Question about Tools & Hardware - Others
How do you adjust depth on rapesco brad nailer electric
  • 15 Answers
SOURCE: how to remove brads jammed in the nailer
Open the top where the plunger is...remove the jam and push the plunger back..close up the gun and you should be fine. Make sure you disconnect your air hose first!!!
Posted on Jun 08, 2010
SOURCE: my black and decker 18v brad nailer will not shoot brad
I had a 12v b&d brad nailer that stopped working.It would just blink & blink (red light on tool). I took it to b&d service center, and I was sent a new 18v nailer. Now I've had this nailer less than a year, I
believe this is the 2nd or 3rd time I use it. It's doing the same thing
as the 12v. I just use it around the house. The batteries are good.
I 've also had the charger go bad and the batteries. which have also
gone bad.
Posted on Jul 11, 2010
  • 1388 Answers
SOURCE: My Stanley Bostitch SB-1850BN brad nailer will not
You may have a broken tip or bent driver. Remove tha nails from gun and dry fire into a piece of wood. You should see a nice little indention. If you continue to hold the trigger and the nailer against wood after firing, the driver will stay in the lower position for examination. Just fire into wood and keep gun against wood while holding trigger and lean gun to side untill you see the tip. If you see broken tip or no tip order repair kit that includes driver, or driver alone from www.bostitch.com or ebay. Good luck
Posted on Sep 09, 2010
  • 119 Answers
SOURCE: My Dewalt 18v nailer consistently
I did not understand all you said but I think you are not using right nails (16 ga. Angled paslode nails)
Posted on Jul 12, 2011
wentlanv
  • 710 Answers
SOURCE: Describe your NT50AE2 2" Brad
Hi Randy,
Welcome to fixya!
Copy and paste this web address into your browser and a webpage will open with your nailer on it: http://www.hitachipowertools.ca/en/Products?cat=29&pid=254
Scroll down the page to the bottom of the description and you will see the owner's manual listed. Click on that and you can download and print a copy.
Please place a vote when you accept this solution. Thanks,
Handie Andie
Posted on Aug 21, 2011
NT50AE2 Hitachi brad nailer depth adjustment
Go back to the dealer and ask for help if its a problem with the receipt is always within 8 days Exchange possibility if something does not normally functioned.
This must not be a problem.
Jun 18, 2016 | Hitachi Nt50ae2 18 Gauge 34" To 2" Brad...
How do I fix my craftsman electric brad nailer
I have one that looks just like the illustration and mine doesn't operate either. I have had it apart and the switch is faulty and seems to be a very poor design.
Mine has a different brand name (Rapesco) and under the label is a generic Chinese export which the local supplier reckons is a throw-away item and no spares are available.
One of these days I will exercise some guile and attempt a repair.
Feb 02, 2015 | Craftsman Electric Brad Nailer
Hi Randy,
Welcome to fixya!
Handie Andie
Aug 21, 2011 | Hitachi NT50AE2 2" Brad Nailer with Case
Our Brad nailer model SB-1842BN is well oiled but it will shoot the brads just a little into wood or not at all. Help!!
Can u adjust the drive depth on the tip of the gun? My nailers all have a knob to adjust the drive depth. Also, what pressure are you using? I typically shoot mine between 90 and 120 psi. Hope this helps.
Jul 17, 2011 | Stanley Air Tools & Compressors
Bn125a nailer not sinking nails all the way
The depth to which a fastener is driven is controlled by the depth adjustment
knob (A) Fig. 19 below. The depth of drive is factory adjusted to a nomimal setting.
Test fire a fastener and check depth. If
a change is desired, rotate the
adjustment knob (A) Fig. 19: the
adjustment knob has detents every 1/4
turn. Rotate the knob clockwise (see
Fig. 19), to increase the depth of drive,
rotate the knob counterclockwise to
decrease the depth of drive. Test fire
another fastener and check depth.
Repeat as necessary to achieve
desired results. The amount of air pressure required will vary depending on the
size of the fastener and the material being fastened. Experiment with the air
pressure setting to determine the lowest setting that will consistently perform
the job at hand. Air pressure in excess of that required can cause premature
wear and/or damage to the tool.
Good Luck
Nov 26, 2010 | Porter Cable Cable BN125A Factory -...
How do I adjust the depth of the brad nail on the porter cable BN 125A brad nailer
Hello. To adjust the depth of the nail you have to increase or decrease the air pressure from the compressor. Look at the compressor and you will see a knob or dial that you can turn to increase or decrease the air pressure. Do this adjustment in small increments testing the nailer by driving nails into a scrap of the same material you will be driving the nails into on the actual job. Increasing the pressure will drive the nail deeper and decreasing the pressure will drive the nail less deep. Joe
Nov 10, 2010 | Porter Cable Cable BN125A Factory -...
I have a Porter Cable brad nailer BN125A, at 125 PSI and depth adjustement turned to the deepest drive setting, the brad does not set flush with the surface. Problem?
A brad nailer in good working order, set to the deepest setting and using 125psi should almost shoot the brad through the wood. If you have been oiling the gun properly (three to four drops at he beginning of your work session and again in the afternoon if under constant use) then you probably have some worn o-rings inside the gun. Porter Cable makes a driver maintenance kit (PN1001 60062) for your gun that will make it work like new.
Oct 04, 2010 | Porter Cable 18 - Gauge Brad Nailer and...
I have a Stanley Bostitch Sb 2IN1 2 In 1 Narrow Crown Stapler/18 Gauge Brad Nailer gun. How do I adjust the depth the nailer shoots the brad nails into base boards? I see that their is a dial on the back...
look on the front of the tool.there is a dial right where the plastic meets the yellow housing.also look closely and you should see a diagram on the plastic telling you whitch way to go.
Jun 12, 2010 | Stanley Bostitch Sb 2IN1 2 In 1 Narrow...
Brad nails not in all the way
There are no adjustments on any electric stapler / brad nailer that I've heard of , only the pnumatics. The electric staplers/brad nailers only work well in softer woods
May 26, 2009 | Arrow ET200 Electric Brad Nail Gun
Tools & Hardware - Others Logo
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
