Question about Maytag Washing Machines
How do I fix my Maytag Centennial commercial technology washer.
I have a maytag centennial commercial tech. washing machine and when it is on rinse cycle the water fills the machine, but it does not agitate it just drains out. I have tried 2 loads and it does the same thing. What can I do to correct this problem? Model mvwc300bw0
  • Maytag Master
  • 5,323 Answers
No agitation? first use a meter and check ur water pressure switch? that is what sends the machine the message to start wash cycle? You can test it with a meter and with a manual test? ( first locate it in the panel, it has a plastic clear tube hose going into it, remove that tube from its connection, now put another small tube or hose into the slot where it was and have the machine set to wash cycle with water in it. Blow into the other end of the tube. If the machine starts to wash. the pressure switch is more than likely good. now take the original hose tube and plug one end and blow into it the other end, it should be hard and have pressure, if it is easy to blow and u dont feel any pressure and it feels like the air is going out ? sometimes they get busted open or a pin hole and release air causing the water switch diaphram to not open. if both check ok then next the motor coupler or belt if belt driven. check with a multi meter for continuity the door switch, and if there is a little movement on wash cycle in 1 direction only then check the cam dogs in agitator.
Posted on Mar 29, 2015
How do you clean out the drain pump maytag centennial washer
Maytag & Whirlpool & Kenmore Washer Pump Repair ...
? 3:44
https://www.youtube.com/watch?v=97rBObh_3mQ
Sep 12, 2013 - Uploaded by ApplianceVideo.com
Repair your own Maytag Top Load Washer which has the following ... Took me awhile to unclog as an entire ...
Washer Won't Drain - Pump Clogged with Sock - Repair ...
? 1:53
https://www.youtube.com/watch?v=tHT7PmmFc9w
Dec 2, 2011 - Uploaded by Tomahawk DIY
Washing machine pump clogged with a sock. ... I searched hi and low trying to figure out why my washing ...
HE Maytag Centennial Washer Fix - YouTube
? 31:43
https://www.youtube.com/watch?v=CoTlOr3Gxuk
Nov 15, 2013 - Uploaded by mike3000ace1
So how do you open the washer to pull out the Manual? .... +mike3000ace1 Hi, I have a 2011 Maytag ...
Maytag Centennial Washer Drain, Transmission ...
Jan 05, 2016 | Maytag Washing Machines
Repair manual Where I can download the repair manual for the maytag centennial washer
This is a manual. Since there are so many versions, you might need to search for the appropriate one. I searched for "Maytag centennial top load washer repair manual". There was a Maytag site, but download was very slow. http://applianceassistant.com/ServiceManuals/8178628_ml-3_maytag_centennial_top-load_washer.pdf#zoom=100#scrollbar=1#toolbar=1 http://applianceassistant.com/ServiceManuals/8178628_ml-3_maytag_centennial_top-load_washer.pdf
Jul 30, 2014 | Maytag Centennial Top Load Washer
Maytag centennial commercial technology washer, having intermittent trouble with controls, wondering how to acess controls to clean connections ?
There are two 1/4 inch hex screws on the back of the control panel and a pair of metal tabs at the base that hold the panel assembly together. I found this video on youtube that illustrates how to take the assembly apart.http://www.youtube.com/watch?v=7yxjNiAKvYwI fixed mine by just cleaning the contacts on the auto load sensing switch.
Nov 12, 2011 | Maytag Centennial 3.2 cu. ft. SuperSize...
Owner's Manual For CENTENNIAL Commercial Technology Washer - Model No. MVWC6ESWW1
Maytag has many of the manuals for their washers available at their site. Go to https://www.maytag.com/webapp/wcs/stores/servlet/OCManualsLiteratureSearchView?catalogId=10562&langId=-1&storeId=10212&krypto=5QgxQhneFliXuEuX564wSQ%3D%3D&ddkey=http:OCManualsLiteratureSearchView and enter the model number of the washer.
The direct link to the manual for the Maytag Centennial MVWC6ESWW1 is https://www.maytag.com/digitalassets/MLPDF/User%20Instructions%20-%20W10330943.pdf . Additional manuals are available here https://www.maytag.com/webapp/wcs/stores/servlet/OCManualsLiteratureSearchResultView?catalogId=10562&langId=-1&storeId=10212 . (This includes the manuals in Spanish, installation guide and parts list.)
I hope this helps.
Aug 06, 2011 | Washing Machines
Washing Machines Logo
150 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
