How do you replace shaft seal on the washing drive?
My husband purchased the shaft seal but can figure out the right way to install it. Can anyone help? Thanks!
  • Anonymous Mar 28, 2015
    Sorry, should say he can't figure out the right way to install it!
  • Washing Mach... Master
  • 5,323 Answers
Try using youtube put in ur model and what u need
Posted on Mar 29, 2015
the dr
  • 447 Answers
SOURCE: Kenmore Front Load Elite Washing Machine
You must ensure the boot is properly seated on the outer tub, There is a groove in the lip of the tub and the boot,make sure grooves are fully mated. Also try getting a new clamp; the screw can back out releasing the tension,also fold the excess clamp that passes through the screw over backwards preventing the clamp from loosening, a few dabs of good super glue helps too and can still be removed (dont use much a few drops in four places is sufficent).
Posted on Sep 27, 2007
larryyb
  • 291 Answers
SOURCE: Direct drive Sears top load washer shaft seal
they make a special tool to replace it and you can pick one up at a appliance part house and they dont cost much
Posted on Nov 25, 2008
  • 17 Answers
SOURCE: maytag atlantis mav 9501 washing machine
YOU NEED SPEACIL TOOLS TO TAKE THE BEARING
Posted on Feb 08, 2009
  • 53 Answers
SOURCE: my amana model ALW460DAW washing machine is
Amana are known for there triple lip seals to leak. Replace the whole kit and it will last a little longer.
Posted on Sep 25, 2009
Testimonial: "the suggestion was helpful, it will save me from doing the job twice."
  • 30 Answers
SOURCE: I have a Fisher &
I would call Fisher & Paykal ask if the seals can be changed ? I know Maytag all the seals are easy to replace yours should be no diffrent.
Posted on Feb 19, 2011
Truck is leaking oil and keeps popping out a seal
Any seal that pops out like that is indicative of a bent shaft. As the shaft turns it oscillates the seal until it wiggles free. There wasn't an internal circlip that goes in after the seal was there? If there was, there would be a narrow machined channel just inside the casting. If that was missing, any movement would allow the seal to come free.
Sorry to hear of the passing of your husband. I was widowed in 1996 and in Feb 2014. Life has to go on and improve.
Jun 17, 2016 | Ford Cars & Trucks
Hotpoint wmf560 aquarius washing machine
BIG JOB !!! The whole machine has to be stripped down. Ie/ The complete bowl assy has to be removed from the machine, the outer bowl separated from the inner bowl, the main seal removed, and the bearings pressed or knocked out of the housing in the rear of the outer tub. If the bearings have failed , it would be almost certain that the drum shaft has worn and or been damaged. You will need a set of bearings, drum spider shaft assy, and main seal. If its an older machine, it may not be worth it.
Apr 13, 2015 | Washing Machines
Stator rubs against rotor
Go to YouTube with your model number,make,bearings change.
Apr 25, 2013 | Kenmore HE2 Plus Front Load Washer
How to pull auger drive shaft for Hobart 4346 mixer-grinder?
The oil seal is the resistance you feel. take a soft mallet or hammer with a soft drift and gently but firmly tap the stub shaft and it will drive out the oil seal in the hopper direction.The lower skirt of the tapered bearing is what contacts the seal so go slow.
Worked for me.
Jan 23, 2013 | Hobart 4346 Meat Grinder Mixer Chopper...
Had a problem with my machine and figured out it was the bearings and the shaft. have replaced those and put the machine back together. Is now running better than ever BUT now have I leak!! any help/s
What was the condition of the bearing surface of the shaft where the seals rubs against in. Did you replace the shaft? To replace seals and bearings needs to be done properly. the bearing surface where the neoprene rubs against the shaft must be the correct size and bearing surface must be polished, otherwise the shaft's pitted surface will quickly grind away the neoprene seal's surface which comes in contact with the shaft. To replace the shaft you will need a hydraulic press to press the shaft out, as well as a good quality bearing puller. For these reasons I advise the DIY expert to avoid doing this kind of work. When the seals go, its cheaper to buy a new machine then undergo other problems associated with rebuilding a machine. Never use washing powder which accumulates and can be very abrasive to the seals. Use something like Cold Power, Green Earth or etc as a liquid detergent
Dec 17, 2011 | Fisher and Paykel Washing Machines
I have a 2004 Saturn ION 3 QC, my husband has replaced the struts and cv joints with new seals and now there is a transmission fluid leak on the drivers side- did the seal not seat correctly?
That is a very strong possibility, however I think that your husband would have made certan that the seal was seated propperly. So all you can do is change the seal again. Make sure you inspect the cv shaft where the seal rides for any vissable damage sharp cut marks, dents or scrapes. Also lubricate the in side of the seal with some grease upon installation. Take care when slidding the cv shaft into place so no damage can occure to the seal. Good Luck, From Ernie @ RedDeer, Alberta, Canada.
Jan 10, 2011 | 2004 Saturn ION
Kenmore 80 Series washer leaves brown grease marks
Remove the agitator and check the shaft seal underneath the plastic drive block at the top of the shaft. Move the shaft in different directions to check the condition of the top bearing. If none or very slight, replace the seal at the top of the shaft supporting post. Clean any grease that is outside of the seal when you are done. Be sure to not damage the seal surface on the shaft when removing/replacing the seal and pre-grease the new seal's inner lip before installing.
Nov 15, 2009 | Kenmore 22422 Top Load Washer
Does the drum have to be removed to replace both bearings and oil seal on an indesit wash machine type we16
No, remove the drive belt pulley and remove the 8 bolts holding the x shaped cast iron frame with the bearings in, lay the washer face down (ensuring adequate protection to the door and controls) whilst pulling the x shaped frame away from the drum tap the threaded shaft lightly with a rubber faced mallet and the frame will come away complete with bearings and seal. To replace the frame (with new bearings and seal installed) I used a large socket and long bolt to draw the shaft through the new bearings.
Aug 05, 2009 | Washing Machines
How do i replace lever seal?
http://www.partstap.com/ Hi you should be able to find instruction on this site as well as parts thank you for useing fixya please take the time to rate me
Feb 25, 2009 | Dishwashers
Oct 25, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
