Question about LG Refrigerators
I have an LG refrigerator freezer model number GR-S392GC that keeps tripping the power box. I plugged the fridge into another source but it kept shorting out. I isolated the issue to the harness wire
I have an LG refrigerator freezer model number GR-S392GC that keeps tripping the power box. I plugged the fridge into another source but it kept shorting out. I isolated the issue to the harness wire connector with the 2 orange wires, light blue and grey. Fridge and freezer works now without light and temp control led lights but remains cold. As soon as I plug those coloured connectors, the fridge shorts again and stops working. I think the circuitry diagram on the back of the fridge relates to Def-Sensor and Door-S/W. I think it might be the defrosting sensor but do I need to replace the door switch too? and what part number must I get and how to access these to replace in these places? Cheers!
  • LG Master
  • 5,323 Answers
The concept for a DRYER is the same for a washer or fridge in some instances
The key to this problem is what the amp draw of the washer is when the house breaker trips.
To narrow this problem down, there are three places that could be causing the ( outlet) GFCI to trip, a malfunction in the washing machine, a problem with the downstream wiring (aka load side of the GFCI-other items connected on same circuit), or the GFCI outlet itself. If there isn't anything downstream, then plugging the washing machine into another GFCI outlet, or simply swapping out the outlet for a known good GFCI outlet, will identify if the outlet itself is faulty.
If the outlet trips when the washing machine isn't running and isn't even plugged in, then there's a fault in the wiring on the load side of the GFCI outlet.
If the issue is neither of the above, then running the washing machine and monitoring to see which step is occurring when the trip happens will isolate what part of the washing machine may be leaking current to a ground. It could be a certain water level, a motor being engaged, a transition step in the controller, etc
Beware some techs believe that most Washing machines or any other motor should not be on a GFCI! Should be a dedicated single receptacle. If there are other outlets on the washer GFCI, replace that GFCI with a single receptacle and put the GFCI on the next jump in order to protect other outlets.
Another item to check is ur lid switch which may have gotten moister inside and created a short_ or broken open and the rubber seal dried out over time, and the switch assembly will be exposed. water can splash onto the assembly, somehow causing the GFCI to trip. In any event, if you are having trouble with your washing machine stopping mid-cycle for any reason, test and replacing the lid switchis probably a worthwhile idea, as it is cheap and easy to replace.
Posted on Apr 17, 2015
3 Suggested Answers
thompsonds20
  • 53 Answers
SOURCE: fridge warm, freezer working, pump working. where
Either the thermostate is defective or refrigerent blocked or leaked or the relay is not functioning properly. Only on inspection of the above parts could pronounce the right remedy.
Posted on Jul 06, 2009
heatman101
  • 43501 Answers
SOURCE: freezer workig fridge not cold
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Jan 06, 2011
My lg fridge keeps beeeping model number gr642apa 8 years ago the beeping is driving me insane but everything else is workin only beeping all the time
http://www.manualslib.com/manual/692499/Lg-Gr-642apa.html
This is the link to the manual for your model. The beeping fault codes are covered starting on page 19 and get into detail by page 22. There are a number of triggering events or causes so you should read about them and try what the manual describes to try and turn the beep off.
Nov 25, 2014 | LG Refrigerators
I have a fisher and paykel fridge freezer model e372b my power kept tripping a few days ago and I didn't know why we switched the power box back on and it tripped again we turned it back on and it tripped...
Check the power cord on the fridge to make sure it is not broken or frayed. There is an electrical short somewhere. Check the recepticle that is used for the fridge by plugging something else in it, such as a lamp, to see if the receptacle has a short in it.
Apr 27, 2014 | Refrigerators
LG Fridge-Freezer model no. GR-T632DVQ The upper freezer lights works. The lower fridge light stopped working. When tested the light bulb works and is NOT broken. There is a combination double...
looking for a door for lg refrigerator GR-T632DVQ
if anyone can help me plz ring 0421203100
perfect fridge, had it for 10 years, door fell off today :(
i've been searching everywhere, *sigh
please help if u can
Mar 16, 2011 | Refrigerators
Everytime I plug in the power cord, it trips the breaker.
Refrigerators are not designed to run on a GFCI. Try a heavy duty extension cord to the fridge from a outlet that is not GFCI protected. If it still trips you probably have a short circuit in the compressor.
May 13, 2009 | GE GTS22KBP Top Freezer Refrigerator
Lg multi air flow gr-349sqf
It sounds like the defrost element is faulty and is causing a leakage to earth when the unit comes onto defrost cycle. Check the defrost element in the freezer compartment behind a panel cover.
Mar 10, 2009 | Refrigerators
LG GR-292R freezer works/fridge does not.
well i have the exact same refrigerator but opposite problem.... the freezer works but the entire refridgerator is a freezer....why is the fridge part freezing everything. This appeared to happen after the power went out and the entire fridge is a freezer now.
Mar 02, 2009 | LG LFD25860
Could be a wire short,bad defrost heater, or comp. pulling too many amps which is between 2 and 6 or higher being bad. I would say the main problem is you purchased a LG fridge which is a poorly made fridge,sorry.
Mar 30, 2008 | LG LRBN20510WW Bottom Freezer Refrigerator
Refrigerators Logo
157 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Colin Stickland
Colin Stickland
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
