte carlo is still overheating after we changed the thermostat and water pump what othernproblem is causing it to overheat
Car must use red coolant or yellow generic designed for newer than 1995 vehicles. Why you wonder - Red is designed for 272 Degees of total fluid heat and since newer vehicles are Aluminum Motors / Cylinder heads it is required to have a Red / Yellow anti - freeze coolant mix to carry - transfer heat out to radiator to be cooled by wind or Temp sensor turning on radiator fans . The older Green coolant is only good to 230 degrees before boiling over . This green in older engines worked because Iron / Steel engine blocks - cylinder heads Absorbed Large amounts of Heat . 1995 and Newer Aluminum does not absorb heat and will Warp Block - Heads if not kept cool ergo milky looking Oil - Coolant . Be sure to get cocentration to 50% REd or Yellow Coolant to - 50%% Water , this also helps fight heat and will give you good winter proction at cold temps.
Jul 16, 2012 | 1997 Chevrolet Monte Carlo
My electric kettle is starting to break.
It sound like the temperature sensor that switches the kettle off when it has reached the correct temperature is faulty. It would probably be cheeper to replace than repair
Feb 18, 2012 | Chef's Choice 677 Cordless Electric Kettle
I have a 2000 Mercury Cougar and the gauge inside tells me that the engine is over heating, no heat is coming from the heater when I turn it on, the fan for the engine is running at full blast, the engine...
The overheating and lack of cabin heat both point to a failed engine thermostat which would be stuck closed. At the warm up stage, the coolant stays in the engine block to bring the engine to efficient operating temperature, then it opens and circulates the coolant through the radiator and heat core. If the thermostat is stuck closed, the engine will overheat, and coolant will never reach the heater core, and you will not get cabin heat.
Blinking oil light at idle which goes away during driving could be a low oil level, but may also be a drop in oil pressue. You could have a clogged oil fliter (at best) pickup tube, or a failing oil pump.
Mar 10, 2011 | 2000 Mercury Cougar
The waffle maker has two lights. A red one which indicates te power is on and a green one which lights up when it reaches the desired heat (and the thermostat circuit opens and the device stops heating...
There seems to be a problem with your thermostat or temp cutout switch if the machine is getting exceptionally hot. This could explain the green light not coming on.
Jan 26, 2011 | Krups FDK2 Waffle Maker
Here again is my model and serial it stops in the middle of the cleaning cycle Kenmore 665.16773402 serial # ft0302854 Here is how I have been resetting the dishwasher. I hit the following sequence of...
Door latch.
Open and close the door to make sure the door latch is securely fastened
Hi-Temp Wash, Hi-Temp Rinse, or Sanitize options.
Some models have options that may require a water heating delay, such as Hi-Temp Wash, Hi-Temp Rinse, or Sanitize. Additional time may be required to heat the water to the proper temperature. The dishwasher will continue to circulate water during this heating delay but the timer will not advance until the proper temperature is reached
Oct 06, 2010 | Dishwashers
Cooling light stays on
If you are referring to the blue temp light on the dash, it stays on until the engine has reached operating temperature. This lets you know the heat will be ineffective and the engine will not be running at peak efficiency during this time.
May 15, 2008 | 2004 Scion xB
Kitchen Appliances - Others Logo
88 people viewed this question
Top Presto Kitchen Appliances - Others Experts
Paul Bade
Jim Goldsmith
Jim Goldsmith
Are you a Presto Kitchen Appliances - Other Expert? Answer questions, earn points and help others
