Question about Acer Aspire V5-122P-0643 Silver 11.6" Notebook 1 GHz AMD A6-1450, 4 GB DDR3, 500 GB HDD, AMD Radeon HD 8250, Windows 8, LED Backlight
FIXED!!!! New Fan cured the problem. What would make it sound like an old hard drive revving up while the fan is running? Is there a second fan in this platform?
I pulled the fan and cleaned it , but it sounds like a second fan with a dry bearing is inside the unit in the same general area.
    Top Expert:
  • Acer Master
  • 51,486 Answers
No just one not room for 2
Posted on Apr 27, 2015
Upon starting my truck I hear the sound of rushing air for about 30 seconds then ok; why?
I would say more than likely it the radiator cooling fan. For some reason some vehicles, no matter what temperature, the cooling fan clutch engages which makes the cooling fan run at full speed like there's no fan clutch.
It sort of makes it sound like the engine is revving up but it's simply the sound of the rushing air from the fan clutch making the cooling fan spin at full speed.
Hope this helps.
Feb 21, 2015 | 2001 GMC Sonoma Extended Cab
There is humming sound coming from the computer and the green light below the power buttom is flashing.
You didn't list the make and model, what is this light for? Power light, cd drive, etc...
Jul 08, 2008 | Computers & Internet
Why does my sky+ box sounds like there is a fan running constantly
Because it has a fan in it!
The hard drive and other processing electronics needs more cooling than passive convection can supply. Your fan has been running from day one. Maybe it's getting old and noisy which is why you are noticing it now
Sep 04, 2014 | Televison & Video
I have a 2006 Scion XA. Few days ago noticed revving sounds while driving the car. Originally thought engine was revving but noticed RPM gauge is normal. The humming/revving sound starts about 20 mins...
under the bonnet on the radiator is an automatic fan, now if the radiator is low or you need to replace the coolant in it or top it up but the car may need a service and let them know the problem.
Jan 27, 2014 | 2006 Scion xA
ViP 612 DVR hard drive is always running. I don't beleive it did this when it was new. At least I never heard it. It's about 2 years old. It is not the fan. The unit vents are clear. Tried reboot. No...
The function is always in use because of the ability to pause live tv and rewind. So its very common for the hard drive and fan to run often on DVR receivers. Does it still allow you to record programs? The best option would be to unplug it for 10-15 seconds which sounds like you have done. If the sound is becoming overbearing we can send a replacement receiver.
Nick Franta
DISH Network Customer Service
Jan 23, 2011 | DISH Network ViP 612
Hard Drive keeps revving???
What do you mean by revs? The noise gets increasingly louder? I doubt you should be hearing the hard drive. It may be a fan that changes under load or temperature. Have you contacted the manufacturer or the repair facility to inquire about this issue? Otherwise if you know someone with the technical capability. I would take the case off and you should easily be able to distinguish then if it's the fan or the drive. Do you know what fan it was that needed to be replaced? Once I have more information I can assist you further.
Thank you,
Lee
May 04, 2010 | HP Pavilion a1610n PC Desktop
Does my notebook need a new heatsink/fan?
If your fan spins at all it is not a problem with the fan. It might be a heat sensor on your motherboard that was not reading correctly.
Now your fan will only run when it needs to so the best thing to do is replace your hard drive and go from there. You can get a hard drive from Best Buy and if that doesn't fix it then your can just return it and buy a new laptop. Or if you want to keep the hard drive just buy a USB enclosure and use it as a backup drive for your pictures, music, etc. Don't go buying a fan if the fan still spins. But a part that can be easily returned first.
Apr 26, 2010 | Gateway MX6453 Notebook
My vaio vgn-cs320j makes a loud spinning noise that comes and goes every few seconds or minutes. Is it the fan not working properly or some other issue, or is that just what the fan sounds like? if it is...
Usually Sound from Notebook are from CPU cooling fan and from Hard drive.
But It's hardly occur in the case of Hard drive.we called it Hard drive failure and the only solution for this is new replacement.
Your problem could be CPU cooling fan not working properly. Open the Notebook ( it will be easy if you refer to manual on how to open) and start the system now, you will be able to pinpoint what causes the sound.
Clean the CPU cooling fan with an air blower and re-check if the problem still persists.
If OK,then close the Notebook otherwise replace the CPU Cooling fan with a new one.
Jan 13, 2010 | Sony VAIO VGN-CS320J Notebook
My Compaq nc6000 laptop sometimes wont turn on. Ill hit the power button the fan will kick on for about 7seconds or so and the lightning bolt symbol will stay lit. normally the hard drive lights, power...
old old old laptops, with windows 2000 or XP, (doomed for sure there both are VIRUS MAGNETS AND ZERO SUPPORT NOW)
a circa 2006 LT. (3+ years before W7 sold)
now the power fails. (could be a blessing....)
NO OS stated, what operating system is on this old dog.
XP?
Fans dead, means power failure.
BIOS dead, same or screen dead.
does external VGA screens work, not if it shuts off sure.
step 1 is does it run with the battery out, main battery huge. does it?
click Laptops black screens of deathhh here.
http://pcdied.com/black-screen.html
windows can freeze for many reasons, 1000s.
but is 2, in truth corruption or power loss.
you push the power button, battery out.
you hear fans,see lights but vastly more important
are the BIOS messages on the screen.
on my HP's power on, battery out. line cord in AC jack and power pack connected
we push power, and the screen always shows
"hit ESC to setup BIOS"
or some other key on OLD DOGS.
it must
if not you have no power. easy no?
if this works and the hot key ESC (0r your prompted )
key works, and bios screens work what is next
the HDD and its corrupted OS.
we then in a real shop boot to live windows PE stick or CD or Linux CD. live.
omg the the computer works and is bad OS on my old dog HDD.
May 23, 2017 | HP Computers & Internet
Revving Sound
its your rad fan if its not broke leave it alone runs cool, live with it !!
May 30, 2008 | 1996 Dodge Grand Caravan
Acer Aspire V5-122P-0643 Silver 11.6" Notebook 1 GHz AMD A6-1450, 4 GB DDR3, 500 GB HDD, AMD Radeon HD 8250, Windows 8, LED Backlight Logo
54 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
