Question about Jeep 2001 Wrangler Sport
Where is the resister bank on a 2001 jeep wrangler sport
  • Jeep Master
  • 20,706 Answers
We cant guess,, TJ jeep
is this an HVAC question? heater?
my wild guess is its the heater blower resistor block.
its same on all cars, (its air cooled is why) it mounted to the blower casing.
FSM book, chapter 24 covers this. page 25
jeep calls them resistor wires.
see TJ, jeep 2002, here, page 25 and do defeat air bags first or be injured.
http://www.jeep4x4center.com/knowledge-base/index.htm?utm_source=cj#service
if blows on high ok but not other speeds, see here.
where is the resister bank on a 2001 jeep wrangler - 25613997-v3q4niidntdtpo20hl3kao5j-5-0.jpg
Posted on Mar 29, 2015
SOURCE: 3rd brake light won't work. Replace bulb...nothing
The contacts for the third brake light are two silver discs, about the size of a dime. They are located on the inside of the tailgate, hinge side. Make sure your carpet or any other loose item has not covered one or both contacts. Make sure they are fairly clean and make good contact.
Posted on Nov 30, 2008
  • 149 Answers
SOURCE: 2001 Jeep Wrangler HP loss
1. did you put oversized tires on the vehicle, if so that changes the gear ratio and will result in power loss,
2.. the catylitic coverter is plugged, often the coverter breaks apart and the pieces find there way to the outlet pipe and restrict exaust flow .
3. a fuel pump probem, low fuel presure under a load, however this condition will make the eng run lean, and most likey set a check eng light,
Posted on Oct 18, 2009
SQUIRESXX
  • 486 Answers
SOURCE: Winshield Wipers stopped working on a 2001 Jeep Wrangler.
TAKE IT BACK THEY HAVE LEFT A LINK OR POWER FEED LOOSE
Posted on Dec 07, 2009
  • 752 Answers
SOURCE: Turn signals/emergency flashers on 2001 jeep
Seating area, driver side, to the upper steering column housing at the top of the steering column, behind the multi-function switch
Posted on Feb 06, 2010
SOURCE: 2001 jeep wrangler sport ,fog lights on, switch off
I have a simular problem. Only mine does not some on. I tried to replace the turn signal switch assembly with a used one. The replacement work ok on the fog lights but the rest was bad. As near as I can figure it, the switch assemble is not well made and had many ways to go bad. Either replace the whole assemble or wire in a bipass switch. I am going to go with a bipass switch. I don't trust the new jeep products.
Posted on Feb 15, 2010
2001 Jeep wrangler sport 4.0 liter what's tsp
TSP.. tail spin propeller?
tps is throttle position sensor, or tire pressure sensor of the TPMS system.
why not say , where you say or head this word.
so we can stop guessing.
or point to it.
or photo it.
or???
Aug 09, 2014 | 2001 Jeep Wrangler
Camshaft position sensor 2012 jeep wrangler unlimited sport
It looks to be on the passenger side front of engine attached to the cylinder head.
Apr 20, 2014 | Jeep 2012 Wrangler Unlimited Sport
2002 jeep wrangler sport....what kind of coolant?
Green regular would be fine. Use a 50/50 prediluted coolant.
Sep 22, 2010 | 2002 Jeep Wrangler
Yellow dashboard light on 2001 jeep wrangler sport
is there an icon or writing on it? is it the check engine light?
Apr 15, 2010 | 2002 Jeep Wrangler
Turn signals/emergency flashers on 2001 jeep wrangler d/n come on. changed fuse and bulbs. Where is the flasher (resister canister) located? What else could could it be?The signal stat?
Feb 06, 2010 | 2001 Jeep Wrangler
Dec 07, 2009 | Jeep Wrangler Cars & Trucks
Variable fan was only working on high for ac now not blowing
if fan speed is working only on one speed it is most likely the blower resister,located in the blower box
Jun 28, 2009 | 2001 Jeep Wrangler
Nov 29, 2008 | 2001 Jeep Wrangler
Jeep 2001 Wrangler Sport Logo
149 people viewed this question
Top Jeep Audio Players & Recorders Experts
Thomas Perkins
Thomas Perkins
Tom Chichester
Duff Howell
Are you a Jeep Audio Player and Recorder Expert? Answer questions, earn points and help others
