Question about Dryers
Need to know how to disassemble dryer so I can figure out what parts I need to fix it
  • 3,519 Answers
Way to go Brian!
You're a true handyman at heart.
Start off by unplugging it. Work safe or watch TV!
Many dryers have a hinged top that lifts up at the front. You have to slide a thin blunt blade like a drywall knife into the little gap between the top and the front. a few inches from both sides there will be an obstruction that is the latch device. Use your blunt blade to gently push this towards the machine, and lift the top at the same time. It should come up. Same thing for both sides and the top will lift.
There will be screws visible on the back. If you undo them, parts will separate from other ones so keep track of what you're doing.
It's usually easier to take things apart than to put them back together, so take your time and enjoy the adventure.
Message me to let me know how it's going.
Posted on Mar 29, 2015
How to disassemble hair dryer
I don't have any indication of what model or brand of hair dryer you have, but a lot of portable electric accessories have one or 2 hidden screws under a brand label or some stick-on instructions. If not, need to know brand and model #'.
To answer on your comment about "dryers" instead of "hair dryers", I assume that the incoming messages are scanned quickly for key words and slated in the most likely category. That's my take on this. Good luck and let me know if you found any screws.
Mar 08, 2014 | Dryers
Need to change back exhaust to side on model wed5500bw
There is a knock out on the side and you will need to get the elbow from the appliance parts store near you. If you need more help let me know. You will have to disassemble the dryer to do this.
Jan 22, 2014 | Whirlpool WED5500XW Cabrio 7.4 cu. ft....
The Caster is warn beyond repair and i cant seem to find anyway to replace it and was wondering if i could Order this older part from somewhere Directly
I have found that RepairClinic.com has parts for most appliances and thier web sit is easy to navigate. The last time I had to work on our dryer (whirlpool) I had to dis-assemble it from the back. A little advice. figure out how to get it diis-assembled before you order the part you think you need, with me, I innevitably find more parts that are worn out as I'm disassembling. I normaly try and ket on the Mfg web sight and print off a technical manual.
Good Luck with the Project.
Jan 16, 2011 | Kenmore Dryers
Jura F9-inside part fell off while pulling the tray. Cannot fix.
Kris I have this same problem. Did you figure out how to replace the flap or did you have to take it in for repair.
Does anyone else know how to replace this plastic flap?
Feb 24, 2010 | Jura Capresso Impressa F9 Espresso Machine
I need to replace a dryer belt on a Kenmore gas dryer model number 110.73032102. The belt part number is 2925.
Not sure where you got that part number but the true part number for the belt on your dryer is 3387610
The service manual detailing the disassembly and repair of your dryer can be downloaded at link below. Be sure to unplug dryer before proceeding to disassemble::
http://www.mediafire.com/?5gmg0jyji4t
Nov 05, 2009 | Kenmore Dryers
The stainless steel drum/tub has a large tear in it. We have been trying to patch it until we are able to figure out if the drum/tub can be replaced. Does anyone know if it can be replaced & is it...
That sucks. I've been informed by LG technical support this is a non serviceable part. what that means in short is, the part is not available thru LG.
If anyone knows of another fix, or an aftermarket part they may be able to point you in that direction.
I've come across this only once with a client of mine, and we could not repair her 3 yr. old dryer. needless to say she was very upset with LG. Look around at some local used appliance parts outfit if possible, otherwise it's a new dryer.
sorry I couldn't actually provide a "fix".
good luck
Sep 27, 2009 | LG Dryers
Do not know how to open up machine to look inside
Hello willdano,
Here is a link to the LG Website. Included in this link are all the service details, specs and documents you will need to repair your dryer. http://136.166.4.200/contents/Laundry/DLG5988.htm If you access the service manual, check out page 29 & up for disassembly details on how to access the internal hardware. Hope this helps.
Regards,
Rick
Jan 04, 2009 | LG DLG5988 Gas Dryer
Kenmore dryer not spinning---how do i disassemble to see if belt or motor is bad?
kenmore dryers are the easiest dryers to work on. unplug! remove 2 screws @lint screen top. insert screrwdriver under top @ each end and pop top up. disconect wires to door panel. remove 2 5/16 screws at each end inside. lift front door panel up and out.( the bottom of the panel is held by spring clips. replace belt if broke. remove drum if not and check rollers. note: belt route at idler pulley.
Jul 19, 2008 | Kenmore 75944 Gas Dryer
Dryers Logo
54 people viewed this question
Top Dryers Experts
