Question about Electrolux Refrigerators
Why is it that several times in recent days the freezer alarm has sounded on our Electrolux fridge freezer even when the freezer door seems to be properly shut?
Electrolux fridge freezer model no ELUX ENB38607
  • Electrolux Master
  • 5,323 Answers
I would check the door seals for a leak
Posted on Apr 28, 2015
dcp2
  • 63 Answers
SOURCE: Samsung Refrigerator SR-608EV with water dispenser
There is another sensor in the door that senses how far open the door is. look for this and see if its disconnected or broke
Posted on Jan 28, 2008
SOURCE: Freezer alarm keeps going off..
Mate prehaps the defrost element could be burntout thus no auto defrost and the big freeze and the alarm, when you switch off the defrost starts and the alarm resets?
Posted on May 03, 2008
SOURCE: fridge freezer
there is a fan inside freezer behind back panel. if pipework behind panel is covered with ice, it will prevent air circulation and the fridge is affected first
take back panel off and check for ice build-up and that the fan is working
Posted on Jun 23, 2008
SOURCE: Zanussi Electrolux frost free fridge/freezer - freezer defrosting
My husband left the freezer door open a couple of months ago, causing ice to form. The loud rattling noise was the fan hitting the ice. The reason why the temperature started to rise but the noise stopped was because the fan had got stuck in a block of ice and was no longer working. Simple solution - defrost the freezer for 24 hours. Touch wood, it is all working fine now!
Posted on Sep 01, 2008
SOURCE: Fisher & Paykel Model number 402B S.Steel. Bottom frezer top Fridge.
My Fisher & Paykel Model E402B Stainless Steel Fridge/Freezer has a problem. Bottom Freezer is OK but Refrigerator will not work properly, somtimes it will freeze everything now it just warm inside i have checked the the fan and the rubber holding it up has broken also the ice is frozen in the vents can you help i got someone in to fix it but he said it will cost around $600 as there might be more wrong with it, what do you suggest thanks Clare
Posted on Sep 29, 2008
E240B Fridge Freezer door open alarm goes even when door closed.
Fridge keeps beeping or buzzing: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.
Cause of Beeping Noise in Frigidaire Refrigerator eHow
Dec 22, 2016 | Fisher Refrigerators
Electrolux door alarm Won't stop. We open door to turn off alarm. Temp seems right but slight condensation at the very top of the fridge. Need to at least disable alarm until I can get a repair.
Check the back wall of the freezer, I would suspect the beginnings of or a full-on defrost failure... If there is frost on the back wall of the freezer it means the evaporator is blocked, disallowing airflow to the fridge compartment... Electrolux Refrigerator Defrost Thermostat 216731001 . If there is no blockage, but temps are still not cold enough, your Frigidaire may be leaking refrigerant...
Jul 03, 2016 | Electrolux ICON Professional E32AR75JPS...
Freezer alarm
Hi Clair, thank you for allowing me to assist you.
When the refrigerator is beeping or buzzing, it may be a warning sign of a possible malfunction or an unsafe, interior temperature. To silence the buzzer, you can depress the ALARM OFF button. However, if you have already done this, try unplugging the unit or flipping the household circuit breaker for about ten minutes.
If the alarm continues, it could possibly be experiencing a communication problem with the temperature control/board or wiring failure. I would recommend connecting with a professional appliance tech for a clear-cut diagnosis.
Sep 06, 2013 | Electrolux Freezers
Westinghouse fridge freezer alarms keep going off
Try a different web site, where are the solutions on this one????? Great site..... not
Dec 30, 2009 | Freezers
Electrolux frost free fridge freezer
i have the same fridge freezer and the same problem and have no manual can any 1 explain thank you
Mar 31, 2009 | Electrolux Refrigerators
Maytag side by side slowly getting warmer
I have actually been having the same problem. We have a Maytag MTB2156GEQ and it hasn't been cooling well at all lately. Temp in the fridge is about 52 degrees even on the highest setting. The freezer seems to be fine. I pulled off the back panel and vacuumed out the condensor coil and everything else under there. I then pulled out the control panel on the ceiling of the fridge. The channel between the freezer and fridge was almost completely blocked with ice. I cleaned it out by taking out the back panel of the freezer and pouring hot water down through the hole until it was clear.
that seem fix the issue.
Aug 10, 2008 | Maytag MSD2656G Side by Side Refrigerator
Apr 28, 2008 | Refrigerators
Kenmore Upright Freezer Model 253.9239780 Temp alarm, Temp rising slowly
you have a refrigeration issue partner let her go 16 yrs. is good service you can replace it for 3 to 5 hundred the repair will be that IF you can find someone with the r-12. don't go for a top it off and go deal the food you lose is to expensive for that to be economical.
Mar 22, 2008 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Ddbb362 viking designer
It sounds like the light switch may be keeping the light on when the door is closed. Faulty Switch. Regards Advisor
Aug 19, 2007 | Viking DDBB363 Bottom Freezer Refrigerator
Refrigerators Logo
266 people viewed this question
Top Electrolux Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
