Question about Refrigerators
Someone told me you could maybe give me pointers to check. I could also send a video to you of the failed startup sequence. Hoshizaki kml-250mah Ice Machine Problem. I had someone clean the ice machine and every time it leads to a service call I just can't afford. I get two a beep error. Now I replaced the filter, here's what happens. I turn on. I see a red light and a series of green. On the third green I hear a hiss of a release valve, water starts to circulate, the fan and unit starts and then stops in about 15 seconds and goes into two beeps. It seems the amount of water circulating is slow as if not enough water is available which is why I replaced the filter. Before cleaning it worked like a charm so I don't buy bad compressor, valve et cetera. Now last time someone damaged a device that measures temperature and tells the unit when to stop making ice. I learned that if this goes bad, which it often does because it's a delicate part that you can jumper the two leads where it connects and it bypasses the part. I did this. Same problem. The person who cleaned it did take out the tray that guides the ice that falls into the bin and put it in incorrectly. I found the unit stalled in 2 beep mode because this guide tray was not installed properly and I did see some ice so right after cleaning it did try to produce ice and probably failed due to the backup; unlike now it starts and stops right away. It probably stalled due to the tray being in incorrectly and the ice backed up. The tray is in correctly and the unit has been off for a week. Now, what else should I check? The problem stems from the cleaning and possible backup oh ice that couldn't fall into the bin. Help please.
SOURCE: No ice...different question
Are you able to see if you can push a Q-tip or something up the fill tube line to see if it's frozen up inside there. It happens on certain units. You may need to take the Ice Maker out (easy) to get to the fill tube.
Posted on Feb 27, 2007
fridgetech
  • 473 Answers
SOURCE: Ice Maker on/off switch has blinking red light, will not produce ice. Manual no help
When you open the freezer door the light should be blinking. When you hold the flipper door shut (on the left hand side) without blocking the beam, the light should stay on solid. If all of this happens then the optics are o.k. If optics are ok then you most likely have a broken motor module on the icemaker and should replace the icemaker thermostat along with it. A bad icemaker thermostat will lead to the module breaking. If you not sure how to replace these parts then I would just replace the whole icemaker. That would be easiest and usually not much more expensive.
Posted on Nov 07, 2007
kermit854
  • 38 Answers
SOURCE: Hoshizaki KM-600MAH-E won't start
I don't have a wiring diagram for this machine so I can't be specific, but I may be able to offer a few suggestions. Check for voltage on the coil by slipping the two wires back off their coil connections you should be able to expose enough of the connection to measure voltage. If voltage exists when machine should be filling, you either have a bad coil, or water is not reaching this point. Check coil resistance by removing wires and testing coil. Resistance reading of 0 or O/L (out of range) would be grounds for replacing the coil.
If coil tests good, look for plugged water filters on water line leading to machine.
Hope this helps,
Kermit
Posted on Aug 19, 2008
SOURCE: Beeping Ice Machine
I have a Hoshizaki KM-250BAF that is making 3 beeps then pauses and them makes 3 beeps again. If I unplug the ice maker and plug it in it continues to make the 3 beeps. The manual does not mention anything about beeps. Can anyone help?
Posted on Aug 29, 2008
  • 124 Answers
SOURCE: km 500 kae hoshizaki 3 beeps every 4 second compressor not coming on
put an amp probe on common wire at compressor and see what amps are when it tries to start. 40 to 60 is mechancially locked up compressor. kill power and test start and run capacitors. there is an thermal temp over load on the compressor that opens when comp gets hot from trying to start. gently remove and look for cracks or burned looking. . i saw one this week doing exact same and i have ordered the oem compressor start cap realy and run cap and drier and will put in all new gas. be sure to allow sufficient time when switched to ice for it to get to ref cycle, it may take 5 minutes starting with water purge, then fill, etc. good luck, call hoshizaki dist they are usually pretty helpful if you need a auth service rep in you area. i think they are three years warrantied!
Posted on Oct 25, 2008
Hoshizaki kml-250mah Ice Machine Problem. I had someone clean the ice machine and every time it leads to a service call I just can't afford. I get two a beep error. Now I replaced the filter, here's...
I see 2 issues for one ur water inlet valve may have gone bad the coils defective u can test it with a multi meter or any appliance parts store should be able to test it for you, also should do a live volt test on it as well. check for full 120, next thing that thing u said that measures temperature? Its called a thermistor and there should be atleast 1 or 2 in ur freezer and maybe 2 or 3 in ur fridge. and it should not be jumpered other words u will get variable termperatures. it should be tested with ameter and should show about In most models around 1300 ohms ( give or take 150 ohms)
Mar 29, 2015 | Hoshizaki Refrigerators
My kml 250mah stopped makinr this condition?g ice after descaling. what is a possible cause fo
The valve that you turn to clean the area in between the plates has a small micro switch. This prevents the compressor from running in cleaning cycle. If the compressor is running, there is another issue.
Jun 02, 2014 | Hoshizaki Freezer Commercial Ice Machines...
Kml 250mah
some over flowing is ok as long as it does not go into the ice bin. if it is, the drain in the res is restricted some how, or the pump is not pumping the water out. start with that and let me know
May 22, 2014 | Hoshizaki Kitchen Appliances - Others
Hoshizaki Ice Maker KML-250MAH trips after water supply cycle ends
What is the voltage and the amperage of the breaker? Have you taken an amp reading of your ice maker and compaired to the electrical data information found on the ice makers dataplate? How many other electrical appliances are running on that same circuit? I will be here to help should you have questions and or respond, Thanks Sea Breeze
Apr 21, 2013 | Refrigerators
Kml 600 mah manual
go to http://www.hoshizakiamerica.com/. Look for your manual by clicking on "Support" and then fill in the model of your unit and then click "get manual". and you are there.
Feb 17, 2013 | Hoshizaki KML-600M Low-Profile Crescent...
Hoshizaki KM-600mah beeping
PCB requires to be reset. White button power needs to be on or it wont reset.
Feb 19, 2010 | Hoshizaki KML-600M Low-Profile Crescent...
I have hoshizaki kml 450 mah and i need water pump for it can you give me the part number . old onr is burnt out
I can get that pump. Look us up on the repair directory under refrigerators zip code 60060
Northeast Cooling LLC :)
Oct 01, 2009 | Hoshizaki KML-451M Low-Profile Crescent...
Model kml-450mah seral mo2237b Hoshizaki Ice machine
start at looking for a stuck float switch. this keeps it in defrost till it senses water level full enough to make ice.
Aug 12, 2009 | Hoshizaki Modular Cuber 680 Lb. with 550...
Something wrong with Harvesting cycle, ICE will not come out, coils freeze up.
If you need answers and have not recieved results I will try to help, I see no one responded to your request because the manual and diagnostics info seems to only be sent to people that sell and purchase the machine. If you need help and want answers  you can call me at 864-812-1887 or e-mail me at seabreezehvac@yahoo.com  your description of the problems could be many different possibilities. I want to know and help also. Thanks John Tripp
Sep 03, 2007 | Hoshizaki Commercial Freezer KM-500MAH
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
