Question about Gilmour Garden
I have a Gilmour 2gallon weed sprayer.that pressurizes the tank by wheels rotating. Inot holding pressure. Cant seem to find replacement gaskets or parts.any ideas?
3 Suggested Answers
SOURCE: sprayer wont spray or hold pressure
We use the both the 425 and 475 solo sprayers most days at work and when they start to lose pressure ( after 6 months of daily professional use) we purchase a complete seal kit and put it through them. The only part I can't work out how to remove is the inside cylinder, other than that everything else is easily removed and replaced.
Posted on Mar 27, 2009
Biggdex35
  • 333 Answers
SOURCE: Weee killer leaks from my Gilmour sprayer finger
Im pretty sure that is all it is. The pressure is by how many times you pump it up. Its just on or off. Sounds like It needs to be cleaned real good, and put soap in it befor you put it bak together. Also there is a screen if you hold the handle and turn the trigger part and unscrew it.
Posted on May 11, 2010
Testimonial: "Thanks for the reply Bigdex!"
Will not pressurize
Seals not sealing check cover rubber gasket and relief valve
Mar 05, 2014 | Gilmour W4 Spray Doc 4 Gallon Wheel Pump...
I have a gilmour xp30. The pump assembly will not pressurize/blow air out the exhaust port. (There seems to be a part rattling inside the cylinder). Can it be fixed?
there is an O-ring in the plunger tube that can slip of its channel seating if it becomes dried out. To put it back you need to disassemble the handle from unit. At base of handle is a lock that looks like a cross. It is difficult to turn because it has small protrusions at the ends that snap into holes in the collar. Once you turn them and the pop out the handle can be removed exposing the pump shaft. The O-ring is probably what you hear rattling and will be loose in bottom of tube. Just put it back into its grooved seat, slide plunger back into unit, rotate the x-lock till it snaps back into place and unit should work again. I have oiled o-ring but that did not last long and might get oil on plants. I now just spray some water down the top to lubricate the O-ring when it seems dry.
Aug 22, 2011 | Gilmour & Spray Doc& Poly Tank Sprayer...
How do i release the pressure in tank?
If you turn the top (fill) handle it should release the pressure. Sometimes you have to also pull the trigger at the same time you turn the handle.
Jul 15, 2011 | Stanley Lawn and Garden Deluxe Steel...
How do yo get the sprayer to actually spray there is no pump to build the pressure to let the spray out. Is there instructions to the sprayer I have missed placed mine if there was some in the box
Here is the web site link for your sprayers manufacture. on the bottom rt is the model you can choose yours and get the manual you need. as you know there is usually some way to pressurize the tank, either hand pump or air pump. This should help and if you need more help please contact me. Thank you http://www.gilmour.com/tips-tricks/
Jul 13, 2011 | Gilmour Garden
I am not getting pressure in the sprayer. Any suggestions?
Generally, the problem is either a leak or a bad pump. If you listen carefully and you hear air escaping try making sure the top is on tight (don't go nuts because you will never get it off again) Also many tanks have a gasket or O-ring under the lid. This is often lost or gets out of place, and then crushed by the lip. There is also a gasket or stopper thing at the bottom of the pump cylinder, sometimes this gets loose or gets a piece of stuff in it. It also could be the pump piston itself. HERE is the manual with a section on troubleshooting.
Be careful if you have used hazardous chemicals in it before.
Hope this helps, If it does please rate it.
Jun 18, 2011 | Gilmour Group #Xp20gt Green Thumb 2 Gallon...
Won't hold air & pump up/
I loss pressure, read the manual, took the slide out and saw that the o-ring was crimped out of shape, thus the loss of seal and no pressure! Popped it back to position and it spray is now powerful as day 1...patience is rewarded!
Sep 21, 2010 | Gilmour & Spray Doc& Poly Tank Sprayer...
I need assistance with properly setting the water flow, range, and rotation of the 993hps Gilmour Impulse sprinkler and the 967hzs Impulse Spike Base Sprinkler. There were not directions with the products...
For some simple instructions check out the "additional information" section at http://www.gilmour.com/Watering/Hose-End/Sprinklers/Large-Coverage/Metal-Head-Impulse-.aspx. If your sprinkler doesn't rotate, ensure that you haven't lowered the water pressure by opening another faucet elsewhere. My sprinkler doesn't rotate as freely as it did when it was new, but it probably just needs to be taken apart and cleaned and greased.
Aug 04, 2010 | Gilmour Mfg Metal Impulse Yard Sprayer...
Tank will not pressurize after pushing the pump handle down multiple times.
the reason it might not pressurize is there might be a hole in your tank or hose to the spraier itself if it has holes in the hose get a new one put it on the tank and handle. if hole in the tank duct tape it or seal it with a sealent. but it wont pressurize with a hole because the air comes in and out of the hole. hope this helps you
Jul 02, 2010 | Gilmour & Spray Doc& Poly Tank Sprayer...
May 10, 2010 | Gilmour 1 Gallon Lawn & Garden Spray Tank...
Garden Logo
256 people viewed this question
Top Gilmour Garden Experts
cackelberry
Level 1 Expert
Charles T Nevin
Charles T Nevin
Are you a Gilmour Garden Expert? Answer questions, earn points and help others
