Question about Dryers
Rear right wheel makes a revelution noise but stops when I apply brakes
Sounds like tumbling metal
    Top Expert:
  • Dryers Master
  • 51,301 Answers
Check the pad thickness as the noise may be from a tin scraper that is touching the rotor to let you know that you need a brake job.
Posted on Mar 29, 2015
Brakes make a whistle noise when applied and sometimes a low grown or grinding when coming to a slow stop or start.
A grinding or rumbling noise can also be symptoms of a wheel bearing or constant velocity joint in a driveshaft. A worn wheel bearing can also cause a 'whistling' sound (as can a worn CV joint).
A grinding noise with brakes is either worn pads causing metal to metal contact on the brake disk/rotor, or the brake backing plate catching on a spinning rotor ... or a loose/missing anti squeal brake shim (they stop the pads from rattling and vibrating).
However, as you say a mechanic has looked at the brakes and can't find anything wrong .. I think I would begin to suspect a wheel bearing or constant velocity joint on the driveshaft (front wheel drive cars).
May 05, 2016 | 2007 Honda Accord Sedan
I have a 2006 f-250, i have a grinding noise that sounds like it is coming from the rear wheels, but when i apply the brakes it stops.
How To replace front Brake Pads. In 90% of the car manufacturers the job will be done the same way. This is F250 Ford 2006
Jul 26, 2014 | 2003 Ford F250
I have a 2006 f-250, i have a grinding noise that sounds like it is coming from the rear wheels, but when i apply the brakes it stops. what could this be?
Are your brake pads worn? They will have a small metal tab on one of the pads on each side. These are referred to squeeker tabs. They let you know when your pads are worn enough to need changed before you get metal to metal part failure. They are designed to barely scrape against the rotor when the brakes are not applied and make an annoying noise. I would look again and make sure all rear pads are in good shape. If they are you might clean the brakes, sometimes a piece of dirt or debris can make the same noise. If you have one pad that is worn more than the rest make sure you clean and grease the caliper slide pins when you change the pads. Actually, you always want to make sure you clean and grease the slides when you do a brake job.
Jul 26, 2014 | 2006 Ford F-250 Super Duty
WHEEL SQUEAKS WHEN DRIVING
There is a small metal tab on the brake pad made to make noise
when the brakes are close to worn out,the noise goes away under
braking,I suspect the pads are in need of replacement.Make sure
the rear brakes get checked for proper adjustment at the same time.
Jan 06, 2013 | 2002 Dodge Caravan
2006 Honda CRV makes screeching sound while turning corners
built into the brake pads is a small bit of metal that when the pads get to low to be safe , runs on the rotor and produces the squeal applying the brakes stops the vibration so the noise drops off
Jun 29, 2017 | 2006 Honda CR-V
Metal on metal noise when driving. Sounds like brake noise when brake pads are in need of replacement. Sound goes away when the brake is applied. Car only has 20,000 miles on it (2006).
Hello tgiro7: My name is Roger and I will help with your question. The fact the noise goes away when stepping on the brake pedal says the problem most likely is in the brake area. The pads could be worn out even at 20,000 miles.If the noise sounds like it comes from the front remove the wheels and check the front pads. If the pads are bad most likely the rotors are also bad.Same would apply if the noise emits from the rear. When you have the wheels off check to make sure the calipers will slide in and out on the mount pins. Should they be stuck on binding the pads will wear excessively and prematurely fail. The calipers must move freely on the pins. If you drive with your left foot on the brake pedal? The amount of pressure required to apply the brakes and not stop the vehicle is 1 to 2 pounds of pressure. Wont turn on the brake lights but will put pressure on the calipers. This in turn will wear out the brake pads. Another thing to look at would be an out of adjustment brake switch. Reach down and grab hold of the brake pedal. Give a firm tug on the pedal. Should you feel the pedal give and hear a click or two the switch was set to deep and holding the brakes on.
Should you need further help please just ask. Please rate the answer. Thank You for using Fix Ya. Roger
Jun 16, 2011 | Chrysler Crossfire Cars & Trucks
My 2004 Dodge Caravan is making a very loud noise that sounds like metal grinding against metal and the noise is coming from the right rear. The noise isn't continuous, but when it happens, it's scary. A...
It could well be in need of new brake pads however this would be noticable more when you apply the brakes if the sound is in the rear its not the front brakes it could also be your wheel hub bearings are past there used by date its a serious problem and needs attension right away
Oct 05, 2010 | Dodge Caravan Cars & Trucks
Drum brakes causing intermittent grinding noise
Sounds like one of the springs that hold the rear brakes in place broke. Jack her up, pop off the tire, remove the drum and take a look. If you need to see what a good one looks like, look on the other side.
This is not a very common problem, but I saw it last year on a 69 chevelle.
Good Luck and thanks for using FixYa!!
Mar 26, 2010 | 1966 Ford Mustang
Have problems with rear brakes, when I apply them, so loud it sounds like a garbage truck stoping
that would be the sound of metal to metal a metalic noise that sounds when its time to change the brakes. or you have a brake fluid leak at the wheel cylinder witch is inside the brake drum
Dec 30, 2009 | Chevrolet 2500 Cars & Trucks
Dryers Logo
49 people viewed this question
Top Dryers Experts
