Question about GMC 2004 Envoy XUV SLT
Which fuses are for the 2004 Gmc ENVOY XUV SLT midgate latches?
SOURCE: 2004 Envoy AC works but does not come out the front vents. Only @ windshield
You most likely have a bad mode actuator. http://forums.trailvoy.com/showthread.php?t=40235
Posted on Sep 26, 2008
SOURCE: 2004 envoy xuv tailgate problems
the actuators have a white stem that sticks out of the bottom of them. if you push up on the ones on the driver side it will open the back hatch for you.
Posted on Dec 18, 2008
  • 94 Answers
SOURCE: 04 GMC ENVOY XUV The window on the midgate made a
take inside door skin off, everything now a days is plastic, prob the arm to lift window or a plastic gear broke, really easy to do....
Posted on Jan 04, 2010
SOURCE: fuse
The second fuse panel is under the rear seat.
Posted on Jan 07, 2010
  • 3600 Answers
SOURCE: 2004 GMC Envoy XUV mid-gate window won't roll up
be sure the gate is fully closed or it will not roll up if it is firmly in place and still does not go up you will have to remove the cover and see if the actuator plastic has broken off from the switch, it also could be a bent rod and or the switch is bad. Check fuses as well just to be sure before going to all the other work to pull cover off. Hope this is helpful and thanks for using Fix-ya.
Posted on Jan 19, 2010
Midgate want let down 2004 Envoy XUV
Folloow the link to find instruction on replacing the window regulator for the midgate http://forums.trailvoy.com/showthread.php?t=90533
Jan 06, 2017 | 2004 GMC Envoy
Midgate closed window up dash says midgate ajar. Its fully closed
Hello Anonymous,
These system are controlled by an electronic module that should
send a fault code to the BCM (Body Control Module) and accessed via the DLC (Diagnostic/Data Link Connector) if a fault is present.
Some Auto parts stores will connect a OBDII scanner to your vehicle for free and provide you with a starting point should any fault codes be present. Fault code scanning is always the first step in trouble shooting a problem.
May 21, 2016 | 2004 GMC Envoy XUV
Want shift into hi gesr
Search Results
    New owner of 03 Envoy XL SLT - AC not working - Chevy TrailBlazer ...
    forums.trailvoy.com > ... > OEM Issues
    Apr 12, 2011 - 11 posts - ‎5 authors
    My Envoy XL SLT has the I6 engine, digital driver/passenger, and rear ... It still doesn't appear that the AC compressor is kicking in. ... 2004 GMC Envoy SLT XUV ...Obviously if failed open the clutch won't engage. ... turn on the a/c and watch to see if it give the hint of wanting to go, if it .... Security Question ... A/C compressor not engaging
    Aug 25, 2010
    Removing front differential!!
    Mar 1, 2010
    [SOLVED] Trailblazer stalls at idle when defrost or A/C ...
    Jan 21, 2010
    Check A/C how?
    Sep 16, 2006
    More results from forums.trailvoy.com
    GMC Truck Repair Question Forums - GreatAutoHelp.com
    www.greatautohelp.com/gmc-trucks.php
    runs fine in park or at idle. go to put the truck in gear and it stalls out, will not take a ...What is OE thermostat temp suppose to be for a 2003 gmc envoy with the 4.2. ...signal for the injector to open and let fuel into the engine. to check the injector pulse..... Any idea on the issue. RPM stay the same when it idles rough. 4.2l v6 ...
    4.2L Inline 6 Cylinder 4200 Engine Sensor Location Pictures
    www.greatautohelp.com/sensor-location/4200.html
Jan 24, 2016 | GMC 2004 ENVOY XUV A/C Compressor a1z18717...
Glass divider between passenger and truck bed does not roll up
I assume you have an XUV. Same thing happened to me a few months back. If the glass isn't broken ( and you would have heard it if it did), its the "midgate window regulator" that has failed. I recently installed one myself and it's not terribly difficult [couple of hours x 2 nights by myself - easier with another pair of hands] if you are somewhat mechanically inclined and have a basic tool set. Here's a start on finding the part: https://www.google.com/#q=envoy%20xuv%20midgate%20regulator Google : "envoy xuv midgate regulator installation" and you'll be able to see a few examples.
Mar 14, 2014 | 2004 GMC Envoy
The midgate and tailgate windows on my 2004 GMC envoy XUV are not working. they are down and will not go up
If this happened all at once, probably the fuse or relay controlling the electricity to these windows has blown. That fuse or relay may be under the dash or under the hood. If they failed one at a time, you may need to replace the motors and /or the regulators for these. This is a common problem on vehicles with electric windows, usually they begin to fail from 7 years to older.
Be blessed.
Dec 30, 2013 | s80 s80 spoiler, tailgate, primed 001....
04 GMC Envoy XUV midgate window fell won't come back up; motor runs ,window won't move
The same thing happened to my '04 XUV. Discovered broken white nylon/plastic that retains the end of the lift cable. Ordered a new lift gate motor/mechanism assembly ($250) online and replaced it myself. Be sure to buy a new limit switch ($13) also. I did not and regretted it because you must remove the old limit switch from the old motor assembly so you can re-assemble it to the new motor assembly. While removing the old switch from the old assembly, I broke it. Had to then order a new switch. The cost to ship the switch separately was more than the switch. The whole thing did not really take that long and was surprisingly easy. It works great now.
Dec 13, 2010 | 2004 GMC Envoy
2004 envoy xuv tailgate problems, will not latch or open sideways. I have a 02 Envoy SLT the rear liftgate Dose not have power. the wipers dont work the Lock dont work I can not program my keyless entry....
I also have a 2004 GMC XUV. My gate would go down but not swing open. In trying to fix it, the gate then refused to go to the flat position.I have removed the cover plate on the gate and found the one of the solenoids loose from its mounting. Resetting the computer by disconnecting both battery leads and holding them together for ten seconds worked to restore function to the gate going flat, but the swing still does not work. I believe it is a bad solenoid or motor for the bottem left latch pin.
Feb 24, 2009 | 2004 GMC Envoy
GMC 2004 Envoy XUV SLT Logo
37 people viewed this question
Top GMC Heating & Cooling Experts
Doug Adams
Doug Adams
Darrell
Stan Ford
Are you a GMC Heating and Cooling Expert? Answer questions, earn points and help others
