Question about Pentair Minimax NT Heater
Ignition is locked out unit will not fire - Pentair Minimax NT Heater
  • Pentair Master
  • 1,631 Answers
I on the other hand, have found just the opposite of the previous answer. The minimax NT, Has been a very decent heater for my customers.
A lockout, is really a very simple problem to find. It is due to Not having the ability to ignite the raw fuel, that is coming out of the gas valve. So if you are getting a walkout, and everything is fine, except for the problem, you should be smelling a very strong gas odor.?
if you are, then that tells you that sensors are good, and the gas valve is good and the ignition control box is good. You probably have a bad hot surface igniter. Replace it and you should be good.
You can confirm this safely: first shut off the gas on off valve near the year. That will stop gas flow. Now after you have turn the power off to the heater for a minute or so, turn it back on and create a call for heat. You will hear the fan blower motor engage, but if you seconds later you will hear a click that will be the relay in the ignition control Module or Grey box sending power to the igniter, you will then see a bright red glow, or you 'should' see a bright red glow in the heaters burner tray area.
Then you will hear a slightly louder click which is the gas valve opening, sending Raw fuel to ignite with the bright red glow. But there will be no ignition because you have the valve turned off, this is for safety reasons. And that you're going to have the exact same problem after a few attempts, which is going to be a total of three attempts before the heater goes into a lockout mode.
but the purpose of this test, is to see if you achieve the bright red glow? If you don't, then you did confirm that your hot surface igniter, has failed, and needs replacement.
Posted on Mar 31, 2015
    New Friend:
  • 60 Answers
Turn it off at the black toggle switch inside the front panel or turn it off at the breaker for 2-3 minutes
Then try again.
Check that flow is good, gas is on ect...
Is it saying lockout on the display?
If not then as you fire it up after cutting power keep the panel off and watch the ignition control red diagnostic light.
The blinking sequence of that light should point you in the right direction. There is typically a label that will tell you what the blinks mean.
Minimax nt heaters are on borrowed time, and in most my Delong with them once they start having an issue it will never end , basically they are lemons and replacements for them is very common
Posted on Mar 28, 2015
How do I get my gas stove to fire?
Mine has the same problem, turn the knob thing so its on.. press and hold the gas buttong and ignite it with an ignitor, after igniting keep holding the gas button for another 20-30 seconds and you're set.
Sep 04, 2014 | Heating & Cooling
H150 heater shows 1f
IF is ignition failure. Verify that you have a good Ignitor and that your gas supply is adequate to fire the unit. I rarely see the internal gas valve fail on any Hayward unit. Be careful if you have to put your hand in there. The electric circuit on the smaller heaters is not typically 24VAC, it is usually 120VAC in the U.S.
May 24, 2014 | Hayward H-series Electronic Gas Pool...
I have a pool heater RP 2100 you set the temperature it calls for the spark -then there's usually a poof and the flame icon comes on, and the heater heats up. Now set temperature, Calls for heat -the spark...
make three attempts to get heater running. most electronic ignition heaters will lock out after 3-4 times. after it locks out error codes should present themselves.....such as ignition failure, prs, etc.
ensure proper gas and water pressure. check voltage supplied to your raypack's igniter aswell. if heater fires up then instantly shuts off, then it may be the flame sensor
Oct 04, 2013 | Pool & Spa
Diagnose Ignition Control Module
means unit tried to fire 3 times then locked out turn off then turn back on check ignitor
Feb 07, 2018 | Sta Rite STA-RITE IGNITION CONTROL MODULE...
Ilo display when trying to turn on heater
ignition lockout. heater has tried to fire up 3 times without success. after three attempts unit will temporarily lock itself out
Apr 09, 2011 | Raypak 2100 Pool Heater Gas 266000 BTU'...
How do i adjust the coil on a echo pole saw to get the right gap to make it fire. and also is there a way to check the coil to see if it is firing
The correct air gap is 0.3mm, slacken the ignition unit screws, slot a feeler gauge passed the ignition units metal core, turn the flywheel around to allow the feeler gauge to get sandwiched between the units core and the magnets, now re tighten the screws. If the machine still has no spark, i fear it is a new ignition unit required.
Mar 09, 2011 | Echo Garden
94 Fatboy, I replaced the coil and ignition, still no spark in the rear cyl, top winding. This bike is a Calf. model. Thanks ............ Dennis Sailor. Cocoa Fl. Steves Cycles...........
By the way you're talking, the bike is equipped with a single fire ignition. Your use of the term "top winding" indicates that there is a "bottom winding" or two windings on the coil. A single fire coil will have three small connections on it. A dual fire coil will only have two primary connections. In the dual fire system, both spark plugs fire at the same time where they fire individually on the single fire. Please check the ignition system out further and tell me if it's a stock ignition system or some type of aftermarket system. Either way, no spark to the rear cylinder indicates a bad ignition unit.
Good Luck
Steve
Nov 14, 2010 | Harley Davidson FLSTF - FLSTFI Fat Boy...
What does a Ignition Lockout (red LED blinking 3 times) mean? Pilot light and main burner will not fire up.
Hi, on most all heaters you will have a chart somewhere on this unit, a code chart that will tell you what it means. It had to try and fire 3 times before it locked the module out do to a open safety switch, flame roll out switch, or a open pressure switch. Look, as they paste them on a panel or somewhere on the unit. If you have no luck, please use my user name below and I will look into it more for you. Send me all of the information to this unit. Keep me posted.
Sincerely,
Shastalaker7
A/C, Heating, & Refrigeration Contractor
Aug 02, 2010 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Mini max plus 150 fails to fire
It appears that the boiler is going into hard lock out. This is caused by successive ignition failures for some reason. After 3 attempts to light, a high limit trip, low water flow, etc, the unit will lock out and will require a power reset in order to reset the ignition control. You should have the cause investigated to ensure safe operation.
Aug 10, 2009 | Pool & Spa
Pentair Minimax NT Heater Logo
221 people viewed this question
Top Pentair Pool & Spa Experts
Jay Finke
Jay Finke
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
