Question about Exercise & Fitness
The belt I need is the motor drive belt, not the treadmill belt.And what it say's on the motor is A17265Mo14. I need the right part no or belt size.thank you!
    Problem Solver:
  • 11 Answers
Its on the belt itself, you will need to perform basic mechanical work etc.
Posted on Mar 28, 2015
Bremshey treadmill maintenance treadmill belt slipping
Fit new belt ,check for slide adjuster slots.
Aug 13, 2014 | Exercise & Fitness
Motor gets hot
You will want to check the condition of your belt and deck. When a running belt has excessive wear, it creates a lot of friction which causes the drive motor to work harder. When the drive motor works harder it will start overheating. If the belt is not lubricated periodically, it will ruin the deck, the drive motor, and cause other electrical problems such as tripping the breaker [after a while, the circuit breaker on the treadmill will need to be replaced.
It is suggested to lubricate the belt every month.
Dec 11, 2013 | Precor M9.1 M9. Treadmill Motor Working...
Treadmill runs 5 minutes stops
There could be other possibilities causing the treadmill to stop but one of the most common issues is excessive wear on the belt/deck.
It is suggested to lubricate the belt every month. At this point, you may need to replace both your deck and your running belt
Dec 01, 2013 | Precor Exercise & Fitness
Pathmaster 8.0 treamill model 21-3688a fix
Drive Belt Installation for Treadmills
The drive belt is used by the motor to drive the treadmill walking belt via the front roller pulley. A drive pulley is mounted on the roller and the roller has knurling or a sleeve to help it drive the walking belt. The treadmill console detects the current speed of the treadmill by monitoring the movement of a magnet mounted on the front roller pulley with a reed switch or by using an optic switch which monitors an optic disk mounted either on the front roller or on the motor shaft. If the sleeve moves to the side, you will not be able to keep the belt centered and many optic disks can be warped if pushed to the side by the sleeve if it moves, but we do have replacement sleeve kits if needed.
Steps to Replace Drive Belt-
1) Remove the safety key and unplug the treadmill from the wall outlet.
2) Remove the screws securing the motor hood and gently remove the motor hood.
3) Using an Allen wrench provided with the treadmill, loosen the two rear roller adjustment bolts until the rear roller comes into contact with the walking board. Turn the bolts and equal number of turns on each side and keep a count of how many turns you made so you will know how to properly re-tension the walking belt.
4) Remove the drive belt from the motor pulley. Place a screwdriver between the pulley and the belt and turn the pulley by hand. Use the screwdriver to guide the belt over the edge of the pulley. Be careful with the screwdriver to prevent damage to the pulley.
6) Mark the position of the front roller axle on the front roller bracket above the front roller adjustment bolt using a Sharpie marker so you will know where to put the bolt back into position. Remove the front roller adjustment bolt if your treadmill's front roller has a pitch adjustment bolt. If your treadmill does not have exposed roller bolts you will need additional instructions. Please see the troubleshooting section on our website for further help.
7) Gently slide the front roller from out of its mounting position on the frame. Do NOT remove the roller from the walking belt.
8) Slip the old drive belt off the roller and loop the new drive belt onto the front roller pulley.
9) Replace the roller back into its slot on the pulley side and re-tension the front roller pitch bolt to its proper place using the Sharpie mark as a guide.
10) Using the screwdriver, loop the drive belt over the motor pulley. Many Icon units originally had the drive belt misaligned by design (if you can believe it). This was to use the side load of the drive belt in order to keep tension lower. It does lower amp draw for the machine and replacing a side load drive belt occasionally is much cheaper than replacing a motor and/or controller so if your original drive belt was off-centered, install the new belt in the same manner.
11) Re-tension the walking belt.
12) Plug in the machine and check the drive belt for slipping. You can use some automotive fan belt dressing on the grooved or contact side of the belt to help it with grip on the pulleys and it will treat the belt as well. We prefer using belt dressing rather than over-tensioning the belt for the aforementioned amp reasons as well as additional stress placed on the drive system parts.
13) Replace the motor cover and test.
14) Make sure the walking belt is not slipping and is properly aligned and your treadmill is ready to use.
Copyright 2009 by TreadmillDoctor.com, Inc.
All illustrations, photographs, and scanned images, and text are the property of TreadmillDoctor.com, Inc. and may not be reused, retransmitted, copied, given, sold, or bartered to any third party. The recipient of this property is authorized to use it only in the manner expressly indicated by a staff member of TreadmillDoctor.com, Inc. All rights reserved.
Jul 09, 2012 | Exercise & Fitness
Belt stops during workout and have to step offf
you need LUBE in according with the instruction manual maintenance schedule . You have a deck belt worn 2) Test the drive Belt for replace 3) Test the input voltage motor, if there are the motor need repair 4) Test the output voltage from motor board, for input main motor, if there are NOT the board is faulty.
RUN the software calibration for easy diagnose and troubleshooting. See my personal TIPS for HELP.
sincerely. God bless you
Apr 27, 2012 | Treadmill Doctor PROFORM 770 EKG TREADMILL...
I have a Reebok treadmill. The belt stops while the motor continues while walking on it. What could be causing this to happen?
the drive belt is too loose. you need to tighten the belt that drives the front rolller, which drives the walking belt. depending on the type of treadmill there shoudl be a way you can do this by loosening the motor and adjusting that to tighten the belt. it could also be that the belt needs to be replaced and also could be the walking belt. you should try to tighten the walking belt first. that is at the end of the treadmill where you walk on it. there are two holes one on each side of the treadmill where teh belt goes back under the treadmill. there are allen key bolts that you need to tighten clockwise one turn then try the treadmill. if it doesnt tighten then turn another full turn. if not tight enough then it might be the drive belt. if you tighten the walking belt all the way then try to tighten the drive belt.
Jan 28, 2011 | Reebok Exercise & Fitness
I have a NordicTrack EXP1000. The walking belt was so far to the left that the edge began to fray. So, I adjusted the belt towards the right and now it slips forward now and then when it gets up to 3mph or...
If the walking belt slips when walked on, first remove the key and UNPLUG THE POWER CORD. Using the hex key, turn both idler roller bolts clockwise, 1/4 of a turn. When the walking belt is correctly tightened, you should be able to lift each edge of the walking belt 2 to 3 in. (5 to 7 cm) off the walking platform. Be careful to keep the walking belt centered. Then, plug in the power cord, insert the key, and carefully walk on the treadmill for a few minutes. Repeat until the walking belt is properly tightened.
If their is still slippage then the drive belt will need to be adjusted.
Find the motor mounts. Many motors in Icon treadmills have a main pivot joint in which a bolt runs the full length of the motor mount. This bolt will require loosening to provide maximum adjustability. Find the set bolt(s) on the motor.
This is typically run through only one side of the motor mount or may be on both sides but it does not run the full length of the mounting. Loosen this bolt but do not remove.
The drive belt must be tensioned by hand. While one person applied increased tension to the drive belt, the other person should tighten the motor set bolt(s) that are described above. Tighten the bolt and test. If the problem is not corrected, if problem persist replace drive belt
Jun 11, 2010 | Nordic Track Nordictrack Exp1000 Treadmill...
The treadmill is loose. How can this be fixed?
If the problem is in the drive belt, either the drive belt will stop when stalled or the front roller will stop when stalled. Follow this procedure: First remove the key and UNPLUG THE POWER CORD. remove motor shroud, then find the motor mounts. Many motors in Icon treadmills have a main pivot joint in which a bolt runs the full length of the motor mount. This bolt will require loosening to provide maximum adjustability.
If your treadmill is not equipped with a bolt as described above, the drive belt must be tensioned by hand. While one person applied increased tension to the drive belt, the other person should tighten the motor set bolt Tighten the bolt and test. If the problem is not corrected, repeat steps above and retest.
If the motor, drive belt, and front roller continue to turn when the walking belt is stalled, the problem is with the walking belt slipping on the front roller. Follow this procedure:
First remove the key and UNPLUG THE POWER CORD. Using the allen wrench, turn both rear roller adjustment bolts clockwise, 1/4 of a turn. When the walking belt is correctly tightened, you should be able to lift each side of the walking belt 3 to 4 inches off the walking platform. Be careful to keep the walking belt centered. Plug in the power cord, insert the key and carefully walk on the treadmill for a few minutes. Repeat until the walking belt is properly tightened. Rear Roller Adjustment Bolts
If the drive belt continues to turn but the front roller stalls, you may have a broken front roller pulley and front roller must be replaced.
Follow this procedure: First remove the key and UNPLUG THE POWER CORD. remove motor shroud. Loosen the rear roller and remove the two adjustment bolts. Some models have a spring loaded tensioner on the right hand side so be careful when removing these bolts. After the bolts have been removed, remove the rear roller end cap(s). The rear roller should now simply slide out of the walking belt.
Remove the motor hood. Using a black permanent marker, make a mark on the front roller adjustment bolt on the motor compartment side at exactly where it fits flush with the roller so you will know where to retighten it later. The adjustment bolt is on the right hand side of the front roller. Then remove the bolt with a 7/16” wrench. then remove front roller and replace with new reverse procedure mentioned above
May 16, 2010 | Proform Sport 1000 Folding Treadmill...
The belt is slipping with each step
At the end of of the running belts2_bing.gif in the end caps will adjusting bolts you will need a allen wrench to adjust the tension. Start your treadmill2_bing.gif and turn clockwise a 1/4 turn each time see i f you can stop the belt. You need to be aware that the drive belt can also cause this problem so I suggest that you remove the motor shroud and when you are adjusting whether the front roller is moving and the running belt has stopped or the roller has stopped and motor is rotating ( adjust Drive Belt)
Mar 01, 2010 | Proform XP 590S TREADMILL Drive Motor
Have a 4.9 treadmill and cant get it to adjust if i loosen bolts in back it slips if i tighten bolts on motor it quits pulling when i put weight on it can you help
Ok I really need more info but let's take a stab at it. The bolts in the back of the rear roller adjust the belt right and left. It also tightens and loosens. Ok there is also a drive belt from the motor that needs to be tight. Generally you should be able to twist the drive belt about 45 degrees. If it's more than that it probably needs to be tightened. If this is loose it will affect the walking belt the same as the walking belt being loose. So when your walking belt is slipping, make sure you tightened the right belt. Tightening the wrong belt can lead to other problems. Tightening the walk belt with the rear roller- turn both bolts clockwise equally to tighten. Remember the walking belt will travel to side with least tension. So to center belt, adj left or right side to fine tune. If belts are adjusted properly and machine stops when you walk on it, you have other issues. Could be the deck ( the board under the belt) and belt or the motor.
Nov 17, 2009 | Proform 6.5q Treadmill Walking Belt
Exercise & Fitness Logo
50 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
