Question about Pool & Spa
Where can I get rebuild kit for the pump of my Aker swirlbath model CT26060B0? The seal is leaking at motor shaft end of pump.
  • 1,631 Answers
That is great, that you posted a picture of the motor....
but unfortunately the motor does not have a seal. It is the wet end that is connected to the motor which makes a pump, and that has the mechanical shaft seal.
if you remove the cover of the wet end, and expose the impeller, then remove the impeller, and expose the shaft seal, we would be able to assist you better. A picture of the wet end and post it, will greatly assist as well.
unfortunately the information that you provided, although very much appreciated, really does not assist. Because the manufacturer of the tub, can use a variety of different vendors for the pump. But,...
if your tub came with a serial number? You can contact the manufacturer and they may have records as to what pump was used on your specific unit. And then from there you would be able to know what pump or more specifically...which Wet End, was used and then you would be able to find out which mechanical shaft seal went into that pump or Wet End!
if I was to venture a guess: it is either a
U.S. Seal PS 200 or PS 201
Posted on Mar 31, 2015
john224
  • 1378 Answers
SOURCE: need to disassemble pentair dynamo pump to replace
Remove the cover from the back of the motor and lock the shaft from turning. Then spin off the impeller.
Posted on Jun 13, 2009
john224
  • 1378 Answers
SOURCE: hayward pump has a steady water leak between pump and motor
Replace the machanical seal in the pump. It seals the shaft opening through the pump and is about a $5 - $10 part.
Posted on Aug 17, 2009
  • 151 Answers
SOURCE: Proline Pump 8D-10-1n11CB. This is for a pool and is leaking from the shaft to the motor
The pump seal is bad on the unit. This requires disassemble of the pump unit. Remove power to the unit, dissasemble pump housing, remove the impeller from the shaft of the motor by removing the allen screw with an allen wrench. Seperate pump housing from motor remove the old seal replace seal. Lube motor shaft with a little clean oil or wd40 to facilitate easy install thru new seal,reassemble in reverse.
Posted on Jan 17, 2010
macdirk
  • 116 Answers
SOURCE: I replaced the motor on my super 2 pump with a new
Most likely leaking from either the shaft seal, or the valute seal (big seal plate o-ring). When you replaced the motor you should have also replaced the shaft seal. If not go back and do that whether it's leaking or not. If you get your head down and look at the bottom of the pump while it's running you should be able to see the water coming from the joint between the seal plate, and the seal plate housing, or just behind that from the bottom of the motor probably from the vent holes in the motor housing. If it's coming from the motor then the shaft seal is leaking, and the water is traveling along the shaft and out the bottom of the motor. This will eventually get into the motor and seize up the bearings. If it's coming from the valute seal, then you need to either replace or re-seat the seal. As a general rule you should always replace the shaft seal, and diffuser and seal plate o-rings when you replace the motor or split the seal. I'm not as familiar with the 2 speed hayward super 2, but the standard super 2's have a small ribbon seal, often called a rubber band. They are infamous for going bad especially after pulling the pump apart.
Posted on Sep 18, 2010
jdvillanueva
  • 2098 Answers
SOURCE: I have an Aqua-flo Flo-Master
Yes this is replaceable, click this LINK.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Posted on May 09, 2011
The jets on my aker Swirlbath are coming on by themselves in the middle of the night. What is the remedy for this problem?
Some tubs with air jets have a sensor that detects water in the piping and cycles the air pump to blow out the water in the air jets. Make sure the faucet is not dripping as the water leaking into the tub could be causing the pump cycling problem.
Hope this helps.
Bob
Aug 11, 2014 | Home
Aker swirlbath manual
Any manuals for the Aker by Maax bathtubs will be available directly from Maax, who makes the Aker brand bathtubs.
Feb 22, 2014 | Home
My Aker Swirlbath pump hums but ther is no water action when I turn it on
Air Switch Repair
It sounds like you have a bad air switch located in your motor.
The air switch is what the air hose connects to on the back of the motor or on the box on top of the motor. The other end of the air hose is connected to the air button on the lip of the tub.
This is a latching air switch and when you push the air button it latches to send power to the motor. When the air button is pushed again it opens the latch in the air switch and stops power going to the motor shutting it off.
US Parts Center
Jan 11, 2014 | Home
My new pump leaks around seal plate
Leaking wet ends are a result of a bad shaft seal.Check to make sure it is installed properly or install a new shaft seal to prevent more leakage.If the motor runs and it will draw the leaking water into the motor and ruin your motor.Change the shaft seal as soon as you are able to prevent further motor problems.
Rod
US Parts Center
888-521-6813
Mar 02, 2013 | Pool & Spa
Spa motor is leaking
This is something you can do on your own.
The leak is either coming from the shaft seals or from the volute-face plate O-ring.
Most likely it is the shaft seals. You'll need to know the brand of the wet end (pump housing) to get the right seal, the motor manufacture doesn't help.
Jul 23, 2012 | Pool & Spa
I have a 1 1/2 HP Magnum Force Pump by Jacuzzi. After making some strange grinding noise, I opened it up to find lots of white powdery material flaking off where the Seal Housing (#18) meets the motor...
Thank you for posting your question here on Fixya.com.
Yes, the seal has been leaking and it needs to be replaced; probably the motor bearings too.
Removing the impeller requires you lock the shaft as you turn the impeller off counter-clockwise. To lock the impeller you will have to remove the motor end cover or a cap covering the shaft end depending on which version your particular motor has. Look at the end opposite the pump and imagine a shaft from one end to the other right in the center.
Once you remove the cover you will see a slot for a screwdriver, a flat for a wrench, a hex hole for a hex key or some combination of these. Lock the shaft and spin off the impeller. Some are so tight you will end up breaking them in the process. Simply replace it and the seal. Be sure the motor shaft is in good enough condition to allow the new seal to work properly. If too much shaft material has rotted away the new seal will leak soon after it is installed; you would need a new motor at that point.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. You may also contact me thru our website at www.arrowpools.net. Positive feedback is appreciated once your problem is solved!
John
Apr 08, 2011 | Jacuzzi MAGNUM FORCE POOL PUMP 2 HP...
How do you remove the impeller to replace the seal kit?
John
Dec 29, 2010 | Waterway Above Ground Hi Flo Pump
Leaking #1 pump on Arctic Spas Cub hot tub.
I found out that the pump impeller can be unscrewed from the motor shaft by turning the impeller while keeping the shaft from rotating. There is a brass shaft coupling embedded in the back side of the impeller. This allowed me to remove the leaking seal assembly inside the pump by tapping it out gently. However, instead of just replacing the seal, I decided to replace the entire pump with a newer version. Cost was only about $25 more than replacing the seal and gaskets. The pump-motor assembly has been reinstalled in the spa and there are no more leaks.
Dec 03, 2009 | Waterway Spa Pump Executive 56 Frame 4hp...
Water leaks between motor and pump can't get motor off
hello there this may help you out ok
best regards michael
Leaking Pump in a Whirlpool DU810DWGQ1 Dishwasher by Samurai Appliance Repair Man
function ReferThisPage779b7841ed943a9e880964fef6da376b(){var rtp;rtp = window.open('http://www.tellafriendking.com/refer/?URL='+escape(document.URL)+'&CODE=779b7841ed943a9e880964fef6da376b&JS=1','_blank','width=350,height=530, resizable=yes, status=yes, scrollbars=yes');if((null==rtp)||'undefined'==typeof(rtp) ){alert( 'The \'tell a friend\' window was prevented from opening.\n\nPlease temporarily disable your popup blocker.');}rtp.focus();}document.write(""); rn-spa-g.gif document.write(""); 3548679745_8c188ff0d2_m.jpgLeaking Pump in a Whirlpool DU810DWGQ1 Dishwasher
These are cheesy, inexpensive dishwashers that are prone to leaky pumps, as shown here (click the pic for the larger, annotated view).
3548734637_17f81a0e1b_m.jpgWhirlpool DU810DWGQ1 Dishwasher Pump and Motor Diagram
The problem is usually a leaky shaft seal kit, shown here as Items 7 and 8 (click the pic for the larger, annotated view).
Fortunately, the shaft seal kit is inexpensive; but it can be a ****** to install, depending on how much rust you’re dealing with. May require a destructive removal of the impeller, too, but ain’t no thang ‘cuz the shaft seal kit comes with a new impeller. Here’s a nice, purdy picture of a brand new shaft seal kit. And just to help motivate you a little more, the money you save from replacing just the shaft seal vs. replacing the entire motor-pump assembly is well over a Benjamin. So you go ahead and drill, cut, and chisel all you want on that old impeller!
wpl-dw-horiz-pump-shaft-seal-kit.jpg And Whirlpool just came out with a spiffy new DIY repair manual for this dishwasher, which will assist you mightily in the many repair adventures you are certain to have with this dishwasher:
whirlpool-dw-diy-manual.jpg To learn more about your dishwasher, or to order parts, click here.
Sep 14, 2009 | Kenmore Dishwashers
Pool & Spa Logo
111 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
