When I use Input 1 the sound is cracking and sounds really bad but when I use Input 2 it sounds great.
Is the problem the Input Module or the Amplifier Module>
    Top Expert:
  • Audio Player... Master
  • 12,962 Answers
Cannot be the amp module if it sounds great on input 2. The problem has to lie in the circuitry for input 1
Posted on Mar 29, 2015
Door locks and lights rapidly go on and off by themselves even after ignition is turned off
Sounds like you have a bad door sensor , an the BCM - body control module is seeing an input it shouldn't > Door Locks Go Crazy 1
Door Locks Go Crazy 2
Door Locks Go Crazy 3
Mar 12, 2017 | Cars & Trucks
My new Toshiba has a great sound system but the mic is bad.
1. IF THE MUSIC FILE WORKS WHILE PLAYING THE FILE THEN IT IS NOT AN ISSUE WITH THE COMPUTER
2. YOU CAN REMOVE THE SKYPE USING "REVO UNINSTALLER"
http://www.revouninstaller.com/
3. TRY RE INSTALLING THE SKYPE FROM
WWW.FILEHIPPO.COM
4. IF EVEN IT DOES NOT WORK THEN IT COULD BE AN ISSUE FOR THE SPEED INTERNET CONNECTION
BEST OF LUCK
Feb 07, 2010 | Computers & Internet
Dell Inspiron E1505 absolutely no sound anymore
1. remove all external peripherals.
2. use the internal speakers
3. uninstall / reinstall the audio drivers
4. reboot system
5. if still hearing the crackling sound check if cracking sound can be heard only inside windows of even in the bios.
6. check bios hdd if in acoustic mode performance if yes then set it to normal.
Oct 08, 2009 | Dell Inspiron E1505 Notebook
I HAVE A SONY 5 DISC DVD SURROUND SOUND THEATER SYSTEM. I'M TRYING TO CONNECT IT TO MY TV BUT I DON'T GET ANY SOUND BUT GREAT PICTURE.
Not really enough info here to help much yet.
Helpful info would be:
1.Are you hooking up coax or optical surround from the DVD and have you set the amp to look at the correct type of input?
2. I could be much more specific with help if knew the model number of the surround system and DVD changer.
Sep 12, 2009 | Sony Audio Players & Recorders
My pioneer sounds really bad
Check the antenna input...sometimes these come loose
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_aad3edb7dfa380b9
Mar 12, 2009 | Car Audio & Video
1993 Chevy Cavalier 2.2 not firing on 2 cylinders
you can test it but removing wires on the coil. they should have same strength as 1 and 4. if they are weaker then you have a bad coil. if nothing happens your have a bad module.
if you want put the 1,4 coil on the suspected bad tabs on the module and see if spark is same strength.that should do it. you pretty much did the right thing is swaping with what testing equipment you have to work with.
its most likely a bad module though. very common. when you test something always have someone explain how its tested and how it works.
Michael
ASE certified
Jan 24, 2009 | 1993 Chevrolet Cavalier
Sound no pic
Convergence ICs are STK392-110 you will need two of them they are available at the link I am posting and they give free instalation instructions with pics and free tech support so you can do the repair yourself.Heres the link.
http://servicemanuals.vstore.ca/
May 01, 2008 | Mitsubishi VS-50501 50" Rear Projection...
Sound pops and cracks on coax only.
While there are other possibilities, this is a problem which is commonly caused by bad solder connections that form in the tuner. When you're using the video sources the tuner is out of the picture (sorry, I couldn't resist a pun) so you don't see any problem. It's relatively easy to fix, but it means removing the tuner from the board inside, opening the tuner and resoldering the bad connections. This is a nice TV, so it would be worth getting an estimate for the repair. Because of the time involved, many technicians would rather simply pull the tuner and put in a replacement. See if you can find one who will repair the tuner instead. I always did when I was on the road, and it didn't really take that long. It saves the cost of an expensive part.
Apr 22, 2008 | Sony KV-36FS17 36" TV
Bad speakers
it might be due to 1 speaker paper jammed or defective 2 any capacitor in sound might be defective. 3 check for proper supply to sound section 4 check components in sound section like ic etc. 5 loose contact or print crack in sound section hope this will help.
Sep 22, 2007 | Sylvania 6427TE 27" TV
134 people viewed this question
 Grubhead
Grubhead
