Question about Saeco Coffee Makers & Espresso Machines
Have a Saeco Rotel Conforta Coffee machine that makes the coffee really weak. Is it possible to adjust the size of the portion of beans ground for each cup? Thanks.
  • 2,039 Answers
Just answer it
Posted on Mar 30, 2015
    Habit-Forming:
  • Saeco Expert
  • 130 Answers
When you change the size of grinder,the new size come after 3 coffees.
Posted on Apr 07, 2015
dutchman05
  • 487 Answers
SOURCE: saeco italia
ok turn the machine on and wait till warmed up. Open door while machine is on and remove the dreg drawer. This you always need to do when the machine is on otherwise it will not reset.
flashing means dreg drawer steady means coffee beans
Posted on Apr 16, 2008
mirran
  • 515 Answers
SOURCE: Coffee too weak
What kind of saeco incanto do you have?
Posted on Jul 10, 2008
SOURCE: Saeco magic comfort coffee machine grinder
Empty beans out. Take the two screws out.
Put bean grade to 1. Run the machine as if making coffee. Use a vacuum and clean the bean grinding machine area. Run the machine again.
Place bean container back and put screws back in. Fill bean container.
This worked for me
Posted on Aug 30, 2008
EsWorld
  • 1618 Answers
SOURCE: grinding and dumping coffee without making a cup.
Check the grind it might be too fine, then check the screen under the red o-ring in the brew unit it might be blocked.
Posted on Feb 26, 2010
SOURCE: No coffee brewing with beans, but with coffee brewing with ground coffee.
make sure you use very dry non-oily coffee beans
Posted on Jan 31, 2011
Why does it brew weak coffee?
can depends many factors, try to grind finer coffe powder and warm well the machine before starting to brew coffee. If the grinder does not make finer coffe powder then you must contact the service, check if blades are in place before calling them...
Jan 19, 2016 | Saeco Vienna SuperAutomatica Coffee...
Hi, can you adjust the portion size of beans ground per cup for a saeco rotel conforta automatic espresso machine. The coffew is coming out fine, but too weak.
In the waste basket you got a nice round coffee puck i think you need to ajust the grinder its not chopping fine enough press for a coffee and put the dial down 1 like if your at 6 put 5 remmember the coffe you grind will take 2 coffe to reach try a couple and if your satisfied good if not go down on more try again
Mar 29, 2015 | Saeco Coffee Makers & Espresso Machines
Gaggia Titanium Weak coffee medium cup only produces a dash of water and weak coffee, also the ground is very course and I am going through lots of beans done the cleaning and re-calibration but still the...
The coarse grounds is definitely the problem. make sure your machines setting are near 5-8 depending on the beans you use.
You need to make 5 cups of coffee before you see the new grind size. Do not change the grind too often or you will not see what you are looking for.
If the coffee is still too coarse you may need to replace the grinder burrs. http://www.cerinicoffee.com/grinder-burrs-saeco-gaggia-asp.html
or you should take it to a service center.
http://www.cerinicoffee.com/espresso-parts/espresso-machine-service-center-new-york.html
Aug 11, 2013 | Gaggia Titanium Espresso Machine
My Saeco Odea Go only produces weak coffee (like water). Tried adjusting the grinder and also different coffee beans. Any ideas?
have you tried adjust coffee strenght?
This is the bean symbol on the bottom of the front control
Jan 23, 2013 | Saeco Odea Go
Saeco Italia coffee too weak - grindes too coarse
Remove beans from chamber, then remove the 2-3 screws in the chamber, then lift hopper slightly and turn adjustment knob towards the middle number, or halfway between fine and coarse. Then lower hopper make sure the gears line up together, set screws add beans and adjust finer.
Oct 08, 2009 | Starbucks Saeco Italia Digital Barista...
Coffee Beans do not grind
Try using the vacuum to clean out the grounds, then remove the brew unit and make sure the chamber from the grinder is clear.
Aug 11, 2009 | Saeco INCANTO DELUXE Espresso Machine
Coffee is too weak/light
I think I have the right manual. Page 29?
http://products.saeco.com/articolo.asp?id_linea=1&id_articolo=740823049
Jan 01, 2009 | Saeco 00034 Incanto Sirius Super Automatic...
Hello and good morning, I have the Saeco Magic model which has been absolutly fantastic, in the last couple of days my machine has been making coffee that has been very watery? How do I fix and could it...
You don't say whether your using ground coffee or beans if using beans chek that no one has altered the grind adjustment on the bean hopper. If using ground coffee it could be that the grind is too coarse not allowing the machine to extract the coffee.
Dec 20, 2008 | Saeco Magic De Luxe Espresso Machine
Bypass doser malfunctions
Happens when the preground coffee is not ground fine enough, you may have to put the pre ground coffee in a manual coffee grinder to make it finer. The machine is not really designed to brew regular coffee grounds.
Jan 20, 2008 | Saeco Magic De Luxe Espresso Machine
Coffee Makers & Espresso Machines Logo
191 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
