On power up I get an error code B04666F6 on the printer screen. what does this mean?
2 Suggested Answers
elix0411
  • 3530 Answers
SOURCE: Screen says "Printer error."
Welcome to Fixya
If the error occurred when you were trying to use a feature of EASYSHARE Software:
  1. Run the Repair utility:
    1. Select Start > Settings > Control Panel > Add or Remove Programs.
    2. Click KODAK EASYSHARE Software.
    3. Click Change.
    4. Click Next.
    5. Select Repair, then follow the instructions.
  2. Try the feature again.
If the error occurred when you were installing or upgrading EASYSHARE Software:
  1. Uninstall your current version of EASYSHARE Software:
    3. Select Remove.
    4. Follow the instructions to remove the software.
  2. Go to the Clear Utility for KODAK EASYSHARE Software at www.kodak.com/go/clear, then follow the instructions to run the utility.
  3. After restarting your computer, go to KODAK EASYSHARE Software at www.kodak.com/go/easysharesw, and install the latest version of software, free of charge.
Thank you for using Fixya!
Posted on Mar 23, 2011
Error code E00000-0001
That error mean there is a sudden change in the fixing unit temperature.
First clear that error from service mode. Press additional function
press 2 and 8 together
press additional function agian
service mode should appear in screen
select copier
select function
select "clear"
select "err"
select ok.
unplug power cord for a few seconds and restart the machine
try to make some copies if problem persist replace the fixing heater assembly
May 29, 2014 | Canon imageRUNNER C5180 Color Copier
What does error code #e1 mean on Canon CLBP 460 PS mean?
Meaning of error code E1
The motor sensor or sensors, the DC controller on the main board DC controller.
I can not give solution to your problem, because possibility of damage main board.
I suggest you contact Canon Customer Support (e-mail, telephone, or repair contacts).
Nov 16, 2011 | Canon CLBP 460 PS Laser Printer
I have a new hp officeet pr 8500 printer but on start up the screen displays error code 0060 and then goes blank. how to fix?
This error means there's an ink leak in your printer. HP recommends that you turn the printer off (using the power switch at the back of the printer), wait 20 minutes and turn the printer on (condensation may be causing error and the printer needs time to dry).
Mar 12, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
What does error code 3501 and 3502 mean on advent AWP10 printer
Printer error code "3501" occurs right before a print job. A flashing screen will tell you that the printer cannot print due to error code "3501". These error codes are generally experienced when you use diagnostic sheet to print and change the ink over them. This error code could also indicate that buffer length of a print was not valid.
Jan 08, 2011 | Office Equipment & Supplies
Ricoh afico 811 error sc689 and sc547
sc547 is a power supply error that can mean you have a faulty power supply. The service manual does not list an sc689, and it's not in the help desk support database either... are you sure that's the code that comes on the screen?
Oct 05, 2010 | Ricoh Aficio SP C811DN-DL Printer
Error c-0510 shows on screen
Code C-0510 means a low fuser temperature. Most probable cause for that - the fuser lamp is probably defective. Try first to clear the error code (if the lamp is close to its life's end the code may pop up after a long print) so do this: power machine off; turn on the machine with the stop key held down; turn off, then on again. If this doesn't fix it then you need a new fuser.
Jul 05, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
I have an error on my w8200, on the screen
i have an error on my w8200, on the screen written ERROR E20D01,
what is the code mean?
Jun 04, 2010 | Canon W8200PG InkJet Printer
Error code E000019-0000, trying to find out what this error code means.
Hello sir; It's means waste toner bottle full, dump it after you turn off the power, then turn power back on.
Apr 29, 2009 | Office Equipment & Supplies
Whats error code 3501
According to Kodak, that error just means the cover was open. I noticed when I print a diagnostic sheet that error shows up whenever I change the ink.
Sep 02, 2008 | Kodak ESP 5 Printer
Error code 1201
The definition corresponding to this error message is this: "The print carrier stopped before all of the data was used." To resolve this issue, please do the following:
  1. Power the printer off.
  2. Remove all cables from the back of the printer.
  3. Reinsert the power cord.
  4. Switch the printer back on.
  5. Check the operator panel to see if the 1201 error message is displayed.
  6. If the error message returns, the printer could be defective. Contact Lexmark Customer Support for further troubleshooting and warranty options.
Nov 30, 2007 | Lexmark X4270 All-In-One InkJet Printer
42 people viewed this question
k24674
jasbo
jasbo
