Question about Baby Gear
How do you remove the canopy - Baby Gear
How do you remove a canopy cover from a Hampton Bay fan?
Turn off the circuit breaker supplying power to the ceiling fan. The circuit breaker is in your home electrical box and may control more than just the ceiling fan. Place a stepladder under the Hampton Bay fan.
Remove the light bulbs and light covers from the fixture, if you have a light assembly on your ceiling fan. Remove the screws securing the light assembly housing to the fan with a Phillips screwdriver. Lower the light assembly, and hold it in one hand.
Twist counterclockwise the wire nuts securing the wires for the ceiling fan and light assembly, using your free hand to separate the wires. Lower the light assembly from the fan and set it in a safe place.
Turn the screws securing the fan blades to the unit with a Phillips screwdriver. Remove the blades from the fan and set them aside. Find the screws securing the canopy to the ceiling mounting plate. Loosen the screws two complete revolutions. Turn the canopy counterclockwise and unhook it from the screws. Slide the canopy over the fan motor housing and away from the fan.
Ask a helper to hold the fan motor housing if you have a Hampton Bay fan with a down rod. Slide the canopy over the down rod until it rests on top of the motor housing. Disconnect the fan wires from the ceiling wires, twisting the plastic wire caps counterclockwise. Slide the hangar ball, at the top of the down rod, out of the mounting bracket. Slide the canopy over the top of the down rod to remove it from the fan.
Regards
Sep 28, 2011 | Dryers
Evenflo embrace
Sometimes the canopy is attached with the carrying handle. Take the screws out of carry handle and remove canopy.
May 05, 2009 | Evenflo Embrace
Can the canopy be removed from a Peg Perego P3
Yes, it can be removed. Where the canopy attaches to the stroller you will see a clip like devise. Push the buttons down and slide the hood up the frame at teh same time. it should slide right off.
Mar 20, 2009 | Peg Perego Pliko P3 MT Classico Umbrella...
Frog canopy removal
Pull gently on the plastic arches that support the canopy (on either sides - where they connect to the stroller) and slide the canopy off.
Nov 05, 2008 | Bugaboo Frog Stroller
Dismantleing canopy
If this is for the Graco Snugride (I have the Windsor model from the Quattro Travel System), this will work:
1. Push the Graco canopy to one side, exposing the plastic support bars that hold the canopy in place.
2. The center of the support is where the canopy comes apart. Using both hands, pull the canopy support
bar apart (as if you were playing tug-of-war). It's best to grab the curved ends and pull HARD (and point it away to the side so that you don't hit your face).
3. Once the support bars are apart, remove the old Graco canopy and slip on the new/freshly washed canopy.
4. Secure the support bars by snapping them shut, and then slide the canopy into place.
Aug 26, 2008 | Graco SnugRide - Clover
Cosco Eddie Bauer Stroller Canopy
the lower frame bar locks the canopy onto the frame. Remove this and remove the brackets from the frame. drill out the rivit on one side (take note of the location of the snap and washers) and then remove the frame from the bracket and canopy. you then use a 1 inch 5/32 rivit to reassemble.
Jun 22, 2008 | Cosco Eddie Bauer Lightweight - Blanchard...
The sun shade on top
1. Infant restraint comes with four identical canopy support parts. Thread one canopy support completely through one sewn tunnel.
2. Slide straight end of a second support into the straight end of the first support.
3. On models with four canopy supports, repeat steps one and two for the other canopy tunnel.
4. Attach canopy in the areas between the infant restraint and the handle base.
To remove canopy, reverse the steps.
http://www.gracobaby.com/assets/pdfs/instructions/ISPC089BA_ISPC106AA.pdf
Hope this helps!! Thanks
Nov 16, 2007 | Graco SnugRide 8646 - Fiesta
Removing Canopy
I don't know what brand you have, but if you look on the inside of the holders for the canopy, there should be a little plastic tab holding the hooked end of the canopy frame in place.  Use a small screwdriver to lift the tab up enough so you can slide the hook out.  Once you have it out, remove the canopy and wash away.
Oct 11, 2007 | Evenflo Cozy Carry 5
Changing the Canopy
The canopy has two plastic poles for shape that you can remove so you can put the material in the washer.
Aug 18, 2007 | Eddie Bauer Musical Rocking Bassinet...
Baby Gear Logo
Top Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Are you a Baby Gear Expert? Answer questions, earn points and help others
