Question about Sunbeam GCSBCL-212 Steam Master Professional Iron
My iron is ready light is blinking and its beeping and not heating up i have tried to move it back and forth to get it to turn on but effect please tell me what i need to do
    Genius:
  • 1,181 Answers
Replace it or if is still in warranty or from some place like Kohls return it for a new one.
Posted on Mar 28, 2015
I was given a Rowenta Effective with no instruction booklet and I can't get it to work properly. When I turn it on it gets hot but soon after that bottom light goes out and the auto off light blinks
If you start ironing with it, does it come back on? It usually doesn't take long for auto-shut-off irons to turn themselves off--a few minutes in the upright postion, and about 30 seconds if left sitting in the down position. Once you start the ironing motion, it should come back on.
Oct 14, 2014 | Rowenta Effective DX1900 Iron with Auto...
Premature shutting off
Have you try with lower heat setting?
It seems like it might be thermostat or thermal fuse that is not working properly.
Apr 21, 2008 | Rowenta Effective DX1700 Iron with Auto...
I have lost my instructions on how to "self clean"
Straight from the manual:
http://www.applianceinsider.com/storage/user-manuals/rowenta/user-manual/DX8000.pdf
Fill the iron with tap water to the max mark on the water tank.
Be sure that variable steam lever is set to minimum.
Stand iron on heel and plug in. • Set thermostat to ••• setting.
Once heated, unplug iron.
Hold iron horizontally over the sink with the soleplate pointing away from body.
Move the variable steam lever completely to the right and hold in the self clean position for one minute.
Warning: Doing this will cause steam and hot water to be ejected from the soleplate. Take all proper precautions and hold iron away from body.
• Move the iron gently back and forth and side to side until all water has run through plate.
• Carefully wipe all water and material from the soleplate with an old towel, as the water and minerals can stain the soleplate (although this has no effect on glide or performance.)
Warning: Iron and soleplate may still be very hot. Exercise care while wiping.
• Place iron on heel and leave to cool. Before using iron after self cleaning, test steam and burst
of steam on an old towel or cloth than can be discarded.
May 04, 2011 | Rowenta Professional DX8800 Iron
I have a Rowenta DX1700. The iron will only stay
The problem is with the iron's thermostat which controls the temperature of the iron
Feb 07, 2010 | Rowenta Effective DX1700 Iron with Auto...
Why does the iron light blinks when plug in
It shows that the iron is heating up. When the light is steady, the iron is at the set temperature and ready for ironing.
Nov 30, 2009 | Sunbeam 4214 Iron
Black & Decker model D1600 iron error message
I work for Black and Decker customer support. Our customer service phone number is 1-800-231-9786.
If the unit isn't heating anymore, it needs to be replaced. Unfortunately, the unit can't be repaired. The unit comes with a one year warranty from the date of purchase. Please call the number above so that we can determine your warranty eligibility and help you any way we can.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here.
Please let me know if I can be of further assistance.
Apr 27, 2009 | Black & Decker ICR200 Iron with Auto...
My rowenta effective will not heat up.
This is a problem with a lot of Rowenta irons. It is the auto shut off that is not working properly and the only way to fix it is to have it disassembled and the switch hardwired to be on whenever the iron it plugged in. It is a thermal metal switch and it just stops working and then the iron will not turn on and the yellow light blinks.
Dec 15, 2008 | Rowenta DG5030 Iron
I'm having a problem with the auto shut off of my sunbeam 421A series iron. The iron works great until the auto shut off comes on and the red light starts blinking. I understand that the iron should...
Unless you have a 5 or 6 hundred dollar iron, or unless it is brand new, and still under warranty, there is an excellent rule of thumb when an iron quits working: Buy a new one! These days, irons can be purchased cheaply enough that it is WELL worth the money. Not just for the convenience, but for the safety issues. This is an appliance that could burn your house down even if it's in PROPER working order. Hope this helps!!
Chad
Sep 21, 2008 | Sunbeam 4214 Iron
Problem with Philips Azur Precise 4340 Iron
i had the same problem and the Philips hekp site was no use. I turned my iron off until it was completely cooled down then switched it back on again, with the steam number turned to 5 and the heat on max. as soon as the ready light went off, i put my iron in the horizontal position and shook it back and forth (quite vigorously) and it seemed to have dont the trick!
Jul 09, 2008 | Irons
Sunbeam GCSBCL-212 Steam Master Professional Iron Logo
642 people viewed this question
Top Sunbeam Irons Experts
Wayne Fellows
Wayne Fellows
Craig Butler
Craig Butler
Are you a Sunbeam Iron Expert? Answer questions, earn points and help others
