Question about Repair Manual for 1994 - 2004 Chevrolet S-10 & GMC Sonoma Pick-ups
Diagram of the three lines going to the charcoal canister on a 1996 4.3L Oldsmobile Bravada
Where do the lines connected to the charcoal canister go to?
  • 21 Answers
Diagram of the three lines going to the charcoal c - 25614136-qps3j2yy2ysvp4eblaxbrbbb-1-0.gif
#14 is the canister...left line runs to #15 Evap Purge Solenoid, middle line runs to #11 Evap vent valve, Right line runs to #8 Roll over valve.
Posted on Jun 07, 2015
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
On 89 toyota pickup 22re 4x4 On my efi i have a gas filter with 3nips where do those vaccum lines go??? Or even better a vaccum diagram for all lines... thankyou
The fuel filter only has 2 hoses, an in and an out. The thing with more hoses is the gas tank evaporative system, and they go to the charcoal canister, the intake manifold, and the gas tank. The filter is usually in back next to the gas tank, where the pump is, so that the pump never runs dry. But some times it is up front. Often is it threaded on. The 3 lines are for the charcoal canister though, and it not the filter.
Jun 02, 2015 | Cars & Trucks
Where is the charcoal canister on an 1996 Oldsmobile Bravada ?
DIY? you will need a repair manual later anyway. Try your library, Your auto parts store should carry the manual, or try filepeep.com or manualslib.com. It should be near the fuel tank fill access, or nearby, perhaps close to the tank.
Or google images. you may find a picture and location.
Mar 27, 2015 | 1996 Oldsmobile Bravada
Where is the charcoal canister located on a 1996 Oldsmobile Bravada ?
Should be on the driver side near the rear axle.
Its usually right under the rear door.
Mar 26, 2015 | 1996 Oldsmobile Bravada
Charcoal canister location
Under the middle of the car towards the driver side. If you look under the driver side passenger door you should be able to see the vent lines going to it.
Nov 05, 2013 | 2001 Oldsmobile Aurora
Where is charcoal canister on 2001 olds bravada
I am not exactly sure what you are referring to as the "Charcoal Canister" But you can check out this website for any and all parts with Diagrams to your particular vehicle. Click here: http://www.gmpartseast.com/oldsmobile/components/2000-bravada-2wd_vapor-canister-lines-ts035760103-l35mw1s10506.html
Jan 14, 2013 | 2001 Oldsmobile Bravada
Diagram for gas tank hoses on 1999 oldsmobile bravada
It depends on which one is leaking. You should have two fuel lines from the pump plus two or more lines for the vapor recovery. The lines for the pump are under 50-70 PSI.
I don't have a diagram.
Jun 26, 2012 | 1999 Oldsmobile Bravada
Gas leaking from charcoal canister after i changed fuel filter, pump, clean egr change egr solenoid. ????
The canister got loaded for a reason, what that may be is hard to track down, let it dry out and see if it happens again. This can be caused by over filling the fuel tank i.e. topping off.
Jun 25, 2012 | 1991 Oldsmobile Bravada
1998 oldsmobile bravada fuse box diagram
On this website you find fuse box diagram and description for Oldsmobile Bravada (1998)
Oldsmobile Bravada 1998 fuse box diagram Auto Genius
Nov 22, 2011 | 1998 Oldsmobile Bravada
I need to replace the canister purge solenoid so I need a diagram.
No need,just go to your charcoal canister and the only thing that has an electrical connector is the solenoid.There will be several vacuum lines connected to it as well.
Dec 19, 2009 | Pontiac Montana Cars & Trucks
Repair Manual for 1994 - 2004 Chevrolet S-10 & GMC Sonoma Pick-ups Logo
159 people viewed this question
Top Haynes Vehicle Parts & Accessories Experts
Vernon Taylor
 Mikey
Mikey
swaffken
Are you a Haynes Vehicle Part and Accessory Expert? Answer questions, earn points and help others
