Question about Husqvarna Garden
Looking for how to refit drive belt on my LTH1742
Mower had stick stuck in belt when removed there was no drive belt loose
    Champion:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • Husqvarna Expert
  • 250 Answers
The drive belt goes around the transmission pulley (located under the cooling fan) then attaches to the engine. You will then need to loop the around the idler set. You will find a "v" shaped pulley and a flat pulley. The flat fits on the outside of the belt and the belt fits down into the "v" pulley. You need to remove the tension of the idler set to fit the belt.
Posted on May 20, 2015
  • 81 Answers
SOURCE: Craftsman Mower Directions
Go to searspartsdirect.com and enter your model number in the space on the right of the page. When the list of illustrations comes up click on ground drive. This will show you the correct installation of the drive belt. Or do you mean " How the Heck do you put this on?"
Posted on Jun 19, 2009
harlan301
  • 205 Answers
SOURCE: Re: Craftsman 50
check your idler spring make sure its there and check your belt make sure it den't ride up over the pulley tran'y or engine if you have a two belt drive sys. check both idler and spring, and valuable drive pulleys. check your belts make sure you see no flat spots or cracks. let me know, good luck
Posted on Oct 15, 2009
SOURCE: JD mower L110, hydro drive. Reverse power is low.
i have the same thing a tractor shop told me thats ok they are slowed dowm for saftey
Posted on Nov 01, 2009
SOURCE: How can I refit the
I did it with a large screwdriver. Pressing the band with the flat end of the screwdriver pushed the drive band back under the drive wheel behind the gear mechanism at the rear of the mower.
When it was back under, manually rotating the blade made the band run free over the drive wheel
Posted on Sep 25, 2011
BAMOUT
  • 2478 Answers
SOURCE: 16.0 hp 38 in riding mower drive belt diagram
Your owner's manual will show and tell you everything.
Posted on Jun 24, 2012
I have a old lawn keeper edger with a briggs and stratton 2 hp engine. It has always run great but the belt came off and we cant figure out how to get it back on. Can anyone help with that?
If the belt just came off, it should be fairly easy to refit back on its pulleys. Use the largest pulley to assist in pulling the belt on by turning the pulley by hand. If the belt has broken, you may have to remove 1 of the drive shafts to slide the new belt over. I had a B and S powered mower which broke a belt and I had to strip off the end of the mower and unbolt the main drive shaft to slide the belt down. took me about an hour and a half. Glad they don't break too often. Ive heard of others who unbolt the motor and disconnect the clutch drive to fit a new belt. have a good look at the unit to see whats easiest.
Mar 22, 2017 | HP Garden
My Craftsman riding lawn mower LT2000 (2002/2003) stopped moving. The drive belt seems to be loose. The engine starts and cutting blade engages fine. Was working fine but stopped working when it started...
there should be a drive belt tensioner somewhere on the belt, it usually works off the clutch/brake, when you push on the brake it apply's the brake and also takes the tension off the belt to stop it from moving.
Not sure of your ride on mower but that is how my ride on mower works so I hope this helps.
May 19, 2014 | Craftsman Garden
How to adjust a loose mower deck drive belt?
check your pulleys to make sure they haven't split as this does happen. Adjust the belt tensioner to tighten the belt when you engage the clutch to drive the mower. You should be able to see the belt tensioner by dropping the cutting deck to its lowest point and looking underneath the mower to see which pulley actually puts the tension on the belt to make it drive. there is no need to start the mower to find which pulley needs to be adjusted, it should be obvious when you look at the belt and the pulleys.
Hope this helps you
May 17, 2014 | Garden
Mower deck drive belt keeps breaking
I HAVE A CRAFTSMAN 18 H.P. 3 BLADE 46" MOWER DECK.
1. THE PLASTIC PULLEY COVERS ON BOTH SIDES OF MOWER...WILL TRAP STICKS AND DEBRIS WHICH VERY RAPIDLY WEARS THOSE BELTS..I REMOVED MINE
IF IT IS RUBBING:
1. EITHER THE BELT HAS STRETCHED-REPLACE
2.THE SPRING MOUNT (WELDED TO DECK) GOT BENT...STRAIGHTEN
Jul 21, 2013 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Kia sedona instructions to replace serpintene belt
Hi, Here is the procedure for a 2002 KIA Sedona 2.9, Engine code KJ. I I can not guarantee the followingprocedure is exactly the same as your car.
Warnings and recommendations Unless otherwise advised by the manufacturer, the following procedures are recommended: Always fit a new timing belt after removal Check the tensioner and idler pulleys; renew if necessary Never turn the engine in the direction opposite to that of normal operation Check the belt(s) for cracks, fraying, wear and oil contamination Note: The engine must be cold before timing belt adjustment Note: Avoid bending, torsion or traction General Before disconnecting the battery cable, check the audio system security code kj_t_dba_uk_6.jpg
Always check the timing marks before timing belt removal Removal Disconnect the battery Remove the radiator upper hose Remove the fuel filter unit Note: Do not disconnect the hoses carniv_j3tci_t_dba_uk_3.gif
Remove the bracket Remove the right front wheel Remove the air-conditioning drive belt Remove the ancillary drive belt Remove the ancillary drive belt tensioner Remove the coolant pump pulley Remove the crankshaft pulley Remove the timing cover(s) kj_t_dba_uk_6.jpg
Remove the tensioner Remove the timing belt Check the gearwheels, tensioner and idler pulley(s) for damage and wear Renew if necessary Installation kj_t_dba_uk_6.jpg
Align the marks on the tensioner Tighten the tensioner (23.5 Nm) Rotate the engine 2 rotations by hand kj_t_dba_uk_6.jpg
Check the tensioner Repeat the procedure if required Refit the timing covers Refit the crankshaft pulley (373 - 392 Nm) Refit the coolant pump pulley (17.6 - 28.4 Nm) Fit the ancillary drive belt tensioner Fit the ancillary drive belt Refit the air-conditioning drive belt Refit the front right wheel (88 - 108) kj_t_dba_uk_4.gif
Fit the bracket (36.2 - 53.9 Nm) Refit the engine mount carniv_j3tci_t_dba_uk_3.gif
Refit the fuel filter unit Refit the radiator hose(s) Refill the cooling system Check for leaks Reconnect the battery earth cable Torque settings Tensioner: (23.5 Nm) Timing covers (6.9 - 9.8 Nm) Coolant pump pulley: (17.6 - 28.4 Nm) Special tools Special tools are not required
Jan 06, 2013 | 2004 Kia Sedona
I need to replace the drive belt on my lawn tractor.
Things You'll Need
  • Wrench set
Show MoreInstructions
    • 1Find out the driver belt's part number. This can be found in your lawn mower's owner manual.
    • 2Find a store that sells Craftsman lawnmower parts and see if it has your specific belt in stock.
    • Sponsored Links
    • 3Clean out the underside of your mower's deck, making sure there are no leftover pieces from your old belt still stuck inside.
    • 4Find your mower's tensioner, which keeps the pulleys in place, and loosen it (this usually involves loosening a single bolt). Then slide the pulleys closer together so that you can fit the belt over them more easily.
    • 5Arrange the driver belt over the pulleys (you should refer to your user manual for the exact configuration of the belt over the pulleys, since this will vary depending on the specific model of your lawn mower).
    • 6Tighten the tensioner back up, leaving only about a finger's width left of play in the belt.
Sponsored Links
Read more: How to Replace a Craftsman Lawn Mower Drive Belt ' eHow.com http://www.ehow.com/how_4826688_craftsman-lawn-mower-drive-belt.html#ixzz27K3g01yM
Sep 23, 2012 | Garden
I have a craftsman riding mower model # 971.274822 and recently replaced the mower drive belt. Although it is the correct belt, 42", it is really loose! How do adjust the tension? Thanks
there is no adjustment on the drive belts but you do have a clutch adjustment to do this you have to remove the mowing deck (NOTE) draw a digram of the way the deck belt runs adjust the clutch lever from the bottom of the mower, test mower with out the deck on and if this solves the problem reinstall the deck....
Jul 26, 2011 | Garden
I have a craftsman model 971.271552 riding mower. I was driving it and it made a noise. Now it will not move. I can push it in neutral, but not when in gear. The belt seems to be o.k. It starts and runs...
The transmission has given up the ghost. Pull the release pin - get it on jack stands and pull the batter. Remove the battery box and look for a tube sticking straight up from the transmission. Stick a straighened hanger down the tube and do a 'stick check' on the fluid level. Fill as needed.
Nov 03, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
