Question about RCA Televison & Video
42 in RCA screeches then loses picture
After being on for a short time tv emits loud screeching, then picture goes to colored snow. I will take it in for repairs,but I'd like to know what to expect! I can't afford to go over $100. Thank you for your help. Beverly
    Top Expert:
  • RCA Master
  • 74,198 Answers
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
In some models of LCD TVS; the backlight inverter and its T'Con board will be a part of the panel itself, and will be a built-in type inside the LCD panel. If so, they can't be replaced. In this case; a panel replacement is the only repair. For some other models, the backlight inverter section circuit will be a part of the main power supply regulator [SMPS]. To such sets, the power supply section circuit too should troubles shoot. Contact any service technician. The circuit will differ with models and versions.
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Posted on Apr 06, 2015
    Top Expert:
  • RCA Master
  • 44,268 Answers
I would look into a NEW one with warranty before spending even 100.
SOURCE: SCREECHING NOISE
I have a 37" combo TV/DVD unit. It's been doing this for about 6 months. Wrote to tech support from their website. Got nothing but an automatic response. When I called them, they automatically tell you the part you need is not available. It is a law that a part be available for 7 years. I have filed a complaint with the Bureau of Electronic and Appliance Repair (BEAR) against them. I need a new LCD control panel. Others have had success getting the parts they needed by going this route. Try it. Maybe they'll stop scamming us consumers. They get your TV back, fix it and resell it as reconditioned.
Posted on Nov 12, 2008
  • 133 Answers
SOURCE: Hi I have a sylvania
your transformer on your power supply is bad, i would recomend replacing the power supply, usually when the transformer goes bad , it damages other things on the board, should be around a 200$ part
Posted on Jan 11, 2009
srinivas1515
  • 108 Answers
SOURCE: red, blue and green dots appear on screen like snow
ask ur service provider and ask him to change ur revolution or ask him to change ur sreen
Posted on May 21, 2009
Shuttle83
  • 1139 Answers
SOURCE: Vizio SV470XVT1A makes screeching sound
This sounds as if it could be a ballast problem, or a switching power supply transformer problem. Both of these can produce this sound. I would suggest that you have a qualified TV technician repair this set due to the dangerous voltages and currents that could be present. In my experience with these TV I would have the technician pay special attention to the power supply board and the backlight/inverter section which includes the ballast used to fire the backlight.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Posted on Jun 17, 2009
SOURCE: screeching sound and display of color bars with no picture
it is two 1000uf 10 volt capacitors on the power board. the tops of the
capacitors will look like they are bulging. total cost of parts around
five dollars. if you can use a soldering iron and have a half hour to
spare this will fix it .there are alot of polaroid customers that have had
this problem and fixed it themselves. just click on the follwing to see
the video on this fix http://www.youtube.com/watch?v=unuS3CvmWtw
Posted on Sep 05, 2009
Why does my vizio tv only stay on for a few seconds before the picture goes fuzzy and the tv makes a very loud screeching noise and shuts itself off
Sounds like the power supply board has gone out. It can probably be replaced, but only by someone qualified to do so.
Oct 21, 2014 | Vizio L32 32 in. LCD HDTV
62" RCA dlp loses color
If you hear any winding, whirling or screeching noise (Color Wheel symptoms)
If there is any vibrations in the TV (Color Wheel symptoms) you would need to change the color wheel.
Apr 15, 2010 | RCA HD61LPW165 61" Projection HDTV
High pitch screech w/no signal
is this a picture tube type of tv? big in back? If so, it could be the tube/circuit short.
If it flatpanel, it could be a bad capacitor in the DM or "Y" board or even possibly faulty power supply. Further testing will be necessary
Jul 22, 2009 | Polaroid FLM-3732 Television
No picture and loud screeching on RCA Scenium 50" DLP
It sounds like it is the Color Wheel. I do not think you can get the Color Wheel separate from the Optical Engine like you can with Samsung. RCA is very tight with there parts like that. Because you have to get the whole
Engine Assy, cost would be too much in my opinion to invest into it. The part cost approx 800.00 the last time I checked on one.
Good Luck,
I Hope this helped,
Skyassoc
Jun 20, 2009 | RCA Scenium HD65W20 65" Rear Projection...
My RCA is screeching
To install the color wheel, turn off and unplug the tv, take off the lower back casing (17 star type screws), remove the lamp door, remove the lower back casing. Look just left of the lamp you will see 3 smaller star type screws near a small circuit board (which is on the color wheel), remove those screws unplug cable from color wheel, unplug other end of 2nd cable from tv circuit board (just to the upper left nearest to the color wheel.
All you have to do is install the color wheel, plug in both cables, put the back on and place the lamp door back in its position, the lamp door pushes in a lillte blue lever which allows the lamp bulb to light up.
I'm in the process of doing the same myself on my RCA same model. Where did you buy the color wheel from?
rw9704
Jan 06, 2009 | RCA HD50LPW42 50" Rear Projection HDTV
Loud screeching noise when it powers on
sounds like picture bulbs maby %30 i think it may need to go in for a check up they can pin point the problem hope ive been somewhat helpful thanks viper
Dec 31, 2008 | RCA Televison & Video
You have a bad colorwheel in the light engine. Due to the complexity of the repair, I suggest you call a tech to check this out
Dec 18, 2008 | RCA HD61LPW42 61" Rear Projection HDTV
Wont turn on
there may be a short in the system. Bad news: You should have a licensed pro help you diagnose it and fix it. Good news: its fixable.
Aug 24, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA HD50LPW175
Sounds like the color wheel is failing.
Dec 18, 2007 | RCA HD50LPW175 50" HDTV
Televison & Video Logo
48 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
