Question about Maytag Dryers
Maytag dryer mdl.#MDE9600SQ0 will run for 20 seconds and then shut off.
  • Maytag Master
  • 5,323 Answers
Bad motor windings? or bad thermal cut off and hi limit fuses also check ur cycling thermostat
Posted on Mar 30, 2015
Dryer runs and stops and all l.e.d. lights come on
Was the dryer on that the time the power was cut? Was the dryer on when the power was restored?
It sounds as though it may have suffered a surge which may have affected the controller board.
Dec 11, 2013 | Maytag Dryers
Maytag dryer tumbles and heats but will run only 10-20 seconds before shutting off.
is there an berrrrrr noise for 1 or 2 seconds when starting the dryer? this sound is a bad motor. another cause is loose power cord where it attaches to the dryer. 3rd is aluminum wiring from your breaker to the dryer outlet. these screws that hold the wiring at the breaker and outlet can loosen and should be tightened. give me some feed back so i can help.
Apr 27, 2010 | Maytag Dryers
The dryer runs about 10 seconds then shut off. It
Maytag gas dryer , runs for about 15 sec. heats up , then completly shuts off , Checked thermal fuse & it was blown , replaced & it ran for about 15 sec again & blew fuse again ....help .
Apr 26, 2010 | Maytag PYE3300 Dryer
Maytag gas dryer ldg7314aae my flame will not stay lit. Heats up flame kicks on then goes for about 20 seconds then shuts off. The dryer runs for about 20 more seconds and then the same thing happens...
you have done a lot . try running the dryer off the vent . when the burner is short cycling it a air flow problem . if off the vent does not solve problem ck the fan for a bad center . very common problem . and clean vent . ck outside for air flow and condition of vent hood .. hop this helps ..
Dec 03, 2009 | Dryers
Changed thermal fuse and cleaned out drier. it ran good for about 20 minutes and then shut down again. what could be the problem
changing the thermal fuse was a good idea but if the dryer runs for 20 min. then shuts off that is generally the motor going into thermal overload....thus meaning you would need a new motor.
Oct 02, 2009 | Maytag PYE2300AY Electric Dryer
Maytag LDG 712 shuts off before clothes are dry.
First, The most common part would be the over limit safety, it will be mounted to the element housing. Second, there is a thermal fuse usually a small disk with a little fuse inside. You can find these (with your model no.) at www.Repairclinic.com .Good luck.
Apr 20, 2009 | Whirlpool LER5636P Electric Dryer
Maytag mdet446ayw runs a few seconds and shuts off
maytag dryer mdet446ayw runs for around 30 seconds then shuts off
Apr 15, 2009 | Dryers
Heating element won't stay hot.
Hello vsjant3,
I assume you cheated out the door interlock switch when running your test. If you did not, then the dryer will shut off when the door is open as part of the safety interlock system. If you did cheat it out and the element shut off after about 20 seconds, then you may have a problem with one of the temp sensors. When an overtemp condition occurrs, it disables power to the heater and it will shut off.. Other considerations are the wiring to the heater.. if you had a poorly tightened heater wire that was ok when first started and cold but when hot and passing current opened, that would also exibit the same symptoms. If I were a betting man, I'd say you probably have a bad temp switch. You can measure them with an ohm meter ( dryer unplugged of course).. or simply jumper the wires together to bypass one to see if it is the fault. Make sure you replace a bad sensor and do not leave it bypassed or you risk fire.
Here is a link to the wiring diaghram of your dryer.. http://www.pcappliancerepair.com/model-display.php
Hope that helps,,
Regards,
Rick
Jan 08, 2009 | Maytag PYE2300AY Electric Dryer
Dryer shuts off
Hi!!! You seem to have a bad timer on the dryer..Or your vent on the back of the dryer can be plugged and the thermal cut off switch in the dryer turns it off..Good luck//
Jan 02, 2009 | Maytag PYE2300AY Electric Dryer
Dryers Logo
69 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
