Question about Sewing Machines
Code 88 starts flashing as well as all the stitching lights on the panel when I try to thread the bobbin. I can sew, that is NOT the problem, threading the bobbin is. What is Code 88? I am not interested in embroidering, just threading the bobbin. There is NOT a troubleshooting guide in manual .Can anyone HELP PLEASE!
  • William Gilbert Mar 28, 2015
    Hi Marlene Law, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    What Maje and Model??
    Do you have a manual?
  • Sewing Machines Master
  • 9,981 Answers
Please tell us the Brand and Model of your machine? We can't help you without that information.
Posted on Jul 24, 2015
    Top Expert:
  • 14,161 Answers
Turn your machine off and leave it off. Remove all bobbins - in the machine & from the pin. Remove all thread - from threaded machine and bobbin thread path. Clip the machine thread at the spool and pull the needle thread towards yourself. Clip bobbin thread at spool and close to bobbin, then pull towards you through thread guides. This keeps the tension where it belongs. Move the bobbin winding shaft from normal sewing back to winding bobbin a couple times. It should click in place when moved to the winding position. Check to see if there is any thread that has slipped under the bottom of the bobbin and wound itself around & under the bottom of the shaft. Carefully unwind to clear. If the shaft does not easily move back to the sewing position it is probably stuck in the winding position. Don't force it, but try to get it out of the winding position. Leave it to the left in the normal sewing position (unclicked). Check to see if there is any thread caught anywhere along the path from spool to the winding pin. Pay close attention to the first thread guide and the two discs the thread slips between that control tension. Hand wind the wheel on the right towards you to raise and lower the needle a couple of times. Stop with needle in highest position. Do NOT wind hand wheel backwards (away from you). Make sure the bobbin pin is not in the winding position. Now turn on your machine. Needle should jump to default position. Move the stitch length and stitch width guides to the far right, then far left, to attain the green lights. Press the reverse stitch button to raise lower and raise the needle. It will stop in the highest position. If you still have the error code - make sure the bobbin winding pin is NOT in the winding position. Remove the needle. Lower the presser foot and run the machine without any thread a bit. If the needle bar does not go up and down most likely the bobbin pin is stuck in the winding position. If the code has cleared use your manual to carefully wind a new bobbin. Make sure you are using a 15J bobbin which this machine requires. It will not work with just any bobbin. Next, raise the presser foot then carefully thread the machine. If you don't have a manual you can download one from the Singer website. You might consider cleaning the entire machine paying special attention to the hook area and feed dogs while the power is off. If you find a lot of lint do this more frequently to prevent buildup. Take special care when replacing the bobbin care. Hope this helps. If not call Singer. It may take some time but you should be able to reach someone to help you troubleshoot. If this is an older machine I recommend taking it for repair yourself instead of sending to Singer
reference: http://www.amazon.com/Singer-7466-Electronic-Sewing-Machine/forum/Fx3BSOY0VA78VQ4/-/1?_encoding=UTF8&asin=B000B91B3K
Posted on Jul 23, 2015
MakikiChris
  • 84 Answers
SOURCE: Does not sew, I think it is problem with the bobbin
Hi Gail4456...When you say "would not sew another stitch", do you mean that it is at a mechanical-stand-still? Or do you mean that the machine runs, but does not stitch? Please update/correct me if I am misunderstanding your issue. If your machine is 'frozen', remove your bobbin and needle. firmly grasp the balance wheel (handwheel on the right), and smoothly turn it clockwise until the jam is free, then use compressed air or brush or vaccuum to rid the now dislodged thread. Other possible causes for non-operation include: raised presser foot and/or un-depressed or faulty start/stop button. If your machine is not producing stitches: 1) Replace your needle, ensuring the slotted side is facing towards you. 2) Wind a fresh bobbin, and ensure that you are threading properly through the bobbin tension spring. 3) Completely remove your spool of thread, and slowly rethread your machine ensuring that you don't miss any guides, and that your thread isn't becoming wrapped around the takeup lever accidentaly. If you believe that you have a threading issue, do not retrace your thread. Instead, completely remove the spool and bobbin, and start again. I hope this corrects your issue my friend.
Posted on Aug 02, 2007
SOURCE: singer sewing machine model 6012 c
hi
i want to know how i put thread in the sewing machine
thank you
Posted on Aug 23, 2008
SOURCE: singer simple sewing machine will not sew
need needle threading instructions singer 3116 simple. pictures would help. thank you
Posted on Mar 15, 2009
sburtenshaw1
  • 5 Answers
SOURCE: Shirring fabric?
When putting your shirring elastic on the bobbin, don't thread the elastic through the bobbin holder,adjust the stitch length longer,and loosen the tension, other wise if you want to put it through the bobbin holder you have to loosen the tension screw on the bobbin holder, and then you have to adjust it back for ordinary sewing,
Posted on Feb 13, 2010
chrismyers67
  • 53 Answers
SOURCE: top thread keeps breaking
This sounds like a backwards needle. Take out the needle and when you re-insert it back in, make sure that put the flat side to the back.
Posted on Jun 07, 2010
Upper thread pulls out of needle as soon as I start to sew. Tension is at 5. Bobbin is correctly wound and seated. Machine is threaded corrctly
If your top thread is picking up the bobbin thread, there is probably nothing wrong with the timing. It sounds like you are not pulling enough thread through the needle eye before beginning to stitch. It also helps to have the needle raised to its highest before taking the first stitch. Pulling the bobbin thread up through the fabric and then holding both thread tails lightly in your left hand while taking the first couple of stitchs will help keep the thread from "back pedaling."
How and Why to Bring up the Bobbin Thread
Mar 06, 2017 | Sewing Machines
My Janome MyStyle 16 keeps jamming - thread bunching in the bobbin cavity. Have tried everything but keeps happening... How can I fix this??
PDF]INSTRUCTION MANUAL - Janome
janome.com/siteassets/support/manuals/.../inst-book-7318-english.pdf
making any other adjustments mentioned in this owner's manual. ..... 16 q w e r t. SECTION 3. BASIC SEWING. Straight Stitch Sewing. Machine setting: q Stitch ...
How to Thread a Janome Sewing Machine - YouTube
? 6:55
https://www.youtube.com/watch?v=NUsT0plWt6Y
Mar 1, 2013 - Uploaded by Easy Sewing for Beginners
In this video I show you how to thread a Janome sewing machine ... I've unwrapped it and started reading the manual and it wasn't easy to see ...
Nov 26, 2015 | Janome Sewing Machines
Why does my thread knot on the back when stitching in place?
Several things to try:
Pull thread tails (both bobbin thread and upper thread) straight back and when you lower the presser foot, make sure they are held down straight back. This may or may not be enough to solve the problem, but it is simple to try, and often works. You might want to hold the thread tails while you start sewing.
Use a starter--folded piece of fabric scrap about an inch long--and begin sewing oink middle of starter. Push the fabric you want to see right up to the starter and keep sewing from the starter right onto your project without lifting the presser foot or cutting the thread. When you finish sewing, cut the little piece of thread between the starter and your project.
Before lowering presser foot, use wheel to lower your needle once and then pull up bobbin thread to top surface of your project. Then hold both bobbin and upper thread tails, lower your presser foot, and begin sewing. Release the thread tails after a few stitches.
Hope this helps. Those nasty "thread nests" are a real pain.
Jul 13, 2014 | Janome Sewing Machines
I cannot thread my bobbin, I can sew. When I try to thread the bobbin, Code 88 starts flashing.
You said "trying to THREAD the bobbin." Did you mean it happens when you put an empty bobbin on and push the spindle to the right? Is your needle all the way up? If so, pull the buttonhole lever ALL the way down, then smack it up, and check to make sure the twin needle lever is not selected. Frankly, I'm not in love with that system anyway; you might think about purchasing an inexpensive Sidewinder for less than $20. You can order from WalMart online; if you pick it up at a WalMart or FedEx facility like Kinko's, shipping is free. Believe me, you'll do yourself a favor; many problems with these machines are actually caused by loosely wound and/or badly wound bobbins. Also, think about purchasing prewounds; they're actually cheaper than winding your own.
Jan 18, 2014 | Singer CE-200 Quantum Futura Computerized...
When I thread the bobbin, code 88 flashes, what is that?
Try zero your embroidery hoop carriage by off/on your machine before your next application, if no result disconect your embroidery unit and connect back again ensuring it is properly connected. Hope the problem can be solved.
Jan 17, 2014 | Singer CE-200 Quantum Futura Computerized...
Thread my bobbin, Code 88 starts flashing & all lights
I owned a CE-200 for about six years, and as I recall, that code blinks if your needle is not all the way up. If it is NOT up, operations are suspended until it is. That means that the hoop cannot reset to its default position.
My singer curvy starts beeping and lights flashing and won't sew
I just got mine to stop flashing lights and function again when I unplugged the cords from the machine and let it sit for a minute. You can always give that a try.
Dec 20, 2012 | Singer 8763 Curvy
E1 flashes on the message window of my brother sewing machine
Brother Computer Codes
  • E1: Make sure the presser foot is lowered before sewing.
    E2: You chose a stitch other than a buttonhole stitch or a bar tack stitch and you tried to sew with the buttonhole lever in the lowered position. Raise the buttonhole lever.
    E3: If you selected the buttonhole or tack bar stitch and start to sew with the buttonhole lever raised, you will get the E3 code. Lower the buttonhole lever.
    E4: You hit the reverse button while the bobbin winder shaft was moved over to the right. Move the bobbin winder shaft to the left.
    E5: On automatic sewing machines, the start/stop button was pressed while the foot controller was plugged in. Unplug the foot controller if you are using the automatic function.
    E6: This code tells you that the motor locked up because the thread is tangled. Untangle the thread, make sure the machine is threaded properly and that the proper tension is set before continuing.
Oct 03, 2012 | Brother CS-6000
My sewing machine keeps getting jammed when sewing. the top stitch keeps getting tangled in with the bobbin thread and jamming up the machine.
Here are a couple of things to try.
* Un-thread your machine and remove your bobbin. Clean any loose thread or lint out of your
bobbin case. Re-thread your machine, reinsert and re-thread your bobbin.
* Change your bobbin
There could be a nick along the edge of your bobbin spool that’s catching your thread as you
sew.
* When you start to sew a seam, grasp the upper and bobbin thread tails. Hold them back
and out of the way as you sew your first couple of stitches. This will keep them from getting
caught in your machine.
I hope this helps.
Sep 11, 2009 | Singer 5160 Mechanical Sewing Machine
Singer 7442 will not sew
Had the same problem as mommyb2 - it was the bobbin spindel was in the wrong position. Push bobbin spindel to the left and it works for sewing.
Have the same problem winding my first bobbin - pushed spindel to the right to engage bobbin fuction and the machine locks up and wont wind the bobbin. Irig did you bring it in for repair? I'm thinking its broke - which **** as mine is a brand new machine
Mar 23, 2008 | Singer 7442 Mechanical Sewing Machine
Sewing Machines Logo
200 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
