Sumvision 8ch dvr forgot admin password and can only log in on admin. Tried codes 123456, 000000, 111111, 999999, 1234, 4321 the last two were tried when the battery was removed please help
    Master:
  • 238 Answers
Factory Reset Hidden Key :Mode Key + CH 2
The Password and all setting value will return to the initial default value.
Default Password is '4321'., Refer to 6-10p, 6-12p of User manual
I hope this helps.
Posted on Mar 28, 2015
  • 3 more comments
  • richard caddick Mar 28, 2015
    Thanks for advice but when i go to log in screen says admin which wont change and p/w tried 1234 and 4321 wont work. Bit slow when comes to things like this need help plz. Thanks in advance
  • Cal Martin
    Cal Martin Mar 28, 2015
    Have you tried resetting it back to default? As far as I understand, your recordings should remain intact.
    Yeah i tried to do that but cant nothing till i get passed the admin/ password page. Not worried about losing data just need to reset dvr box or access the default code to change the password if you need any info on dvr box plz ask.
  • richard caddick Mar 29, 2015
    Thanks cal martin for your help found the master code in the end.
  • Cal Martin
    Cal Martin Mar 29, 2015
    Perfect! Glad to hear you got in.
priyabrat
  • 123 Answers
SOURCE: Resetting Admin password
go to setup>and go to maintanance -->there is a option restore default>select that and after some time do power cycle>and rste me solved if its helps
or
go to your user accouny and change your password
Posted on Jan 28, 2008
Joed911
  • 4338 Answers
SOURCE: Forgot linksys password
Reset your Linksys router back to default:
The easiest method of resetting your Linksys router’s password is to reset your router back to the default factory settings. This is done by simply holding down the reset button located on the back of the unit for at least 30 seconds. Once the router has been reset, it must be reconfigured. Using your web browser go to URL address http://192.168.1.1. You will then be prompted to login to your router. A log-in screen asking for the password will automatically appear. At this time enter the default password “admin”, in lower case letters into the password field. The username field may be left blank at this time. (Note: both the default username and default password are set to “admin” on some of the newer Linksys router models).
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Jan 31, 2009
  • 1602 Answers
SOURCE: Forgot macbook admin password and can't get into it? HELP PLEASE
MAC PEOPLE HAVE WONDERFUL PROGRAMS THAT CAN HELP YOU AND YOU NEED A SERVICE TECH FOR MACS TO HELP IN THOSE TYPE OF PROBLEMS ASK YOUR FRIENDS THAT MAC, IF THAN FIND A USERS GROUP OR PROGRAM, COMPUTER CLUBS,
THE SCHOOL DISTRICK MAY HAVE SERVICE GUY OR EVEN THE TEACHER WHO IS A MAC USER OR MAC LOVER.
Posted on Feb 12, 2009
  • 14 Answers
SOURCE: dell inspiron 5150 laptop, reset admin. password.
Restart your laptop and keep tapping F8 key the moment you see something on the screen. You will get a black screen with some options written in white. Select the option Safe mode and then you can create a new user with admin rights. Or else at the windows login screen press and hold ctrl and alt key and tap delete key twice and then it will take you to a login screen. Dont put any password there just hit enter. And you will be able to login with admin rights.
Thanks
Deepak
Posted on Oct 28, 2009
  • 314 Answers
SOURCE: Dell Latitude D630 admin password lost
You can take care of this yourself. With the laptop off, unplug it, and take the main battery out, and open the screen back until it can't open any further. Take a small flat-blade screwdriver and put it into the small vertical slot on the right end of the bezel plate just above the keyboard. Pry that up, it will tilt to the left wiggling it as you pull it up and off. When that goes back on, the left end goes in first, re-snapping it back down. Set that aside. Looking at the top frame of the keyboard you will find three small Philips screws that need to come out. Use a #00 Philips (you can pick one up as Sears if you don't have one). Set those aside (they are all the same size). Gently pry the upper edge of this keyboard frame up and it tilts toward you, then you pull it toward the LCD screen to release the tabs that hold the bottom edge of the keyboard under the palm rests. Don't yank it off, there is a cable holding it on the left side! Just fold it back and let it rest over the trackpad, no need to release the cable. Look into the now open area and about 1/3 of the way from the left side you will see a tiny white plug with two little wires attached, red and black that go to a little "coin" battery. This is the CMOS battery that keeps configuration data from being lost when powered off. Grab the wires closest to the little plug and pull it straight up, wiggling it left to right if you need to. Leave it unplugged for 10-15 minutes. Plug the little white plug back in, fold the keyboard back into it's normal place maing sure you push the bottom tabs in first, then be sure you snap the sides back down at the right and left edges and under the little side tabs. Put the three little Philips screws back in and reinstall the bezel above the keyboard. You have cleared the BIOS settings including the password to get into the BIOS. Close the lid. Flip it over. Put the main battery back in. Plug in the power cord, flip it over again, open the lid and hit the power button. Press F2 while you see Dell on the LCD screen and you will get into the BIOS Setup without a password, it is gone.
Posted on Jan 20, 2012
I forgot My Admin password at H.264 DVR Network Version (Model): SDVR - 3308LS Serial N?: D98017C10018F5149CA6 I want reset my password now.. could you help me?
f you have changed the password and forgot it,please try to use the password below:
Username:admin
Password:ansjerreset
If password"ansjerreset"doesn't work, please use another password to try:
Username: admin
Password: superpassword
Log in and click the right button of the mouse,
go to Main Menu--- Set up --- Users --- Change Password to modify your password.
Hope this helps.
Dec 19, 2017 | Home Security
Forgot password on cyclone voyager tablet
How to reset a Sumvision cyclone voyager 7'' - Tablets and e ...
forums.digitalspy.co.uk/showthread.php?t=1777470
Digital Spy
Dec 31, 2012 - 7 posts - ‎4 authors
Hi a friend of mine had a 7'' Sumvision Cyclone Voyager tablet for ... it round for me to look at last night, i tried to get the password reset but ...
Do you know how to reset a Sumvision Voyager Tablet, i ...
www.askmefast.com > ... > Screen
Cyclone voyager tablet how to reset stuk on android screen .... Sumvision cyclone voyager password reset · I forgot my .... Cyclone voyager 10 tablet factory reset.
Topic: Cyclone Voyager ' Tech It E@sy
Dec 30, 2015 | Tablets & eReaders
I forgot my admin password i got a H.264 dvr 4ch China made
Admin and Passwords come as default. If you changed it and forgot, try unplugging the DVR and restarting. You can also still open the settings and try to re- factory the DVR if the settings permit. Next, I have to assume that you got the Booklet or the email or URL addresses to download same.
There is in the hand book the default password as the User name:password and the Password #'s 1-6. Good luck.
Sep 09, 2015 | Home Security
How do I reset the Admin password on a H.264 Hexaplex 4ch network DVR
try to log in with user name admin and password ttvvtthuanyuan
Mar 03, 2015 | Home Security
FORGOT PASSWORD DVR ECOR264-16X1
Thhe Factory Default is.
For user type in : admin in lower case .
for Password Type in : 11111111 .
thats 8 # 1 .
Sep 15, 2014 | EverFocus Ecor264-16x1/2t Dvr Digital...
Reset password samsung SDR-5102
By default, initial ID and password are set to "admin", and "4321
Jul 30, 2014 | Samsung 8ch Dvr 4 Camera System 19" Lcd...
I need reset the password on a 16 ch. dvr dvs do you know how i can do this?
I have a H.264 Network DVR with ver. V2.00.R05 and I've forgotten the password can anyone help with resetting it...
Mikw
Nov 05, 2010 | CSi Speco Speco DVR-T4IP 4-Channel Triplex...
I have Fuho 8ch. H.264 DVR I cant reset my password.
hello friends i have 8ch H.264 dvr i forget defalt password please help me how to get the password
Oct 12, 2010 | Cameras
Admin password DVR-X4 IP
i lost the dvr password how to watch yastaday data
Mar 11, 2008 | CSi Speco Speco DVR-T4IP 4-Channel Triplex...
Computers & Internet Logo
138 people viewed this question
David Payne
David Payne
