Question about Dryers
The remote operates fan functions fine but will not turn light off
    Genius:
  • 1,617 Answers
Make sure you have the correct wattage for bulbs.
Posted on Mar 30, 2015
Honeywell Marston Ceiling Fan. Why has remote stopped turning the light off?
Dwayne, Try a new battery in remote, if that does not fix, replace your remote, replacements can be found at the larger hardware stores, eg. home depot, lowes,etc.
Apr 03, 2016 | Dryers
I have a sony s-master digital amplifier which will not power up: when I plug it i to power it takes about 30 minutes before the red standby light comes on but no other functions operate.
So the standby indicator never changes state? If so, more than likely, your amplifier has DC Offset(a damaged amplifier inside) which will keep the speakers off, and disable any use of the front or remote functions. If you are interested in having your Sony repaired, please refer to my website, audioserviceclinic.com. You may contact me there. Thank you.
Jul 11, 2015 | Audio Players & Recorders
The remote transmitter for My Hampton Bay Windward III 54" ceiling fan operates all fan functions properly; however, the lighting functions do not work with my remote. How can I check out problem?
The good news is that the fan functions properly. Now, do the following.
1. Turn off power to fixture at the breaker
2. Remove batteries from remote and press all buttons to eliminate a stuck button as a cause. Reinstall batteries
3. Turn on power and test operation of remote. Be sure to hold dimming button down until lights respond
Jan 29, 2013 | Hampton Bay Dryers
I have a brand new Kichler Ceiling Fan/Light installed in new home. This one for the M-Broom came with Remote UC7206T. The function which controls Fan and Fan speed works fine but I cannot the Light...
Something that may work (based on my experience). Shut off power to the fan (the circuit breaker). Remove the battery from the remote and push all the buttons just in case one is stuck. Reinstall the battery. Turn the CB on. Check operation using the remote.
Dec 29, 2012 | Kichler Lighting 300106OBB Ceiling Fan
My Callaway II ceiling fan transmitter shows that air is being pushed down. However, the ceiling fan is actually pushing air upward. I've tried everything I can think of to get the transmitter and...
If I recall, this fan has no external switches that can be operated - all of the fan and light functions are controlled by the remote alone. If this is indeed the case, there is little that can be done outside of hoping the problem is with the remote itself. If that is the case, replacing the remote is likely to be cheaper and less labor intensive - that is if you can find one.
From what I have read, this fan is no longer in production nor available for purchase. You may have luck bringing the remote to Home Depot - the main (possibly the exclusive) distributor of the Hampton Bay brand to see if they have fans on display that make use of remotes for fan and light control. If so, try to see if all your remote functions work. If you find that the reverse function no longer works - you should ask the sales associate about how to go about ordering a replacement remote. If the remote fails to work at all, you can 1) try a "shot in the dark" about ordering a an exact replacement remote - with the hopes that the remote itself is defective - rather than the paddle fan, or 2) start new by buying a new paddle fan with hardware switches for fan speed, direction and light operation AND a remote control module to perform a whole replacement of your existing paddle fan.
The "add on" remote control gives you many of the benefits of the remote only fan - but also provides a "back up" way to operate the fan should the remote or module fail. Had this been the style you have currently, you could operate the fan by hand until the remote and / or ceiling module was replaced.
I hope this helps and good luck. Please rate my reply. Thank you.
Jun 01, 2011 | Hampton Bay 46056 Callaway II Ceiling Fan
Remote does not operate ceiling lights or fan.
Hi fan was aorking fine then when u first turn fan on it made nosie .Now fan or light wont come on , i check power its fine
Oct 31, 2009 | Hampton Bay 52 In. Ant. Brass Redington...
Light remote control stopped working
most of my fan controls have done this to me. you know the reciever is working cuz the fan works fine. you need to dis assemble the remote completely and clean the contacts for the light button. mine are two small black dots that seem to keep getting slimey and wont work till i clean them, then all works like brand new again.
good luck.
Aug 21, 2009 | Hunter 52" Ceiling Fan With Light And...
Remote control ceiling fan
Possibly a bad circuit board in the ceiling fans remote function. I would suspect that the circuit board has a thermal issue where once warm it works fine. The most common fault that I have seen is a bad solder connection on the board. Pull the board from the fan and check all solder connections for cracks or dull solder. If you see any of these then reflow the solder connections. If this does not work you probably will need to order a new board from the manu.
Jan 26, 2008 | Dryers
Dryers Logo
46 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
