Question about Taco 006-BC4 Cartridge Circulator Pump, 1/40 HP, Bronze, 1/2" Sweat C
Why is there a leak at the Taco Circulator?
For a two week vacation, we shut off water to the house and put water heater on vacation mode. After returning, we woke up to big leak from the piping entering/exiting the Taco Circulator. Leak stops when we closed valves on either side. No hot water pressure now.
3 Suggested Answers
  • 20 Answers
SOURCE: NO HOT WATER ON OTHER SIDE OF HOUSE
All of the white pegs on the outside of the dial are on and off times. If they are pushed out they are on and pushed toward the center is off. You want to set those for the times you would usually used hot water. There is a white arrow on the face. You want to rotate the face clockwise until the time of day is infront of the arrow to set the time. Last but not least there is a switch on the right side of the dial it has three settings, on off and timer. If you set it to the clock the pump will turn on and off at the times that were selected on the face. You can also turn it to the constant on position and it will run constantly. I would suggest flipping it to constant on and wait a few minutes to see if it fixes your hot water problems. If not the pump might be bad.
Posted on Apr 29, 2010
heatman101
  • 43501 Answers
SOURCE: The taco cartridge circulator #006-BC4
Here is a tip that I wrote about heating circulator pump problems.
It will give you the information you need to learn about your circulator pump problems and solutions for it.
Heating Circulating Water Pump Problems
heatman101
Posted on Dec 24, 2010
My taco red robin is leaking water can I replace the seal?
Yes you can if you get the casting number I can find them for you
Jan 08, 2015 | Taco Pumps Taco Red Baron In-line...
Taco circulator
Is this for a hot water system? If it is, u might have air in the system.
Mar 04, 2014 | Taco 007-F5-5 Cartridge Circulator Pump,...
Taco 007 not working
If the motor is getting warm I would suggest replacing the Cartridge assuming all the air is out.
Jan 23, 2014 | Taco Cartirdige Circulator Model 007
Hot water is not staying hot
Is the control that operates the pump located in the storage tank? If so the pump not be pumping. A few factors might be needed to solve the issue.
Dec 18, 2013 | Taco 006-B4 1/40 HP Bronze Circulator Pump
Taco pump noisy whine
Take apart and clean with white vinegar.
This will remove scale and build up causing noise in line.
Nov 27, 2012 | Taco 007-F5 Outdoor Wood Furnace...
I cannot figure out why my hot water no longer gets hot. I unplugged my timer 3 years ago and never had a problem. Now, no hot water unless timer is on and circulating.
Best solution is to remove the circulation-system crossover located under sink and see if problem is solved.
After removing crossover piece, try hot water tap.
Another way to check if this is the problem: Turn off cold water shut-off located above water heater. No need to turn off power or gas to water heater. Now, no water should flow when you turn on hot water tap because hot is turned off.
Open hot water side of double handled faucet. If water still comes out the hot side, then crossover is the problem.
After removing Taco crossover, you can still have the problem if a single handled faucet has the same type of crossover issue.
Repeat test to see if water comes out of hot side when water to water heater is shut off.
If water still comes out of hot side, then put ear against each single handled faucet and see which one has sound of moving water. That will narrow down the suspects.
Mar 27, 2011 | Taco 1/2" 006 BC4-TAC Circulator Pump/...
I have taco 671-2 aquastiat and water going out from there what i can do
Going out from what?
Is the Taco pump leaking?
Or pipe connected to taco?
Or is the water heater leaking?
1) If this is emergency, turn off water and call plumber.
http://waterheatertimer.org/Emergency-steps-for-leaking-water-heater.html
2) If water heater is leaking:
http://waterheatertimer.org/Water-heater-leaking.html
3) If pump is leaking, then pump needs to be replaced.
http://waterheatertimer.org/Water-heater-recirculation-system.html
4) If pipe going into pump is leaking, then it needs to be taken apart and fixed.
5) Add a photo to this post so I can see problem.
After that, I can give best direction to go.
http://www.fixya.com/support/r6568559-post_photograph_fixya_questions_answers
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you via e-mail while you work on Taco or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 19, 2011 | Taco 1/2" 006 BC4-TAC Circulator Pump/...
The taco cartridge circulator #006-BC4 was working fine. Then there was a brief power outage, now it is hot to the touch, and circulates hot water to one part of the house, but not to the other 2/3's of...
heatman101
Nov 06, 2010 | Taco 1/2" 006 BC4-TAC Circulator Pump/...
We have a taco timer aquastat that's pretty hot to the touch; and were not getting hot water to the house. Does it need replacing?
The pump has air in it and you need to purge out the air..
heatman101
Aug 20, 2010 | Taco 1/2" 006 BC4-TAC Circulator Pump/...
Taco 006-BC4 Cartridge Circulator Pump, 1/40 HP, Bronze, 1/2" Sweat C Logo
96 people viewed this question
Top Taco Plumbing Experts
Gil Shultz
Are you a Taco Plumbing Expert? Answer questions, earn points and help others
