Question about Boating
Motor will not always start right away. Most times when i first start out on my fishing trip. It has taken as many as 18 tries. 2015 model
    Top Expert:
  • Boating Master
  • 44,435 Answers
Problems resulting in hard starting are generally related to fuel problems
condensation in the fuel or corrosion in an empty fuel system are good problems
stale fuel is another good fault
A safety conscious person would start the engine before leaving home and have the engine regularly serviced by an accredited service centre for the make
Posted on Mar 29, 2015
Fuse gets hot and burns out
Small Engine Troubleshooting - Jacks Small Engines
www.jackssmallengines.com/diy/small-engine-troubleshooting/
Mar 20, 2015 - Engine Will Not Crank; Cranks - Will Not Start; Runs Rough On Low ... Engine not running (After Hot Test); Stops on High Idle; Hot - Will Not ... Paint or oilburn off. .... I have a Honda self propelled lawn mower that will not stop right away ... ends puts the motor out of time change the fly wheel pin if it's not the ...
Electric Mower will not start, trips the breaker? - Instructables
www.instructables.com/.../Electric-Mower-will-not-start-trips...
Instructables
Dec 29, 2015 | Garden
Suggest the measures to protect and develop the fishing industry in pakistan?
The best gauge to protect the ocean is to stop the industrial waste right away. And then taken measures to ensure to part of food. The industry can be grown by exporting the fish to different regions and all over the world.
I HOPE THAT THIS ANSWER CAN HELP U!!!!
Mar 13, 2013 | National Geographic GPS
Starting issues
starter motor sounds faulty
Apr 04, 2012 | 2006 Kia Rio
Machine Fills up perfectly. Then trips electrics when it starts the cycle. Have checked plug, and changed extension lead-all OK. Have taken front cover off and pump is OK, no water leaks at all, also have...
Sorry but it could be internal wiring/plugs sockets, control panel switches, control PCB but the main motor is probably the primary suspect, I fear that your only real option is a service call as the engineer will have the right equipment to safely diagnose what is wrong.
Sorry again and good luck,
John C
Mar 29, 2011 | Speed Queen Washing Machines
I have a new Tohatsu 6HP, 4-stroke motor on a sailboat. Is there a secret to starting it without pulling on the d... cord 20 times? Even then it may not start. Kind of scary if I am out on the lake and...
Yes, I think I know the problem because I have the same motor and mine starts right up every time. When you cold start it, you may not be priming it enough...it doesn't have enough gas. Don't squeeze the bulb 2 or 3 times, do it about 10-12 times. Full choke and it will light right up. On a warm start, you don't need to prime it or choke it. On a semi-warm start, try half choke and no priming.
Jan 11, 2010 | Light Outboard Motor Boat Bass Fishing...
I run twin 115 4 strokes,2001 model.Port engine started to drop rpm while running at wot. Dropped to 3700. No skipping,missing,etc. Stop and fish for hour, start over again and runs fine than starts...
check Compression and spark. Tools(1) A compression gauge (2) a spark gap tester.(3) A Clymer service manual for your engine. (you can purchase from your local dealer). I know all these are expensive but if your going to be a outboard owner you will always need them. troubleshooting (1) check compression. I'm giving you average numbers. Look at your
Clymer manual for specific numbers. all cylinders need to be over 100 lbs and equal each other within 5 lbs.(2) check spark. use a spark gap tester, all cylinders should jump a half inch gap.
Aug 31, 2009 | Boating
Boating Logo
81 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
