Question about Hardware & Accessories
How do I set a Digital Timer Model 458148? - Hardware & Accessories
Setting a timer model hb88rc75
http://waterheatertimer.org/Woods-timers-and-manuals.html#HB
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#hb88
Manuals for the Intermatic are located on links above.
If your timer does not show, then attach photo of product
If you have specific question about setting the timer, add a comment March 2015
Gene
Water Heater Timers Save Money
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Mar 28, 2015 | Hardware & Accessories
How do I set the clock? The included instructions for setting the clock do not work. I can set all the programmed on & off times, days of week, etc., everything except the friggin' clock. The cl
Give us the model number so we can see what you're talking about. Tell us what link you have tried, and how the instructions seem to be different.
Display showing no-op is sometimes associated with defective timer, bad battery. Resetting timer will clear memories and restore functionality in some cases.
http://waterheatertimer.org/How-to-troubleshoot-timers.html#digital
Attach photo of timer, or description of timer.
Add if this is new timer or if timer worked before, and what load the timer controls
Do you have correct instructions for timer ?... scan the manual into .pdf format. and then post the .pdf manual on your website .... then post link here to assist other folks with same problem.
Gene
Dec 11, 2014 | Hardware & Accessories
How do I set the Intertek 3075048 timer Model #YL-13M-1
Post photo of timer so it can be identified.
Or describe timer in detail, including what it controls and if timer is digital or analog
Otherwise this model number appears to be fixya fiction
http://waterheatertimer.org/How-to-set-timers.html
Gene
Dec 09, 2014 | Hardware & Accessories
How to set timer a digital timer
http://waterheatertimer.org/How-to-set-timers.html#digital
Timer brand and model are unknown
Gene
Aug 17, 2014 | Hardware & Accessories
Defiant daylight adjusting digital timer instructions
If you have the Defiant Digital Timer, I found this great video on the Home Depot Website! It's step-by-Step! Nice!! http://www.homedepot.com/p/Defiant-20-Amp-7-Day-7-Event-In-Wall-Digital-Timer-49814/203678179
Jul 19, 2013 | Hardware & Accessories
Lost my instruction manual for Polder Digital Therm/Timer/Clock and I can't remember how to set it.
I'm not sure which model number you have.
Polder timer manuals appear on following link: Click on timers and thermometers.
http://www.polder.com/productinfo.html
Jul 04, 2011 | Polder Triple Digital Timer Model 891-90
I want a programmable timer that can, eg, switch on a single phase electric motor for 10 seconds every hour. It may be 9 secs or 11 secs.
You need a programmable interval timer.
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#ET70
Intermatic and Tork make digital timers with interval settings that can be set for specific short-duration with 1 minute minimum.
(Or set to pulse bell ringing with 1-127 seconds.
10 minutes is 600 seconds)
For example ET70115 single-channel timer.
The timer would be set for 24-hour operation, and then programmed for Pulse, and then set timer with 24 programs, with 1 program for each hour.
Mechanical cycle timers from Intermatic:
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#cycle
1) Talento 1 hour cycle timer/ each tripper represents 1.25 minutes
2) Model C8835/ each tripper represents 15 seconds.
To operate these timers certain hours of the day, add another timer in-line.
The in-line timer could be digital, but remember digital timers are not protected from power surge and tend to have more problems, and do not have replaceable clock motors and trippers.
Apr 08, 2010 | General Electric GE 24-Hour Timer, 2-Pin...
Hardware & Accessories Logo
1,134 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
