Question about Drills
Motor turns but the chuck won't turn - Drills
2 Suggested Answers
agent91
  • 2100 Answers
SOURCE: Crafatsman Rotary Tool Single speed - chuck has no power -
These are fairly easy to disassemble and get back together, take it apart and find out what got stripped, It might be an easy fix, then again, it might be going back to sears. They will take it back no matter what. Hope this helps.
Posted on May 29, 2010
How to use the collar settings
I am assuming you are reffering to the torque setting on the transmission that is set by turning the numbered ring just behind the chuck on the drill. The ring adjusts the torque where the motor will not be able to turn the chuck any more. At the lowest setting, 1 or 2, you can hold the chuck with your hand and the motor should turn without turning the chuck in your hand. This setting would let you turn screws into threaded holes or nuts but not let you over torque them and strip out the threads. Higher settings will let you drive screws into wood to a determined depth like flush with the surface or slightly countersunk. This depth will also be affected by the hardness of the wood so if you hit a knot the depth will change. The highest settings will drive screws or bolts in very tight before the transmission will slip.
Oct 08, 2012 | Ridgid 12 Volt Cordless 3/8 In. Drill
Hilti chuck won't turn
inside the chuck you will see a screw, remove the screw and chuck . A small punch with minimum forced with a small hammer to move the chuck dogs toward the end on the chuck . The chuck was opened to far and is a mechanical bind ..
Jun 30, 2012 | Hilti SFH 18A CPC Hammer DrillDriver
Remove the chuck dc970
I'm assuming you have a DCD970 as DeWalt doesn't have a DC970 and the DW970 is an impact driver. The chuck on your drill is a new design that doesn't have a lock screw inside the chuck, they are put on very tight with lock-tite to hold them on. They are made to be taken off with a special chuck holder and vice jig that only service centers have. The allen wrench method used on older chucks won't work as the chuck will just loosen when you hit the allen wrench. I have on occasion removed one by doing the following: Turn the chuck fully open then secure it in a vice with the drill straight up. Holding the drill body and using the handle for leverage, turn the drill counterclockwise, as you are looking down on it, with steady, strong pressure. If the chuck breaks free it will spin off easily. If you are at all afraid you may break the handle you may have to take or send it to a service center to have it removed.
Mar 07, 2012 | Dewalt Drills
I have just purchased a Makita 8391DWPETK 18V Cordless Combi Drill - how do i actually put a drill bit in? Do I need to take off the plastic ring?
The large black part of the chuck should turn left and right to extend (close) and retract (open) the three chuck teeth that hold the bit in place. Turn the chuck to open it far enough to get your bit fully in the chuck then turn it closed to hold the bit in. When the teeth make contact turn the chuck a bit further to get it tight enough that the bit won't slip. When you get used to it, sometimes it's easier to hold the chuck lightly and turn it by lightly squeezing the trigger to turn the chuck with the drill motor.
Feb 25, 2012 | Makita Drills
THE CHUCK WON'T TURN WITH THE MOTOR RUNNING. YOU CAN HOLD IT IN YOUR HAND AND FEEL IT CLICKING AND HEAR IT WHAT COULD BE WRONG WITH IT?
The DCD950 drill has a chuck that does not require the reverse-threaded lock screw. It is put on with lok-tite and a good deal of torque. It is hard to remove without the Dewalt vice tool to hold it but not impossible. Some can be removed by tightening the chuck in a vice and, using the drill handle for leverage, apply steady, even, strong pressure until it breaks free. Using this method usually bends the part of the chuck in the vice making it useless. Another reason for the chuck not turning when the motor is turning is a broken transmission. If the chuck works properly in tightening down and releasing bits, your problem may be in the transmission. If you go to http://www.ereplacementparts.com/ and search for your model number you can look at a breakdown of your drill and what you're looking at to replace the transmission.
Feb 12, 2012 | Dewalt 18v Battery Hammer Drill Dcd950...
I have a Kupa/KP36 that is making noise but the bit is not rotating. I have check the cord for power, tried different outlets. Unplugged hand piece replugged it in changed bits and still the same result....
Sounds like the chuck holder is already worn and needs replacement.
If the motor still runs but the drill bit won't turn the problem would be the chuck adjuster( the one that holds the drill bit and tightens it ).
If the motor does not turn but there is a whining sound the problem would be the armature bushing ( it is inside the motor which the rotor/armature rotates). The armature does not turn anymore.
Fuse is out of question because the motor still have some power. Check also the motor brush.
Disassembling it requires to unscrew all the screws on the side and carefully remove the side cover, you can clean it and dust it off.
Hope that helps you out!
Jul 07, 2011 | Drills
How can I replace the keyless chuck on my Dewalt DWD215G?
Open the chuck wide open. In the center is a retaining screw, they usually have left hand threads. Remove the screw. Take an allen wrench1/4" to 3/8" in size and fasten the short side tightly in the chuck. The chucks are usually right hand thread, so take a small hammer and strike the allen wrench to turn the chuck to the left to loosen it. Once you have the chuck off, verify the thread size of the drill motor shaft, then go to McMaster-Carr and choose the one you need.
Apr 16, 2011 | Dewalt DWD215G 12Inch 10AMP Heavy Duty Mid...
Crafatsman Rotary Tool Single speed - chuck has no power - that is motor will run smoothly - - chuck will turn - but your finger can stop it - it is free wheeling on it's own even while the motor is...
May 29, 2010 | Craftsman Single Speed Rotary Tool
Drill press
Release the belts and check if you can turn the chuck by habd, if the chuck won;t turn, two things could be wrong, 1) the quill bearings are bad or 2) the shaft that runs down thru the quill could ve rusted causing a restriction, if that's the case, WD 40 should loosen it.
Oct 24, 2008 | Delta 15 331 15" 115/230V Variable Speed...
Dewalt dc920 repair instructions chuck
To remove the chuck on your drill follow the instructions for the type of drill chuck you have:
Instructions for removing a keyed chuck
Most reversing drills have a left hand threaded screw located inside the bottom of the chuck.
1.) If the unit has this screw place the chuck key, with the chuck facing toward you, into one of the holes on the right side of the chuck. Strike the key in a clockwise direction with a wooden mallet or similar object. This will loosen the screw inside the chuck.
2.) Open chuck jaws fully. Insert screwdriver into the bottom of the chuck to engage screw head. Remove screw by turning clockwise this is a left-hand screw.
3.) With the chuck facing toward you place the key into one of the holes on the left side of the chuck. Using a wooden mallet or similar object, strike the key sharply in a counter-clockwise direction. This will loosen the chuck so that it may be unscrewed by hand.
There is no way to stop the motor from turning.
It may require several attempts to loosen the chuck
Instructions for removing a keyless chuck
1.) If the unit has this screw open chuck jaws fully. Insert screwdriver into the bottom of the chuck to engage screw head. Remove screw by turning clockwise this is a left-hand screw.
2.) Insert the short end of a 1/4" or larger hex Allen wrench into the chuck and tighten. Facing the tool strike the long end of the hex wrench sharply counter clockwise as it is a standard right hand thread. This will loosen the chuck so that it may be unscrewed by hand.
Oct 15, 2007 | Dewalt 18 Volt Compact Drill Kit
Drills Logo
73 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
