Question about Janome Sewing Machines
Is there anyone who can repair a Janome MC 8000 with the stepping motor error. Mine had been running fine until I sewed over a thick flannel seam with a hidden pin. It knocked the needle out of alignment then this steppingmotor message came up on the screen. Can't get the machine to do anything...dealer time me it couldn't be fixed....so bummed!
  • Sandra Stovall May 16, 2015
    Sorry for duplication of instruction part 2 which appears first, the first is on the bottom showing which buttons to press first to initiate the process. Hope this helps
    Sandra Stovall
  • 5 Answers
You might try "resetting" your machine. It is not difficult; however, I cannot get my copy of instructions on here. If you like, you may email me and I should be able to provide the instructions to you.
Is there anyone who can repair a Janome MC 8000 wi - 4ffa662a-e61a-4e57-82ee-dc423e0a0994.jpg
Posted on May 16, 2015
SOURCE: Janome Memory Craft 8000 Stepping Motor Error
Bear with me here...
When the Janome 8000 is turned on, one of the first things that it does is run the stepper motors to return the embroidery carriage back to its original position.
The computer in the Janome needs to know when the embroidery carriage is back in the correct position and to do so, it uses a sensor.
If the sensor fails, it does not know that the carriage is back in the correct position.
When the sensor fails, what happens is that the stepper motor keeps running even though the embroidery carriage is fully back, so what you hear is a horrible grinding sound. The grinding sound itself is nothing to worry about, actually it is good news, it means that the stepper motor is fine.
Janome in their infinite wisdom decided that whether the motor failed or the sensor failed, that they would simply say on the screen that the stepper motor failed.
I have repaired a machine with this problem, in my case it turned out that the sensor was okay, but someone had damaged the main circuit board, breaking the track from the sensor to the computer.
Unfortunately, I don't know if this sort of repair is something that the average repairman can take care of. I am an electronics engineer, so thats why it wasn't a problem for me.
I just thought some extra information on what is going on might give you a head start in getting some one to fix it for you.
Posted on Nov 15, 2007
bargainbox
  • 1388 Answers
SOURCE: Janome MC 9000 Embroidery/Sewing Machine
This is the diagnistics routine for Janome 9000.
Run each test in sequence from 1 - 13, or until you find error
The results of this may not be what you want to hear, and may be why no-one has yet replied....I hope for an easy resolution for you
If you are having trouble reading this here, simply send a request via the "contact us" page on:
www.bargainbox.com.au
Martyn
Posted on Feb 16, 2008
SOURCE: New Home Memory Craft 8000 stepping motor error
ours was ndoing same thing. took bottom off and the stepping motor was stuck. moved it manually to get unstuck , oiled it, sewing again!
Posted on Oct 30, 2008
SewCreative
  • 15 Answers
SOURCE: stepping motor error
From what I've read here, it could be one of two things: a blown motherboard or a scratched bobbin case.
Before you do anything else, I'd remove the bobbin case, clean it and the area around it thoroughly (and check it for scratches or dings -- perhaps a needle broke recently?) and then replace it and see if that fixes the error.
If not, unfortunately, I'll bet it's time for a check-up with a repairman. :(
Best of luck to you!!
Posted on Apr 12, 2009
bargainbox
  • 1388 Answers
SOURCE: Screen dull on Janome mc 8000
There is an LCD Backlight Panel that illuminates the screen, and yes, they do fail.
Before you start, just check the screen contrast dial inside the top cover, front right, they can be easily knocked and this will also cause the screen to go light or dark.
Janome no longer supplies the LCD Backlight, however, we have an after market replacement at our store, and also provide fitting instructions and a good deal more besides.
If you care to contact me I can send a Diagnostic Routine and the Screen Reset instructions for you to check if there is anything else causing troubles.
Please remember to give details of your dilemma as we do receive a lot of requests.
Contact Link
Cheers
Martyn
Posted on May 19, 2010
Memory craft 8000 how do you take it apart to replace light
When your Memory Craft 8000 or MC 5700 is otherwise working fine but the LCD display screen begins to grow darker and you find you just can't read it, the only thing you can do is replace the LCD screen, or buy a new machine.
Janome no longer stock this item direct, but there is an affordable replacement available.
Full Access and Installation instructions are provided, so you can DIY or have someone else do the replacement for you.
Check this Link
Also includes advice, links & contacts to be able to Reset your screen and do a Self Diagnosis Routine to test your machine BEFORE you purchase a replacement LCD backlight for either the Janome MC 8000 or MC 5700, so you can check that there are no other troubles.
Jun 22, 2010 | Janome 8080 Computerized Sewing Machine
Try this link for an affordable solution to repairing your Janome MC 8000 Display Back Light
Janome Memory Craft 8000 LCD Backlight Replacement Kit
Mar 26, 2010 | Janome Memory Craft 5700
How do i install my el board in my janome mc 8000 sewing machine
Try this link for an affordable solution to repairing your Janome MC 8000 Display Back Light Janome Memory Craft 8000 LCD Backlight Replacement Kit. The kit comes with a custom repair manual specifically written for back light replacement.
Dec 28, 2009 | Janome Memory Craft 9000 Computerized...
Janome 8000 LCD question
Hi Lezlie,
I shall send you the installation instruction to gain access and replace the screen via email.
Cheers
Martyn
Dec 22, 2009 | Janome Memory Craft 9000 Computerized...
Sewing machine LCD display not lighting up
Check this Link
Sep 18, 2009 | Janome Sewing Machines
The sewing advisor screen on a Janome 8000 is getting dim.
Check this Link
Jan 26, 2009 | Janome Memory Craft 9000 Computerized...
JANOME MEMORYCRAFT 8000 STEPPING MOTOR ERROR
if you ever have this problem, it is because you have had something in the way of the embroidery arm at the back of the machine, so it has not been able to move freely; you'll get a terrible noise as the machine is unable to do what it wants, slips gears or something and then can't bring the arm to its home position. But fear not, i have found if you turn the machine off and gently push the arm back home to touch the machine as it is the start position, when you turn it on, it will work fine and no harm done. just make sure the arm can move freely before you start embroidery!
Jul 11, 2008 | Janome Memory Craft 9000 Computerized...
Janome/New Home Memory Craft 8000
I have a memory craft 8000 that gets a message stating "Stepping Motor Error". What can I do to try to fix it?
Oct 01, 2007 | Sewing Machines
Sewing Machines Logo
146 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
