Question about Ski-Doo 2006 GTX Sport 600 H.O. SDI
My engine sputters between 10 and 20 miles per hr and fouls the plugs after a while
If 360 km per hour is equal to 40 miles per hour, please show me how to calculate using formular
360 km/hr is NOT 40 miles/hr.
1 mile is about 1.6 km
To go from km to miles, multiply by 0.62
To go from miles to km, multiply by 1.6
Kilometers per hour to Miles per hour
Feb 23, 2017 | Cars & Trucks
I took spark plugs out of 2001 Ford Ranger 3.0L to place plug fowlers in. Spark plug will fit in fowlers, however; fowlers will not fit in engine. Placed plugs back in engine and now will not start.
Sounds like that car is the proverbial POS. Did you check for spark? - need a strong one with a car burning that much oil and the plugs getting fouled like that. Need to replace those rings!
Nov 30, 2015 | Ford Cars & Trucks
Mazda 323 1.4 1999 misfire at 65 miles per hour going up hill
Have you ever changed your spark plugs?Check that all the plug wires are tight.If that all fine then probably a cylinder coil, all easy fixes
Aug 10, 2014 | Vehicle Parts & Accessories
I put 2,720.00 worth of work into my 97 Pontiac grand am. Engine light is flashing the car sputters and might get up to 40 mile per hour I took it out on the road again and got it up to 75 mile per hour...
Sounds like who ever did the work on your car needs to go back and check the plug wires to see if they are going to the right plugs. and check the fuel filter, and fuel pump pressure. I would also check the Catalytic Converter to see if it is stopped up, if so replace it. Check the throttle position sensor with an ohm meter, if bad replace it. Check the oxygen sensors as well. I am running out of Ideas, so I hope this helps.
Aug 10, 2013 | 2001 Pontiac Grand Am SE
I have a 2004 ford f150, accellerating to 50 to 51 miles per hr it will sometimes miss. is this a fuel injector problem? shows no codes, please any suggestion
Probably not probably a coil or plug..If it a 5.4 or 4.6 its probably a coil pack but if you change it change the spark plug with it..or sometimes the problem will come due to a fouled plug because of the bad coil
Sep 04, 2011 | Ford F-150 Cars & Trucks
How would you convert 40.32 km/hr to m/sec
There are 1000 m in a km and 3600 sec in an hr. Thus, multiplying 40.32 km/hr by 1000 m/km gives 40320 m/hr. Dividing this by 3600 sec/hr gives 11.2 m/sec.
Of course, the two operations can be done in the other order.
Some calculators have unit conversions built-in. Without knowing the make and model of your calculator, I can't tell you whether yours does so or not, let alone tell you the keystroke sequence to do it.
Jun 09, 2011 | Office Equipment & Supplies
Can the ignition coil cause the car to sputter and foul the plugs
It can cause sputtering but it wouldn't really cause the plugs to foul. Try pulling the plugs and getting a good look at the electrodes and you can get a good idea of why they're fouling by looking at them. Here's a good guide with some pictures to help you:
http://www.gnttype.org/techarea/engine/plugs.html
Jul 25, 2009 | 1998 Dodge Neon
Acceleration - cannot get above 40 miles per hr.
If the engine revs up while in drive and running at 40mph, your transmission is probably slipping. Try checking your transmission fluid level. If it is OK, I would get it by a garage to have them look at it to cofirm.
Mar 30, 2009 | 1998 Land Rover Discovery
2007 cobalt engine hesitating during acceleration
any ck engin lights could be bad gas or spark plug or coil pack braking down
Dec 18, 2008 | 2007 Chevrolet Cobalt Coupe
Plug wire burn spots, spark plugs fouling, loss of power, misfire
optispark distributor fails. go to summitracing.com and search optispark. it'll pop right up
Nov 18, 2008 | 1996 Chevrolet Camaro
Ski-Doo 2006 GTX Sport 600 H.O. SDI Logo
515 people viewed this question
Top Ski-Doo Winter Sports Experts
Todd Arndt
Todd Arndt
ptpumpman
David Harrelson
David Harrelson
Are you a Ski-Doo Winter Sport Expert? Answer questions, earn points and help others
