Question about Black & Decker Toaster Ovens
Need to change the Switch : Switch number T120 55 TA 112 Where can I buy it or oeder on line - in Montreal Canada
Thank you
  • Anonymous Apr 24, 2016
    I'm also looking for that part or any part that would be compatible. "T120/55" "TA-112" 10A 250V~ 16A 125V~
Same here! You found it?
Posted on Apr 22, 2017
Where can I buy a replacement white George foreman drip tray? Thank you
Hi,I think if you have the papper work for the item there should be a part number on there some where,
or google g/f parts,I have one but have lost the book.
all the best
Mar 17, 2015 | George Foreman "" Grill With Bun Warmer...
I need a new handle for a Black & Decker toaster oven model #TRO964. I've looked on line, but am having trouble finding it available. Do you know where I can get one? Thank you!
you could get this on Ebay if you dont have an account you will need to create one
Add Email adress
Add Bank Acc
Add Credit Card
also add your postal adress
also add a paypal account
when you get to the paypal login page at the bottom you will see new to paypal sign up tab
paypal to create an account
paypal registration password ,bank card /credit card,phone numbers home/mobile ,email adress and a postal adress
http://www.paypal.com/
be very specific when you type in the search
always ask questions? before you make a purchase and keep the email/s for security reasons if the item arrives and its not as described
you will even see the pictures of your item so you cant make a mistake and get them home delivered
hope this helps you
Nov 11, 2011 | Toaster Ovens
I broke my Euro-Pro PE278 knob and switch (control) for selection cooking mode (midle switch control). Please tell me where can I find this part in Montreal Quebec.
If you don't mind shopping online then try the following address for a list of websites that sell oven parts and maybe one of them can help.
netshoppers.com/search/index.php?phrase=oven+parts&uid=d5d00793c96dccbcaa9b5f3ca3d412cd&kuid=4c4a6ef184c15b7eeffee322a7d94921&src=7s
Mar 27, 2011 | Euro-Pro EP278 Bravetti Platinum 1500...
How do i register my product online
On-line registration for Cuisinart Canada is here:
https://www.cuisinart.ca/warranty/index.php
Simply complete the on-line form with the required inforamtion and click register at the bottom.
Mar 26, 2011 | Cuisinart CBK-200 Toaster Oven with...
Can you change the default settings
hi friend,
  1. Touch Control Setup pad.
  2. Touch number 1 pad.
  3. Touch number 2 pad.
thank u for using fixya
regards,
sivaranjini
Aug 11, 2009 | DeLonghi DO400 Toaster Oven with...
Burned out diode in GE 168970 toaster oven
Just clip the diode out (pay attention to the white band around the end) take the diode to radio shack and match it's size physically.Then put it back in using regular electrical solder (rosin core) put the band on the diode facing the same way it came out
Jul 24, 2009 | Toaster Ovens
THERMAL FUSE BLOWN ON KITCHEN AID KCO100508 TOASTER OVEN. WHERE CAN I BUY A REPLACEMENT ? This Thermal fuse [ 206 degrees C ] is a ceramic housing mounted to a bracket near the oven wall. It contains a...
Thermal fuse is a one time safety device, order by specification. My Kitchen Aid toaster oven has one on the side with the controls marked 206c for 206 degrees Celcius when it blows, and marked with a part number that when Googled was found to be 2 amp. The fuse blows in this sequence: temperature first, then if that fails the regular fuse action will kill the circuit at 2 amps. I called electronic supply places around Los Angeles. $1. 25 later I have my part. Mouser electronics carries them for .44 cents. Placed the new one on the ceramic base of the old one, and am back to using my favorite toaster oven. Will not be using it for broiling again - that is when it got hot and quit on me.
May 28, 2009 | KitchenAid KCO1005OB 1400 Watts Toaster...
Hot plate not working
Check the non working plate element for continuity - if open replace it. Otherwise the switch is bogus.
Sep 04, 2017 | Euro-Pro EP278 Bravetti Platinum 1500...
Toster Timer Switch Broke
I had the same problem with the same exact switch DKJ/1-60. This part cannot be found anywhere but the factory and you'll have to buy 5,000 if you want one. There is another switch made for Delonghi that will work but it only has timer for toast. No 60 min. timer. The part # is 5218104600. This switch works the same way as the original but you will only have about a 13 minute timer. There is another one that has a 120 min. timer. The part # is 5218101800 for Delonghi. These switches look the same as the DKJ/1-60 but you may need to use parts from your old switch to mount these switches. Another solution to the problem is to replace the bad switch with a single pole single throw toggle switch that will handle 20 amp's on 120 volts AC. You will no longer have a timer and you will have to turn the oven on and off manually but at least you will be able to use the appliance. The above switch can be purchased at Gourmet Depot website for $10.98.
Jan 28, 2009 | Black & Decker CTO649 Toaster Oven with...
Timer Switch
Same problem with Black & Decker CTO6160 toaster oven. Same switch. Must be they're all Chinese garbage.
Dec 28, 2008 | Euro-Pro TO160L 1380 Watts Toaster Oven...
Toaster Ovens Logo
688 people viewed this question
Top Black & Decker Toaster Ovens Experts
Dave
Dave
derbed
Level 1 Expert
Are you a Black & Decker Toaster Oven Expert? Answer questions, earn points and help others
