Question about Craftsman Garden
I have the Craftsman GT5000 24 OHV tractor lawn mower. It's been in storage for a while, I have replaced the battery, spark plugs, fuel filter, and oil. I can't get it to start. Does the engine have a
I have the Craftsman GT5000 24 OHV tractor lawn mower. It's been in storage for a while, I have replaced the battery, spark plugs, fuel filter, and oil. I can't get it to start. Does the engine have a pump primer? Any suggestions? It just turns and turns. I can't get it to start unless I put gas in the air filter then it will trun over but it won't stay running.
  • Craftsman Master
  • 2,478 Answers
Take fuel line off, fuel run out. If doesn't remove fuel filter, if not. Remove fuel cap, if not check line coming from tank.
Posted on Mar 29, 2015
    Master:
  • 381 Answers
Try blowing the main fuel line out with air if not getting fuel to the carb..
  • Deanna Waldrop
    Deanna Waldrop Mar 29, 2015
    Take the fuel line before or after the fuel pump??
  • Harrie Mar 29, 2015
    just see if any fuel is coming to the carburettor when you try to start. That is after the pump. If nothing comes there, you also can check before the pump. But when there is an air bubble in th pump it will come to the pump, but the pump will not be able to pump fluid. It can't produce a "vacuum" in air. It is a fuel pump.
    Top Expert:
  • 6,702 Answers
I assume the fuel is coming into the carburettor. A air bubble in the fuel pump will keep it from working correct.
  • Deanna Waldrop
    No gas is getting to the carburetor but gas is going into the fuel pump.
    when the bass is going is and you are sure the pump is working, press out the air. If there is no air in the pump, perhaps you need to replace it? But don't hurry replacing it. make sure the fluid is running through the pump and try again.
  • Craftsman Master
  • 1,169 Answers
Sounds like the carburetor needs a good ultrasonic cleaning as old gas will leave behind varnish and gum deposits clogging the carburetor fuel passages up.
  • 3 more comments
  • Deanna Waldrop
    that makes sense. I can't seem to locate a manual on this mower. Any suggestions on the best way to do the carberator cleaning? Is there a Carb Cleaner? Or is this something I would have to have done at a shop?
  • Eugene Rounds Mar 29, 2015
    The carburetor would need to be disassembe to clean properly.
    If you have expereince in doing this then there is two options on cleaning. One involve the old style dip cleaner and the other which is more enironmental and user friendly is ultrasonic cleaning methrod using soap and water.
    If you don't have the exprience or don't feel comfortable doing this then taking in into a repair shop would the next option.
Craftsman 917.270514 not starting?
check to see if your getting power to the solenoid on the bottom of the carb a bad safety switch will shut it off they also stick closed from old fuel
Jun 04, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a 15.5 hp ohv briggs n stratton on a craftsman riding mower when I engage the blades or let out on the clutch the engine dies out tried disconnecting seat switch ,replaced spark plug and fuel...
There is a switch underneath the seat that will shut the engine down if the mower is engaged and you are not on the seat...that switch is bad and it thinks you are not on the seat so it shuts you down...
heatman101
Aug 10, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have CraftsmanLT1000 lawn tractor, Smokes heavily.
Many times a dirty air filter will cause this on this style of engine. When the filter is plugged, it creates a 'rich' fuel condition, and the engine smokes heavily, the excess carbon is drawn into the air filter, and plugs it even more.
check spark plugs, air filter, fuel filter, choke linkages (for full choke/no choke operation) and crankcase oil.
Crankcase oil can become fuel contaminated, thus overfilling the crankcase and filling the crankcase breather with raw oil/fuel, and this is drawn into the air filter, plugging it, and starting this senerio.
If there is fuel in the crankcase oil, drain completely, and refill with fresh oil. Then you need to look towards the carb for an inlet needle sticking, broken, worn.
Nov 15, 2009 | Craftsman Garden
Stalling Craftsman LT 1000 Lawn Tractor
I have a Craftsman 21 HP Twin riding lawn mower and have replaced both spark plugs, filter and battery. New gas. New Oil....still will not start?? HELP!!!
Oct 11, 2009 | Craftsman Garden
Craftsman 17.5 LT1000 Won't Start - Need Help
pull the flywheel and check if the key(latter models the flywheel itself will need replaced if stripped)is damaged. This is a possibility.
May 27, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Lawn Tractor won't start Craftsman LT1000 17.5 OHV
The starter bendix is not engaging properly the bendix pushes the starter gear into the flywheel gear when the starter spools up, it may need minor lubrication.
It sounds like the engine is not getting fuel as it should, the main jet may be restricted from varnish if she stumbles under a load especially if the plug tips are white after running for 1/2 an hour.
Remove the float bowl and clean the jet, make sure the fuel is still good, gas that smells like a library is more like varnish and less like fuel.
Garden Logo
122 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
